Go Back   HeliFreak > R/C Electronics Support > Eagle Tree Systems
Eagle Tree Systems Onboard data loggers, telemetry, and OSD support
Old 08-23-2011, 12:11 AM   #1
Windbreaker
Default Hard case for EagleEyes
The heat shrink doesn't provide much protection for the EagleEyes circuit board, and it doesn't allow a secure way to mount it near the receivers which would be on a stand.
So I made one with Plexiglass.
There are holes for all the audio and video jacks, as well as holes and slots to provide access to the two control buttons, adjustment screws and I/O connectors.
The circuit board is supported from below. One of the SMD's are very close to the edge of the circuit board, so the strip of Plexiglass holding up that part of the board had to be carved away.
It's held closed with a couple of small servo screws. Because the case is totally transparent the labels and LEDs are all readily visible. The only difference now is that it's better protected and easy to mount using VHB adhesive.
I'm only using this as a diversity controller for now.
ID:	248638   Click image for larger version
ID:	248639   Click image for larger version
ID:	248640   Click image for larger version
Custom quad copter, Cobra C-3525/18 motors and ESCs; APC 15x4 thin electric props. OpenPilot ControlCopter board. Futaba 8FG Super 2.4 gHz FAAST system.
Windbreaker is offline        Reply With Quote
Old 01-06-2012, 12:40 AM   #2
MIRCEA1305
Hi Windbreaker,
Awesome case you have there-if it is not too much to ask for can you please share a drawing of it?
Regards
MIRCEA1305 is offline        Reply With Quote
Old 02-06-2012, 05:13 PM   #3
landshark501
very nifty!
just got mine in..and was thinking how to go about protecting it..
i think you've given me a spark of genious...
i think..
what???? i gotta stick to one area of rc?? HA!!!!
"COBRA "- "HEADHUNTER" AH-1W HELI BUILD
landshark501 is offline        Reply With Quote
