Old 12-09-2012, 07:34 PM   #81
Gregor99
When done properly, the case of both supplies shares the same ground as the AC as well as the charger's ground. The supplies come with the case grounded on both the AC and DC sides. To run them in series the ground on the second supply must be disabled (side that provides the 24v positive). What you are describing sounds normal.
P.S unfortunatly i have no Ground in my AC socket
Probably shouldn't be using that socket then. Time to upgrade your house wiring and not just for your charger's sake
Greg
______________________________________________
Synergy E7 - Compass 600e - T500 - Trex Pro - mCPX
Gregor99 is offline        Reply With Quote
Old 12-09-2012, 07:47 PM   #82
martingru
Im using only one PSU (12v)... but i see only way is changing my wireing ,unfortunately its impossible .
Thank you for answers ,I'm appreciated .
Regards Martin
Sent from my GT-I9000 using Tapatalk 2
LOGO 600 SE Vbar5.3Pro -700 mm
LOGO 500 SE Beast X -600mm
MCPX BL
martingru is offline        Reply With Quote
