Old 09-16-2011, 10:48 AM   #1
nuclear_heli
Default Trex 450 pro Tail servo
Hello
I was thinking of upgrading my tail servo to an MKS servo and was wondering why everyone is picking the MKs ds-95i instead of the MKS DS8910A+
The DS8910A+ is 15$ cheaper, 0.002 ms slower, has 0.2kg more torque and weights 7 grams more, is all plastic body compared to alu for the ds-95i
thanks for the help
nuclear_heli is offline        Reply With Quote
Old 09-16-2011, 11:16 AM   #2
Spork01
Fear the Spork!!
The ds95i is lighter , faster, Has aluminum case for better heat dissipation . plus it's sexier
Oxy3+ , XK K110 and XK K120
Spork01 is offline        Reply With Quote
Old 09-16-2011, 01:02 PM   #3
akamullen
I have the DS95's on cyclic and the ds95i on the tail. It fly's simply amazing. Best setup I have ever flown hands down on a 450. The tail is crazy solid for a 450 as well. I also use EDGE tail blades, EDGE tails also help with blowouts in hard maneuvers as they have a little more surface area, they are also carbon, so much stiffer than stock plastics.
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN 380/500-x2/630/770 * Swinging SWITCH/RJX/RAIL & SAB Blades * Microbeast/IKON * Castle ESC's on all * DX18 *
akamullen is offline        Reply With Quote
Old 09-17-2011, 09:39 PM   #4
cormier33
Originally Posted by nuclear_heli View Post
Hello
thanks for the help
You bring up a good point. I was told to go for the DS8910A+ because it fits in the stock servo location without any modifications. That's the route I went.
Align T-Rex 450 Pro
Eflite Blade mCX
Spektrum DX7
cormier33 is offline        Reply With Quote
Old 09-17-2011, 10:45 PM   #5
ddhuans
+1 for MKS 8910A+
ddhuans is offline        Reply With Quote
