Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 03-14-2013, 06:20 PM   #81
dsduani
Something else I did as soon as it came out of the box: measured and recorded the lengths of all pushrods/linkages
More than once it helped me get back to point zero after my "adjustments" really screwed things up!
Fighting keraunothnetophobia one flight at a time.
Blade 450 flybarred, Protos 500 stretch, BD3SX, Spektrum DX8.
dsduani is offline        Reply With Quote
Old 03-14-2013, 06:38 PM   #82
curmudgeon
I too recorded the link lengths on the original B450 3D and later on the B450X. However, I did not find this as helpful since the swash was not leveled out of the box. I use the Blade BLH1690A swash leveling tool to get the swash at the appropriate height, and then finish off leveling the swash with the Trueblood tripod leveler.
Synergy 806 & E5s/Logo 700 & 550SX V2/Goblin 700 KSE, G380 KSE, G380; Kontronik ESCs; Spirit Pros; MKS/Futaba/XPERT/BK servos; KDE/Xnova/Kontronik/Scorpion motors
Sims on Mac:
neXt/RF7.5/Phoenix 5/RC7
Jeti DS-16C
& DX8 Gen 2, Citizen 259
curmudgeon is offline        Reply With Quote
Old 03-14-2013, 10:16 PM   #83
dsduani
I agree, the Trueblood swash leveler is a great tool
Old 04-30-2013, 08:26 PM   #84
Sickworm
Default Carbon Fiber tail boom Stab
there is a difference from the plastic to the carbon piece on the bottom. The plastic piece has a nice little Curve on the bottom that makes a snug fit
anyone else have this problem and how to fix it
tom
Sickworm is offline        Reply With Quote
Old 04-30-2013, 09:35 PM   #85
Thalios
CF one is designed to go with the aluminum upgrade parts.
Thalios is offline        Reply With Quote
Old 04-30-2013, 11:42 PM   #86
Sickworm
I solved the problem ... but you are right..
so if you don't want to use the Aluminum part which is....
Aluminum Horizontal Stab Fin Mount: B450 [BLH1662A]
then take a piece of RC Fuel tube and put it between the CF Fin and the tail boom and it works perfect
Old 11-26-2013, 01:14 AM   #87
Stretton
Question 450 3D Main gear not engaging all the time
My Main gear is not engaging all the time sometimes it does, other times it doesn't. Not shore what is happening.
Changed out the main gear, changed out the non return bearing, changed out the main shaft. Does anyone have this issue and does anyone have some advise?
Stretton is offline        Reply With Quote
Old 11-26-2013, 07:11 AM   #88
Gladius
Sounds like your motor mount is loose.
<> Trex 600 ESP FBL, Trex 500 ESP FBL, Gaui X3 <>
<> Builds in progress: Logo 600SX, KDS Chase 360 <>
*Spartan Vortex VX1e*
Gladius is offline        Reply With Quote
Old 02-27-2014, 12:45 AM   #89
D Aug
Default seesaw help
Hello, and thanks for the bible. I wanted to know if I had to take bearing out when just changing out the plastic seesaw for the aluminum with no crash damage. D Aug
D Aug is offline        Reply With Quote
Old 02-27-2014, 09:59 AM   #90
LubeMan1
+1 I used a small piece of double sided stick tape and that worked well also..
Compass Chronos & 6HV,5003D,NanoCPX,CFX180
DX9,Phoenix 5
Team Flybar & "Less" now
LubeMan1 is offline        Reply With Quote
Old 03-04-2014, 10:13 PM   #91
cpmboy
Can we use the BLH1690A with the head on?.....
All begins (Jun 2011).......
Next project:
MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad
cpmboy is offline        Reply With Quote
Old 03-05-2014, 10:56 AM   #92
LubeMan1
Yes..That's what it's made for, the swash dimples fit into the recesses on the leveler
DX9,Phoenix 5
Old 03-29-2014, 05:10 PM   #93
Hcasa
Question Blade 450 3D BNF with DX6i - Set up Help Needed
Guys, just purchased a used 450 3D. I bound it to my DX6i and the right stick controls are note functioning properly. Can anyone provide guidance on the base settings to achieve proper left and right stick function?
Hcasa is offline        Reply With Quote
Old 03-30-2014, 08:33 AM   #94
Gladius
Can you describe exactly what your right stick is doing? Which slot did you bind your 450 to? Pretty much all DX6i's come with pre-programmed setups for the 450 in slots 9 (intermediate) and 10 (advanced). Did you use one of those, or did you start a new profile from scratch?
Old 04-27-2014, 04:50 PM   #95
NuCOTech
Default Blade 450 bible by Thalios
If you started as a new model chances are you have your mixing set to one servo instead of ccpm 120*
NuCOTech is offline        Reply With Quote
Old 07-11-2014, 05:29 PM   #96
gixerfien
hey thalios and other, plenty of thx for this bible, had the 450 3d since it came out.
Just wondering if you've tried or are planning on trying any of the newer upgrades for this machine.
Like the carbon fiber frames that lynx and microheli make, and the strech kit lynx makes.
I'm interesting in finding some reviews on some of the newer upgrades offered.
DX9-Realflight 7
Align 250 pro DFC, Blade 450x with every blade hopup/lynx upgrades, Align 500L Dominator
gixerfien is offline        Reply With Quote
Tags
blade 450, blade 450 rebuild, blade 450 repair, blade 450 setup
