Old 12-23-2012, 11:05 AM   #121
salasgr
Anyone using BeastX on Velo 50N2 flb to post his settings...?
salasgr is offline        Reply With Quote
Old 01-03-2013, 03:36 AM   #122
salasgr
I guess im the only one all over the world flying velocity 50N2 fbl with beastX... ...well, not yet !! i will post mine when time comes
cheers
Old 02-16-2013, 01:51 PM   #123
koi-fish
Anyone have beastx settings for X2, 093 and 095 servos?
/MSRX, MCPX, Nano, 1SQ, several 130x, Gaui X2, 300x, 450x, DX8, Harley Road King
"It's not getting any smarter out there, you have to come to grips with stupidity and make it work for you" - Frank Zappa
koi-fish is offline        Reply With Quote
Old 03-21-2013, 04:49 AM   #124
Ze Povinho
Trex 450 Pro V1
Equipment
Scorpion HKII-2221-8 main motor with 15T pinion
Spektrum H3020 servos on cyclic
Futaba S9257 on tail
Align Pro FBL head
Align ESC
DX6i transmitter
Transmitter mode
15 percent expo on aileron and elevator
10 percent expo on rudder
100 percent ATV on aileron, elevator, and rudder (I might experiment with 10 percent more
on aileron and elevator and 5 more for tail)
70 percent gyro gain
0-40-80-80-80 normal mode throttle curve
85 percent flat idle up throttle curve
40-45-50-75-100 normal pitch curve
0-25-50-75-100 idle up pitch curve
Parameter menus
Everything is stock setting with the exception of the following:
B control behavior: transmitter
G cyclic response: slightly increased
Batteries used
Sky Lipo 2200 mAh 40C 11.1V
Gens Ace 2200 mAh 55C 11.1V
Gens Ace 2200 mAh 60C 11.1V
Ze Povinho is offline        Reply With Quote
Old 04-30-2013, 11:43 AM   #125
Wardy1982
Hello All.
Now got myself a 450 sport v2 with the ar7200bx and i love it. Been reading manuals since i got it second may i add and wondered what settings i should be running on a dx6i with the ar7200bx
Cheers
Wardy1982 is offline        Reply With Quote
Old Yesterday, 08:39 PM   #126
RBoyne
Question MicroBeast
Good day all,
I set up my Trex-600 Pro Nitro using Align Head and parts from Ron's. All seems well except setting my D/r . Should I leave the cyclic with over 12 degree +- or some how reduce those numbers.
If I reduce the travel by the TX it takes from 100% to 20% to get travel within range of normal flight.
I also use a Airtronics SD-10G.
Use of D/r seems to slow the swash movement down is this OK?
RBoyne is offline        Reply With Quote
