Old 04-14-2007, 08:53 PM   #1
mudbogger2
Default DIY Night blades
This is not new stuff. It has been done before but this is my first try at making night blades. I do a lot of night flying and I have been using the MS night blades. They light up well but I do not really like their in flight performance. So I figured it was time to make me a set of Radix night blades! :glasses2:
I used the following to make these.
1 set of Radix 690's
2 rolls of 1/16" copper tape http://shop4.outpost.com/product/593...H:MAIN_RSLT_PG I only used 1 1/4 roll so some is left over
SMT LED's http://www.ledtronics.com/ds/SMD-0603/#0805 I have not had a chance to buy from this company yet. I would love some feedback from anyone who has or does.
Resistors http://www.radioshack.com/product/in...entPage=family
This pack had all the resistors I needed plus tons more. The resistors are not manditory unless you are using the red leds. The blue, white and green do not have to have the resistors.
2- 90mah lipo cells http://www.bphobbies.com/view.asp?id...27&pid=W561531 website shows 80 mah but they are actually 90 mah cells
1- pack of Deans 3 pin connectors.
lots of patience!!!!!
The setp draws .130 amps so it should be able to run for 30-35 minutes. Enough for 4-6 flights per charge depending on flight time.
Hopefully I will get to test them out in the daytime tomorrow. Then the night time test next weekend.
Edit: When mounting your packs to the blades be sure the tabs are pointing in to the rotor head and not out to the tips of the blades. Lipo packs have a gel in them that could be forced out if the pack is facing the ends of the blades.
Jon Jennings
mudbogger2 is offline        Reply With Quote
Old 04-14-2007, 11:24 PM   #2
Ace Dude
Nice job! Thanks for posting! How hard was it to solder those LEDs to the copper tape?
Ace Dude is offline        Reply With Quote
Old 04-15-2007, 08:55 AM   #3
mudbogger2
It took a few times to get it right but it was not as hard as I thought it would be.
I just tinned the copper tape. put some flux on the led's and placed them on the copper strips. Heated the solder and they stayed right where I wanted them.
Hardest part is seeing the led's. Those suckers are tiny! I did use a magnifying glass to help out.
Jon Jennings
Old 04-15-2007, 09:08 AM   #4
Ace Dude
Do those LEDs require any resistors?
Old 04-15-2007, 09:13 AM   #5
mudbogger2
Yes they do. Each color needs a resistor. I used this calculator to determine what led will need what resistor. http://led.linear1.org/1led.wiz
Jon Jennings
Old 04-15-2007, 10:30 AM   #6
Wa11banger
HEHE hmm those look awefully familiar.. Where have I seen those before lol
Nice job man, but you can forego the resistors if you can live without red in the mix. The ones seen at Bham, Clintsone, IRCHA SE, IRCHA, Huntsville, and all over TN do not have resisitors.. We wanted as light as possible..
Nice blades
Rick
Proud member of the Quick UK, Duralite Flight Systems, V-Blade, and KBDD Team
Wa11banger is offline        Reply With Quote
Old 04-15-2007, 06:07 PM   #7
Ace Dude
Do you think the adhesive on the copper tape is enough to keep it from lifting off during flight? I wonder if clear heat shrink on the entire blade would help.
Old 04-15-2007, 06:39 PM   #8
mudbogger2
Rick- Thanks for the tip on losing the resistors on the non-red ones. You guys inspired me after seeing Bobby Watts fly some at IRCHA SE.
Hopefully my next set will be even better.
Ace Dude- I am not sure if heat shrink will be needed or not. I did not get to test them out today due to high winds today. I will find out one day this week hopefully.
THe copper tape has a good grip so hopefully it will not be needed.
Jon Jennings
Old 04-15-2007, 08:22 PM   #9
Wa11banger
After 24hrs you wont have any problems with the tape. We have a very huge following with our versions of these blades, Not one set has failed to anything but pounding ground lol.. The copper tape is good
Rick
Old 04-16-2007, 05:42 PM   #10
mudbogger2
I test flew the blades today. They did great. 2000 rpm was no problem for them. Nothing flew off or even moved. Covering the blades will not be needed.
I ran the blades from a full charge for 46 3/4 minutes and put back in 67 mah.
Now I just need to test them at night! :mrgreen:
Jon Jennings
Old 04-18-2007, 02:30 PM   #11
gerard_nl
did a simular job for kicks last year on 50 sized woodys (just to try the concept)
works fine
held up fine @ 1950 rpm and mild 3d stuff.
never found the time to do it on carbons.
gerard_nl is offline        Reply With Quote
Old 04-19-2007, 08:00 AM   #12
Wa11banger
We have many, many sets of these flying right now.. The only thing they wont hold up to is the ground.. I run a set at 1950 no issues. the Trex sets we make are running 2800-3200RPM.. Have no fear the lights and the tape are good.. What you do have to worry about is the tensil strength of your shrink wrap on the blades.. Our very first pair failed because we used the battery pack type shrink wrap and it is not pliable enough. It cracked, we lost a batt in flight, we landed no issue. Cept for the puzzled looks until we found out what happened. SInce then the new stuff we have been using has been working great the whole time.
Rick
Old 04-19-2007, 04:21 PM   #13
mudbogger2
Where do you guys get your shrink wrap from?
Jon Jennings
Old 04-19-2007, 07:37 PM   #14
teeroy
Our LHS. If you are coming to Huntsville I will take you there and get you some.
Troy
teeroy is offline        Reply With Quote
Old 04-20-2007, 02:01 AM   #15
Striker
Sweet! Great job guys
Trex 600 HFE / Trex 450se / Blade CP Pro
Striker is offline        Reply With Quote
Old 04-20-2007, 06:37 AM   #16
Ace Dude
It's a bit hard to tell from the pics, but are those LEDs right on the leading edge of the blade or are they just behind the leading edge? Can you post some real close-ups of the LED installation?
Old 04-20-2007, 08:43 AM   #17
flyinfool
Is it just the shrink wrap that is holding on the battery?
Has anyone tried the copper tape on a nitro ship? Is the adhesive fuel proof?
Jeff Borowski
RAMS Club President
www.ramsrcclub.com
flyinfool is offline        Reply With Quote
Old 04-20-2007, 09:07 AM   #18
Wa11banger
There are many many sets on nitro and electric alike.. So far it hasnt failed.. For how long is anyones guess but our first sets are about a year old and for those that are still surviving are doing fine
Old 04-20-2007, 09:31 AM   #19
DebianDog
Making a sticky and moving to electronics.
Edit: We do not have a electronics or night flying area?!? ummmm
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote
Old 04-20-2007, 11:01 AM   #20
dsduani
What setup do you use to re-charge the single cell lipos?
Thanks for the great DIY info.
And those who were seen dancing were thought to
be insane by those who could not hear the music.
Blade CX2, CP Pro, mQx, mcpx bl, Blade 450, Spektrum DX7
dsduani is offline        Reply With Quote
