| Odin and 3D+ Compass Odin and 3D+ Model Helicopter Discussion |
Anyone flying a KME60 in their 3d+?
Im thinking of putting one in mine, but not sure if the upper mounting bracket will fit... Could I mount the engine without the upper mounting ring? Most heli's dont have this so I think it would be ok.. |
If you havent already bought one I would skip the kme and just stick with os.
Havent purchased it yet.. If the KME should be avoided why not YS56?
From all reports the YS56R has more torque and less bearing wear compared to the 55HZ.. And its regulated/pressurized. |
I would go for a YS or a Novarossi. Never really cared for OS. Way over rated in my opinion.
Airtronics SD10G, SK540, OS.50 Hyper (possibly tweaked a little) To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Synergy N5c MAAC #85462 |
Anyone tried the new thunder tiger 56? could be interesting.
#6 |
#7 |
watched one run recently and was not impressed at all, it was well tuned and seemed to run like a dog.
#8 |
One of the RR members tried a new TT56 and it lasted all of 30secs before the connecting/conrod broke off where it joins the crack shaft.. Not a good start...
http://rc.runryder.com/helicopter/t631523p7/ Doesnt fill me with confidence.. |
#9 |
yep I did see that post, I have an answer anyway as cjp tested the motor with a gp55 and its a no go, I have a gp55 here so I will be going the os motor
#10 |
Location: Winnebago IL Where the politicians are MORE corrupt-Thanks alot Blago/Burris/Daley etc...
skip the KME and get a YS56 or an OS55
I run one of each in my 2 3d plus's. If you run the YS, make sure to get a new rubber insert for the upper motor mount.
):> Team Alees To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Scorpion Power Systems/Batteries |
