Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 06-26-2011, 12:36 PM   #81
tntburnett
Originally Posted by Nytflyer View Post
Curious what motor I should use and what everyone's opinion would be. I have my thesteve converter on the way should be here this week and I have 3 motor options as I have some extra one's laying around from my wakera's.
So, my choices are the WK-003 which is the same as the helimax motor TNT is using. Next up is the Red Turbo Ace model 91416 and then the HP07 or HP06v2 whichever you prefer to call it.
Just wondering which one you guys would use if you had those 3 choices.
well the one I am using is 11,000 kv which you already no this. I would use the one that you half to do the less mode to the frame . Also you can use the one that benefits you. You do know i am using a 9tooth pinion which works perfect.
tntburnett is online now        Reply With Quote
Old 06-26-2011, 12:49 PM   #82
Nytflyer
Hi TNT thanks for the reply. I was thinking along the same lines as you to use the one that requires the least amount of frame modification. Then started thinking a bit more and that motor weighs around 11g where as the HP07 is right around 7g so there is a significant weight savings. I have got a couple of those 9t pinions from BP(thanks for the link) so that is what I will use. I am also wondering if saving the weight will really even matter with the added power of the brushless set up.
Nytflyer is offline        Reply With Quote
Old 06-26-2011, 01:02 PM   #83
tntburnett
My weighs in at 56 grams with the stock battery and without 50 grams (hard 3d ime 3:10 stock battery and sports flying time 4:50). factory stock weighs in at 46 grams with battery and without 40 grams.
i went with the setup i have becuz less mod on the frame and the other motor had to come from hobbyking out of states ( why they dont have it the states) and i got this one from towerhobbies.
do this buy another frame and do one with the walkra motor and the other frame with the other motor to see which one you like better
http://www.helifreak.com/showthread.php?t=316832&page=2
Old 06-26-2011, 01:26 PM   #84
Nytflyer
Great idea man a new frame is only 8 bucks that is what I will do so I can try them both. Will let you know the results when I am finished the conversion.
Good luck and happy flying!
Old 06-26-2011, 01:40 PM   #85
gashead
Here is some pics of my brushless conversion mcpx.
I am using the helimax novus cp brushless conversion kit I got it from http://www3.towerhobbies.com/cgi-bin...8015&search=Go
the 9tooth pinion from
http://www.bphobbies.com/view.asp?id...18&pid=S739658
and the steve converter from
http://thesteve.ca/walkera/
Heres video also
http://www.youtube.com/watch?v=RJnTs...el_video_title
The pics with the yellow wire shows how I done it and it works well. I solder the yellow wire to the old main motor plug on positive side and plug it into the plug on the board.
This thing is
Enjoy
Have a blessed week
Which convertor is requires from the four listed?
gashead is offline        Reply With Quote
Old 06-26-2011, 01:50 PM   #86
tntburnett
This one
Custom made converter for the Walkera 4#3/a/b helicopter(also works in the Kyosho Minium and Parkzone Vapor as well as many others) to allow the use of a brushless controller for the main motor. ***USA and Canada shipping*** - $15.00 shipped
Jesus Rep all over, Team Outrage USA Rep Orange Power
O Fusion 50, BL mcpx ultra, 700e, trex 450 pro all FBL
3g, vbar 5.1(blk), 3g, kds ebar
GOD BLESS
Old 06-26-2011, 06:40 PM   #87
Goatkeeper
Originally Posted by Goatkeeper View Post
I held tnt's mcpx today and the cg is only slightly off, with the esc in the front to help add a little weight. But I promise you, if you saw it fly you would see that the cg imbalance made no difference in flight. The tail was absolutely glued in place. I can't wait to do this mod.
Ok... I did the sr120 tail mod and what a difference, holy cow. I tried to make it blow out but it didn't come close.
After I do the bl mod on the main motor I may cut the tabs on the sides of the batteries so they can be moved farther forward to help with the cg. It also looks like you could trim the batt holder on the landing skids and get 2 or 3 more mm.
Lynx Heli Innovations team pilot.
Mavrikk field rep.
Goatkeeper is offline        Reply With Quote
Old 06-26-2011, 10:59 PM   #88
Crashhappy13
for that resistor can you solder it right on the steve converter so its compacted or do you need it going from the plug to the end of the blue wire
Crashhappy13 is offline        Reply With Quote
Old 06-27-2011, 06:47 AM   #89
tntburnett
Here is what I found of a better diagram then I drew :-). This is on the blade MSR but the same concept. Have a blessed week.
http://www.rcgroups.com/forums/attac...mentid=3122340
Sent from my DROIDX
GOD BLESS
Old 06-27-2011, 11:20 AM   #90
adroc3905
Ok, got the stock SR120 tail blades on and it’s locked it. Wow what a difference using the Helimax BL motor and 9T pinion with the SR120 tail motor and boom ext mod. Flies sweet.
Originally I was worried about the CG being tail heavy (which it is) but when doing sport/3D you would never notice.
TBS Discovery
Rave 450 FBL - miniVbar
Trex 500 ESP FBL - Beastx
Trex 600 ESP FBL - Beastx
adroc3905 is offline        Reply With Quote
Old 06-27-2011, 11:56 AM   #91
tntburnett
Glade to hear it worked out.
Sent from my DROIDX
GOD BLESS
Old 06-27-2011, 01:39 PM   #92
dbennettya
Default 120SR tail motor heads up
Hi all,
If you go with the 120SR tail motor, blades and boom extension mod you need to know this. When buying the 120SR tail boom assembly I noticed a small round oblong part that was in a small bag with the assembly. I asked the LHS guy what it was and he told me it goes on the end of the motor before you press on the tail rotor. It turns out that it is a cup that holds a 1x3x1mm bearing for the output shaft. It mounts on the front of the motor and provides a load bearing for the output shaft of the motor. I think it is to provide a thrust bearing for the tail rotor and help unload the main motor bearing on the output side. I noticed that this part is available seperately:
Tail Motor Protective Sleeve: 120SR
(BLH3125)
When I mounted the tail rotor I used a small square driver bit to hold the back of the motor through the hole in the motor holder so I could seat the rotor as far a possible on the shaft.
Good Luck, Don
dbennettya is offline        Reply With Quote
Old 06-27-2011, 02:00 PM   #93
tntburnett
Originally Posted by dbennettya View Post
Hi all,
(BLH3125)
Good Luck, Don
I have it on mines. It came with it when I bought it.
Sent from my DROIDX
GOD BLESS
Old 06-27-2011, 02:05 PM   #94
adroc3905
Which direction should it be installed?
I left mine off as I did not realize its usefulness at the time.
TBS Discovery
Old 06-27-2011, 02:07 PM   #95
tntburnett
Small end facing towards the motor
Sent from my DROIDX
GOD BLESS
Old 06-27-2011, 02:14 PM   #96
tntburnett
Bearing facing out
Sent from my DROIDX
GOD BLESS
Old 06-27-2011, 02:14 PM   #97
dbennettya
Tnt,
How long is your tail boom from end of the frame to the front of the tail motor holder? Mine is 4 5/8".
Thanks, Don
Sent from my DROIDX
Old 06-27-2011, 02:16 PM   #98
tntburnett
Tnt,
Thanks, Don
Right at 6 inches
Sent from my DROIDX
GOD BLESS
Old 06-27-2011, 02:22 PM   #99
tntburnett
Sent from my DROIDX
GOD BLESS
Old 06-27-2011, 02:26 PM   #100
dbennettya
Tnt,
How are you measuring it? If I measure from front of the frame where the 2mm shaft is by the elevator servo to the end of the tail motor holder I get ~ 6". But if I measure the exposed tail boom length I get 4 5/8".
Thanks, Don
Right at 6 inches
Sent from my DROIDX
