| Realtime Video and FPV Discussions of receiving video in realtime from the aircraft |
Here is my new fpv video:
http://www.youtube.com/watch?v=MeGOLu0LsS8 I am waiting for my replacement 900Mhz FPV TX, so I used my old 5.8Ghz... Work not too bad but I don't have diversity here and I am not too confident so I remained close from base. Board: Multiwiicopter Warthox V2 Frame: Scarab Quad Motors: Gaui 300XS Scorpion ESC: Turnigy Plush 10A / Gaui 10A (the same sold on different brands) Video: Gopro Hero HD FPV Gear: Hobbywireless 5.8Ghz / 200 mW Gregory T-Rex 450 Sport, FPV Scarab Multiwiicopter
__________________________ T-REX550E / FPV Scarab Multiwiicopter Quad & Y6 |
And now the new video including ESC failure and subsequent crash...
This is the native transmitted video. As I must play with my 5.8Ghz / 200 mW for the moment (waiting for a new 900 mHz TX), I was playing doing range tests with the stock combo from Hobby wireless. Simply one receiver with the stock 2dBi whip antena, no diversity. Stock antenna on the TX as well. I must admit I was quite impressed, I had no table with me so the receiver was not surelevated, on the ground and I got easily 500 meters. I did 8 lipos before this flight but on this one, at the end of the sequence, one ESC died for unknown reason (only 15A on the 4 ESC/motors when it occured). I now hate these Turnigy plush 10A and I consider switching to plush 12 or 18A for more reliability. I was lucky that the crash did not occur when I was at 130 meters high, I was just about to land. The Scarab did well in the crash, protecting the electronics as only one leg broke, nothing else! Gregory T-Rex 450 Sport, FPV Scarab Multiwiicopter
Great videos Gregory this one too up until the crash. I like your music selections they go well with your videos. I'm into the tricopters and quads and so far I've been using the KKboard. Hopefully I can experience fpv myself soon.
Frank I held it in just like you said....from what tree? To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Hirobo Shuttle, srb. Trex 450se V2, GY401, S9257, hs-65mg servos, 430XL Motor, 11v 2100mah, 325 cb Futaba 7cap Tx, RealFlight G-4.5, T-rex 500, 6sKP2600,GY401,9257, HC 3D, mCX,(2) HK 450's, telebee gyro, hxt900 cyclic. |
Good luck, and share your vids when you start fpv...
A small flight test and FPV test of my just completed quad octa frame scarab...
All the Fpv gear neatly fitted between the 2 big plates, easy access to boom holders bolts for easy removal and or repair, nice gopro holder in front, these are the main advantages of this bigger frame. Weight compared to classic scarab. I changed the plush 10A for plush 18A (increase of 40grams), used 20C batteries instead of 40C (gain of 40 grams), 2 big plates and 1 small instead of 4 small plates. Overall it is about 60 grams over the classic scarab. Flight time is the same. 7min30 on a 3S 2200mah Zippy for a total weight of 1.2 Kg. Gregory Gregory T-Rex 450 Sport, FPV Scarab Multiwiicopter
#6 |
Hello,
In this one, I connected my Fpv diversity ground station to my TV in the living room... Take off from the table, exit through the window to do a small Fpv tour in the garden and back in the house. I did 4 packs like that when I came back from the office tonight... Leaving and entering through the window are done in normal piloting, I feel it a little bit too risky, then I turn to the TV to continue in FPV. If you do that, be very careful to 2 potential problems: - when there are interferences in the reception, at once, the tv gave a black screen for one or two seconds... Just like some video glasses not adapted to Fpv can do... I did not panic, but knowing this, I stayed close to the house and I will use the Fpv glasses if I want to go a little big further. - keep in mind that if you use 2.4Ghz like me and you stay in the house, your range is seriously impaired. Here it is: Gregory Gregory T-Rex 450 Sport, FPV Scarab Multiwiicopter
#7 |
This one with my Multiwiicopter Scarab frame QuadOctaKopta which I am proud of...
Gopro HD Fpv in Chateau de Sceaux. The Château de Sceaux is a grand country house in Sceaux, Hauts-de-Seine, not far from Paris, France. Located in a park laid out by André Le Nôtre. The château was built for Jean-Baptiste Colbert, Louis XIV's minister of finance, who purchased the domaine in 1670. The present château, designed to evoke the style of Louis XIII, dates from the Second Empire. Some of Colbert's outbuildings remain, and the bones of the garden layout. Gregory Gregory T-Rex 450 Sport, FPV Scarab Multiwiicopter
#8 |
New FPV in annoter interesting site, in Waterloo, Belgium. The Lion's Mound (la butte du Lion) is build on the Waterloo's battlefield.
#9 |
Hello Guys,
Here is my first video from French Polynesia. I did not expected that the wind would constantly blow at 15 knots with increase to 20-25 knots from time to time. See at 2min30, look at the trees and the angle of the Scarab to prepare for landing, I did wait for the wind to decrease before taking the opportunity to land. Another interesting item is the radio cutoff over the see at around 1min35, all 4 motors cut and the scarab started to fall just before recovering... Big stress! Enjoy, Gregory Gregory T-Rex 450 Sport, FPV Scarab Multiwiicopter
#10 |
Here is the second video from French Polynesia. Tahaa island and the Motu Cerran & Motu Adgé.
#11 |
#12 |
Scarab in the Fog, I am happy to have a reliable Gps on my OSD...
This is a Gopro v1 Gregory Gregory T-Rex 450 Sport, FPV Scarab Multiwiicopter
#13 |
Hello my friends,
I have not posted anything for a while because I was working in preparing something… I did not like my out of range over the sea in French Polynesia, even if it was a happy end. So I married my Scarab with the Thomas Scherrer Long Range System. This is my first try in FPV with the TSLRS and second flight with the Carbonbirds 775 combined with 0905 Tri Props. Gello is gone !!! Regarding the Thomas Scherrer Long Range System, I have the TX V5 Pro and the RX NR 600, both received from Danish Aviation Systems. Steven Friberg there has been very supportive and helpful. The quadricopter is a QuadOcta Scarab with a Whartox. Absolutely no problem in setting-up TSLRS with Multiwiicopter, very straight forward. Gregory Gregory T-Rex 450 Sport 3GX, FPV Scarab Multiwiicopter, FPV Easystar
#14 |
This is the new video.
Cheers, Gregory T-Rex 550 FB FPV : Scarab Multiwiicopter QuadOcta & YSiix
#15 |
Hello,
Here is my first released video made with the YSiix, mixed FPV and LOS images. I release it both on YouTube and Vimeo... I started with Vimeo because I don't like copyright restrictions on YouTube based on the selected music. https://vimeo.com/39758749 For those who like to follow multicopterpilot.com channel on Vimeo, here is the link: https://vimeo.com/channels/293032 Cheers, Gregory Gregory T-Rex 550 FB FPV : Scarab Multiwiicopter QuadOcta & YSiix
#16 |
Dear all,
This is the last video I made with my Scarab QuadOcta during my vacation in Brittany. Sorry for the small gello, I did not have with me the equipment to perfectly equilibrate my props: https://vimeo.com/40649707 Enjoy, Gregory T-Rex 550 FB FPV : Scarab Multiwiicopter QuadOcta & YSiix
#17 |
Hello,
Bordeaux wine Smith Haut Lafitte is one of the big ones. Robert Parker gave it the highest score of 100 in 2009 (the last released). Attached to the castle is the 5 star hotel and spa “Les sources de Caudalie”. Both belong to the Cathiard couple, French Ski champions in the 1960’s. The Scarab FPV Reconn found it’s alter ego… Please enjoy: https://vimeo.com/43745851 Gregory
#18 |
Hello,
This is my new one, in Iguaçu falls. The little Scarab Reconn flew from Brasil to Argentina and came back safely... https://vimeo.com/44873371 Enjoy Gregory T-Rex 550 FB FPV : Scarab Multiwiicopter QuadOcta & YSiix
#19 |
Hello guys,
Here is the new release from my vacation in Sologne, France: https://vimeo.com/channels/multicopterpilot/47272340 It was 80 % filmed with the Multiwiicopter Scarab YSiix and 20% with the Scarab QuadOcta as Quad. Gregory T-Rex 550 FB FPV : Scarab Multiwiicopter QuadOcta & YSiix
#20 |
Hello,
Here is the new video, BMW Z3 vs Volkswagen EOS, filmed with Scarab YSiix and Gopro HD2: https://vimeo.com/47401520 Gregory T-Rex 550 FB FPV : Scarab Multiwiicopter QuadOcta & YSiix
