| Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics |
#161 |
That is strange. I must admit, I probably haven't done multiple consecutive forward flips in the few flights I've had on my 500, only back flips but I will try if I ever get out to fly with all the bad weather we are having around here.
#162 | |
Another thing to try is to recalibrate the sensors Can also be blades or swash not level throughout range |
#163 | |
Yes, gain against black Sensor recalibrated Blades are 3G blades, balanced, but will try another set Will check swash again
Ben Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251 DX8, RF6 |
#164 |
ok guys, just noticed this today, I have now mounted the unit on the side frame & changed the units orientation under sensor menu. The first thing that got me was that after changing the orientation I had to reverse each axis sensor direction, I've done the same with the Mbeast & just changing orientation was all I had to do, everything else worked as normal.
Next, now that every axis is working correctly including the tail every time I give elev or ail input the tail slowly moves to the right (if you stand behind the Heli). This I've never noticed before, this is with the Heli on the bench, has anyone noticed this?
Shape 9.0, Goblin 700 (yellow & orange) , Outrage G5 all FBL** MKS Cyclics & Rudder Servos all round. Futaba SBus Rx, Futaba 8FG** transmission. |
#165 |
That's cyclic DMA, same as when you go from mid stick up or down on collective tail should compensate, normally to give right nose thrust.
the higher the value the more the throw, strange that you had to change sensor direction, did you also change wire orientation? |
#166 |
I was thinking the same about servo plug order but even the tail sensing I had to change.
#167 |
Does anybody know what pulse rate and frequency to use with Hitec 225's on the cyclic?
Sent from my C771 using Tapatalk
MSH Protos 500 GT-5 FBL, Trex 450 Pro 3G FBL, TT Mini Titan v1, Blade MCP-X & Nano CPX, Blade 130x. - Spektrum DX8 |
#168 |
You can check on Beastx web site, they have a pretty big chart with a lot of servos. Maybe yours are there
#169 |
I just looked and the hitec 225 is not on the list
#170 |
its a analog servo,u should use lowest frequency.
#171 |
760us/???Hz
Also what to use for the spectrum 5020g for the tail? Sent from my C771 using Tapatalk
#172 |
Go to beast x website they have a list of servos there, sorry dont have link
#173 | |
I have already been to the beastx site and my servos are not in the list. Sent from my C771 using Tapatalk
#174 | |
You are mixing frequency in hz (the number of times per seconds the servo gets updated with a command from the FBL unit) and PWM (the Pulse width Modulation, in s, that defines what the center reference for the servo is). So for your analogs on cyclic set them for 1500 (or 1520, can't remember) µs and lowest frequency (70hz or so, can't remember either) Your tail servo is digital, I would set high frequency (333hz) and it is most probably a 1520 µs center as well.
#175 |
I was under the impression that 760us was for analog servos and 1520us was for digital.
#176 |
Wrong, again, you are refering to the centering PWM of a servo. Most servos (analog or digital) center at 1520 µs. a few at 760 (Futaba BLS251, some MKS and others...)
Set you analog to 760µs and you will most likely fry it Drive frequency 65 or 70 hz is for analog, above for digital. Likewise, set your analog to 200 hz and it won't be long before you see some magic smoke out of it
#177 |
How do I set the pulse rate for the cyclic servos? I have only seen it for the tail servo. Unless the cyclic pulse rate is non-adjustable.
I am a noob to setting up FBL so patience with me would be appreciated. Sent from my C771 using Tapatalk
#178 |
My answer was general. Most (all) units do not allow cyclic servo pulse rate adjustment because most servos used for cyclic are 1520µs anyway.
So for you. Cyclic: set lowest frequency (analog) Tail: set high frequency set 1520 µs
#179 |
Are there a default settings list for a Raptor G4 and the GT5 gyro anywhere....i'm confused
