Old 06-11-2011, 01:03 PM   #1
VDFS
Question Ds95i on trex450!!
What you think use servo DS95i on trex 450 ? This servo is the best option?
Trex 700E 12s Pro DFC
Trex 600E 10s with Vbar
Trex 450 Pro with Vbar
Trex 250 with scorpion 3600Kv
VDFS is offline        Reply With Quote
Old 06-11-2011, 01:29 PM   #2
Luvmyhelis
Yes, yes, and again yes!
This topic is being discussed in almost every forum, and the consensus is always
Yes!
Jeti//800Triabolo/Gob700/SHS800/Frankenheli600/Chase420/Compass/Coax/Sk720B/540/360 YGE/YEP/HW/MKS/Outrage/Turnigy/Mibl/Soko/KollDubroRcTek/Boca/Herc/Gryphon/ScottGray Scorp/KDE/Kontronik/TP/Tenax/Lynx
Luvmyhelis is offline        Reply With Quote
Old 06-11-2011, 01:50 PM   #3
CaptainCarling
So that's the servo for the job then
CaptainCarling is offline        Reply With Quote
Old 06-11-2011, 02:58 PM   #4
akamullen
I am running the whole ds95 cyclic and ds95i tail servo set on my 6S 450 pro with microbeast, the tail gain is now about 15% higher than I could ever get it with the futaba 9257. MKS make some of the best servos in the world. They also make the Torque servos for outrage, I use the outrage tail servo 9188 on a couple of my large machiens and the tails are much better than any other tail servos I have tried. and I have tried MANY.
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN 380/500-x2/630/770 * Swinging SWITCH/RJX/RAIL & SAB Blades * Microbeast/IKON * Castle ESC's on all * DX18 *
akamullen is offline        Reply With Quote
Old 06-11-2011, 05:19 PM   #5
ScotY
What's the consensus on the Ds8910A+ mini servo? Specs are comparable but is it as precise and slop-free as the Ds95 series?
ScotY is offline        Reply With Quote
Old 06-11-2011, 06:36 PM   #6
VDFS
Question
What difference between DS95 and DS95i?
Old 06-11-2011, 06:55 PM   #7
VKGT
I think it's more expensive than I'm willing to spend on the 250... So JR DS290G for me although I hear that the DS95i is the best tail servo for this heli, period.
JR11X Come to the dark side
T-Rex 500E, T-Rex 700E 3G, Min Air Fury 55 FB, Min Air Fury Expert 60, Blade mQX, Rotor Concept HP-Q1
VKGT is offline        Reply With Quote
Old 06-12-2011, 02:56 AM   #8
Funky242
DS95i is a dedicated tail servo. It is a bit faster, but a bit less torque than the DS95, but it works @ a pulse of 760s, so your gyro must support that.
A DS95 should be OK for the tail too. Those servo's are amazing, I'm using the 95/95i combo on my 450Pro too.
Logo600 V-Stabi- BLS252/251 - Jive 80+HV - Scorp 4035-500 (12S)
Prtos 500 - Microbeast - Svox DS1250MG/MKS DS8910 - Jazz 80 - Scorp/MSH 3026-880
Funky242 is offline        Reply With Quote
Old 06-12-2011, 03:40 AM   #9
Fullonoob
Which servo arms to use? The one that is include come with two side ... Do I cut off one side?
Fullonoob is offline        Reply With Quote
Old 06-12-2011, 04:45 PM   #10
Luvmyhelis
Me too, but I haven't run the cyclics with my new Sk-720 yet since my blades are in the mail. Should be interesting to see how all this ties together with my previous 6s scorp mod.
Yes, you can either cut them down to single sided arms or leave the counter arm on. It looks better trimmed off. But, if you crash and tear the end off the arm you now have to buy another arm. If you leave the double arm alone it leaves you with the option to just turn the arm over, trim the bad piece off and go flying again.
ID:	233611   Click image for larger version
Old 06-12-2011, 05:10 PM   #11
Fullonoob
I have mine mount inside is that going to be a problem?
Old 06-13-2011, 04:00 PM   #12
VDFS
Question
Guys DS95i do not work well on ciclic or DS95 is sufficient?
Old 06-13-2011, 05:06 PM   #13
froghammer
Ds95 are more than sufficient for cyclic. You would want to use those and not the 95i. It's for the tail.
froghammer is offline        Reply With Quote
Old 06-15-2011, 02:25 PM   #14
Funky242
You cannot run the 95i on the cyclic. They are 760s tailservo's. Won't work on the cyclic.
On the swash it is better to have some more torque anyway. The DS95 are more than fast enough on the swash.
Old 06-15-2011, 06:40 PM   #15
Warhorse
Since I am now have the unenviable task of rebuilding my T450 Pro, I'm seriously thinking about the DS95s for cyclic since I have a FBL setup and I've heard they are the only servos that stand up to that kind of stress and the occasional shock load.
Trex 450 Pro, Agusta A109 fuselage, Align 3G FBL head, SK720, MKS DS95's, ICE 50
Tarot 450 Pro, Align 430L, ICE 50, FBL w/ SK-720, HS5065MG cyclics, HS5084MG tail
MCPX V2, all stock
Warhorse is offline        Reply With Quote
Old 06-15-2011, 07:58 PM   #16
Luvmyhelis
Oh no! Not you too! Sorry! Oh well, I have some new Mks Ds95 cyclics showing up tomorrow for one of my new builds after wreck carnage also. Man it hurts paying for them.
Old 06-15-2011, 11:33 PM   #17
invertsick
I really want to get these servos for my 450 FBL Pro.
But the idea of paying over 300$ for micro servos is killing me
But i know they are the best.
invertsick is offline        Reply With Quote
Old 06-16-2011, 05:00 PM   #18
ScotY
Yeah, they sure are expensive servos but until you've plugged one in and played with them, they don't seem to be worth the money. I'm not up to speed with all the latest stuff out there, but I have NEVER seen a micro servo that had ZERO slop and amazingly smooth, quiet, and fast. I just ordered 3 Ds95s for the new Pro kit on the way! Hope they do hold up to crashes as well as they say because I will definately be testing their durability.
Old 06-24-2011, 03:45 PM   #19
Warhorse
I just finished rebuilding my 450 Pro and put MKS DS95s on the cyclics. I can't fly well enough to tell the difference between them and the old Align DS410s but everyone says they are a lot stronger and will survive better in a FBL environment. The 450 seems even more stable if that says anything. When I first test hovered it, I thought I was having problems getting it to lift off and then looked under it and saw the skids 2 inches off the ground. I have NEVER had one of my helis hover that stable (and no I didn't have the self leveling enabled).
I know one thing. They sure are fast! I was doing that flick the control levers thing like in the video and watching them. The arms are almost a blur. When I still had the servos out I was flicking the lever and watching them dance on the workbench. Funny!
MCPX V2, all stock
Old 06-25-2011, 06:25 AM   #20
VDFS
When my align damage I will buy MKS.
