Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Odin and 3D+
Odin and 3D+ Compass Odin and 3D+ Model Helicopter Discussion
Old 08-24-2011, 09:57 AM   #1
yannick
Default regulator
hi. I want to use a regulator on my compass 3d+. I will be using a v-bar, jr 8717 and 8900g tail servo. I already have a scott gray regulator but i would prefer something with less wires, something with an input(dean) and an output at 6v.
I was looking at the cc bec pro or the arizona regulator.
How many amps a set-up like mine can draw?
the cc bec pro is rated at 20 amps and the arizona, i did not find the specs.
Any suggestions or other regulators ???
I am using life batteries but would like to return to lipo!!!
yannick is offline        Reply With Quote
Old 08-24-2011, 10:36 AM   #2
belcom
something like this maybe...
http://www.readyheli.com/Gryphon-Duo...r_p_37006.html
or this...
http://www.readyheli.com/Gryphon-Ext...r_p_37005.html
Which receiver are you using anyway? What are you doing for governor?
For less wires overall it is suggested to use AR7100R receiver with built-in rev limiter. it also has a built in regulator for tail and throttle but if you're running BeastX for example you can't really use the 5.2V tail output on the receiver. There are 2 connections from 7100R to BeastX which will supply 8.4V from 2S Lipo directly and tail servo would be getting the same voltage.
The way I'm doing it right now is running the 8717s on direct 2S Lipo and have a high voltage tail servo.
The way I plan to do it in the next couple of days is to run that 2 channel Gryphon voltage regulator between the 7100R and BeastX which will provide regulated 6V into the BeastX and run everything on that voltage essentially. Or another option is to regulate the voltage on the tail servo only.
The other good thing about the 7100R is the rev limiter. The sensor attaches to the back plate of the motor and you're good to go. If using other governors it is necessary to do some modifications and custom fitting of the sensor I believe.
There are so many options really but you have to plan beforehand and order what you need. Scott Gray X2 is great but it might be tricky getting it to work with 7100R receiver. However if you have a regular receiver just get it to work with X2.
Compass 7HV, SAB Goblin 700, Minicopter Diabolo, Mikado Logo 600, Synergy E5
RCHeliCanada.com - Compass Model - SAB Goblin - Synergy - MKS Servos - YGE - Kontronik
belcom is offline        Reply With Quote
Old 08-24-2011, 10:45 AM   #3
Down Low
Hi, I can't really answer your question (sorry) but I have one for you if I may.
Why exactly do you wish to return to LiPo? Was there something about LiFe that you didn't like?
Airtronics SD10G, SK540, Novarossi .57 3DS
Synergy N5C Build in progress!
MAAC #85462
Down Low is offline        Reply With Quote
Old 08-24-2011, 11:12 AM   #4
yannick
Default regulator
i have already used a 7100r on a flybarred heli but now i want to use the v-bar with 2 satellites( no receiver). So i want a regulator with an imput and an output that will plug in my v-bar at 6v. The v-bar will supply voltage to all my servos.
Nothing wrong with the life packs. It is just that it is harder to monitor voltage. Life batt have a different discharge curve making it harder to monitor. I will be using a dx-8 with telemetry so it would be easy to keep an eye on the lipo's voltage.
Old 08-24-2011, 12:37 PM   #5
belcom
Well, ok. I understand what you mean. I am running BeastX and it can get it's power from servo lines via the receiver. I also have a mini Vbar and was just looking at the manual. They're suggesting to supply power via RX B or RX C channels. And that's the way I do it on my Logo.
Western robotics Mini Super BEC should work ok. You can set the output voltage to 5.2v or 6v and it has 2 separate wires for dual input into Vbar. Will supply both RX B and RX C with 6V for redundancy. And you don't have to use X2 and run everything at 6V with satellites. WR will be much more reliable than CC. The only concern is supplying the BEC with only a 2S Lipo. These are designed to run on 6S. It should work fine I think but maybe better to use a 3S receiver pack.
Old 08-24-2011, 01:28 PM   #6
yannick
Default regulator
a 10 amp regulator will be enough for my system???
What about the arizona regulator??? is it good
Old 08-24-2011, 01:49 PM   #7
belcom
Sorry, never used Fromeco Arizona regulators but it does look interesting and is designed for 2S Lipo. Maybe it's your best bet then. Since WR spec says from 3S to 6S. 10amp will be enough.
Old 08-24-2011, 03:34 PM   #8
alexmit
I run a perfect regulator on my 3D+ nitro setup with vBar. I've never had any issues with any of their regulators I have used.
They have many choices for they type of regulator you can use.
http://www.perfectregulators.com/
Atlanta RC Club, The only club inside the city.
SAB USA Field Rep. Canomod USA Field Rep. Pulse Battery USA Field Rep.
alexmit is offline        Reply With Quote
Old 08-25-2011, 07:37 AM   #9
Jeff_Barrett
WR makes an excellent BEC and is highly regarded in many circles.
On my 3DPlus, I'm running the Skookum Powerbus.
Owner - RCHeliCanada.com
Compass || Gaui || Synergy || Walkera || DJI || Skookum Robotics || TracX || Bavarian Demon || MKS Servo
Jeff_Barrett is online now        Reply With Quote
Old 08-25-2011, 08:06 AM   #10
yannick
Default regulator
just by curiosity, is there a problem with the cc bec pro? i know there are some problems with their esc but what about bec pro?
Old 08-25-2011, 01:22 PM   #11
belcom
had seen a few references of them burning out and taking all electronics down with them. when it fails it sends the voltage straight from the battery and burns everything.
Old 08-26-2011, 10:58 AM   #12
alexmit
I use Castle products to light my grill. They work just fine for that.
Old 08-30-2011, 08:38 PM   #13
Jeff_Barrett
LOL!
CC is really taking a beating this past year or so.
