Old 05-14-2012, 10:10 AM   #301
TheBum
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
Originally Posted by mastmalang70 View Post
ohh thanks, so ,vf is a forward voltage
i need one with 3.7 volts any link
thanks again
Due to the semiconductor "stew" required for each color, I doubt you will find an LED in a color other than blue that will be able to take a straight 3.7-4.2V.
There's also the issue of the changing battery voltage as it discharges. It will start at 4.2V, so a 3.7V LED would be overloaded at first. It's possible the LED would survive for a while, but that extra voltage and the associated extra current is likely to gradually damage the LED until it fails. With a resistor, the LED can adjust its voltage and current as needed.
HeliFreak Support
Nankin Hobby Field Rep, Compass Support Team
Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX
Experience is something you obtain only after you need it.
TheBum is offline        Reply With Quote
Old 05-14-2012, 10:21 AM   #302
mastmalang70
i saw on the site they also sold resistors ,and in the begining of forum there is a calculator ,only want to know what type of resistor i need ?????? here is the link for different type on the site
thanks
http://www.rapidonline.com/Electroni...-Potentiometer
mastmalang70 is offline        Reply With Quote
Old 05-14-2012, 12:32 PM   #303
TheBum
thanks
You'll undoubtedly want SMD (surface mount) resistors. I used 1206 sized SMDs on my blades because they were available locally at Fry's, but the 0805 ones, which are physically smaller, would work too.
HeliFreak Support
Old 05-14-2012, 12:41 PM   #304
mastmalang70
ok here are my findings please advise
1 , for 2.5 vf and 25ma ,calculator showed 68ohms 1/4w resistor
2 , for 3.8 vf and 25ma ,calculator showed 18ohms 1/4w resistor
for both if i use 4 smd's in parallel and with each smd a resistor
if i wana use different vf smd simply change the resistor ????
Old 05-14-2012, 12:52 PM   #305
TheBum
Those resistor values look correct. The second one should ideally be 16 ohms, but 18 ohms is probably the closest available for sale. I would suggest looking around for a lower Vf blue LED though because when the battery voltage gets close to 3.8V, that LED will dim significantly and finally extinguish. The place where I got mine has blue LEDs with Vfs of 3.1-3.2V. In fact, I'm running those particular blue LEDs on the tops of my blades.
If you're running the same LEDs (color and part number) in parallel, you can treat them like one higher-powered LED and only use one resistor. In that case, you'd keep the voltage the same but multiply the current by the number of parallel LEDs when calculating the resistance. If doing so would unduly complicate the placement of the foil traces, it would be better to use one resistor per LED.
Yes.
HeliFreak Support
Old 05-14-2012, 01:10 PM   #306
mastmalang70
Yes.
Thanks The Bum you are very wisely helpful,one more thing i need to know about resistors,
is carbon resistors are okay instead of using surfadce mount resistors because they come in a package of 5000 pieces ,too much for beginner project
Old 05-14-2012, 03:42 PM   #307
TheBum
You can, but they won't hug the surface of the blade as much. As long as you run them in a chordwise direction, you should be fine. Make sure they're 1/4W or smaller, mainly to keep the physical size at a minimum.
If you shop around, you should be able to find SMD resistors in much smaller quantities. For example, I know you can get them in single quantities at DigiKey. I don't know how much international shipping would be for you though.
HeliFreak Support
Old 05-15-2012, 12:49 PM   #308
mastmalang70
it doesnt worth it ,shipping is way way too much , even from UK on the order of 6 euro i have to pay 30 euro shipping ,only option of DHL i guess
thanks for great help,learn a alot
Old 05-15-2012, 12:51 PM   #309
TheBum
One more thing: I'd recommend that you use a tiny bit of epoxy to adhere the resistors to the blades, since they are significantly larger than an SMD.
HeliFreak Support
Old 06-09-2012, 10:39 PM   #310
TheHeliDude
Do you guys CA the batteries down in addition to using heat shrink. While testing my battery flew out of the heat shrink. Im using the heat shrink kavic posted on this thread from amainhobbies. I'm wondering if I need to just apply the heat shrink better but I'll probably CA it to be safe.
Also, thanks for all the information on here guys. This has been easier than I thought.
Blade Mcpx - Spin 16.3 - all MicroHeli
Blade Mcpx BL, Blade 130X - HP08
Blade 450X - Scorp 2221-6
DJI F450 Naza, Trex 500 DFC
TheHeliDude is offline        Reply With Quote
Old 06-10-2012, 01:15 AM   #311
ChrisH
I use double sided tape underneath my batteries, then shrinkwrap tightly. Never had a problem.
Edge Rotorblades
Thor/Voltz Batteries
450 Pro V-Bar
130X
ChrisH is offline        Reply With Quote
Old 06-10-2012, 12:06 PM   #312
TheBum
Same here.
HeliFreak Support
Old 09-04-2012, 09:40 AM   #313
Jonathan Ott
Here's a spin up of my new DIY blades.
Jon
Chaos 600E -- TRex 500 ESP -- EXI 500 -- mSR
Jonathan Ott is online now        Reply With Quote
Old 09-07-2012, 01:16 PM   #314
badastinner
Jon
Nice!
No changes are permanent but...change is.
badastinner is offline        Reply With Quote
Old 09-09-2012, 11:51 AM   #315
powerstroke01
Oops
Gaui x5,Mcpx, Ncpx, Msr, Dji 450 Clone, TBS Disco FPV rig with NAZA+GPS, Turnigy Talon Tricopter FPV Rig with kk2.0
powerstroke01 is online now        Reply With Quote
Old 10-01-2012, 09:30 AM   #316
Jonathan Ott
I just did these blades last night, and threw a video on YT.
