Old 10-02-2011, 04:53 PM   #1
GlobalHawk
Default Near death experience!!
So I finally was able to get out and maiden my 700E and test out the scorpion 130HV. However, 3 minutes into my flight the heli just starts to piro like crazy & will not respond to ANY tail inputs. So I do the only thing I can do at this point, hit TH with heli about 75ft in the air. HOLY SH!T this heli autos like you wouldn't believe!!! I was able to safely auto the heli down without a scratch. This thing floats like a piece of paper in the wind! Ok so it wasn't an "actual" near death experience, but if I would have destroyed this heli I would have died! . It seems that the tail rotor grip came completely off the tail drive shaft while flying. Never seen that one before!
That wasn't a crash....It was an acrobatic landing!
AMA# 927891
Trex 550E 12s Stretch BeastX, Trex 700E BeastX
GlobalHawk is offline        Reply With Quote
Old 10-02-2011, 05:25 PM   #2
MajorPayne
Was this the v1 or v2 tail (black or silver grips)? Did the spindle bolt fail? Pics???
Glad you were able to save it!
T-REX 700E VBAR
T-REX 450 PRO BEASTX
MajorPayne is offline        Reply With Quote
Old 10-02-2011, 05:58 PM   #3
GlobalHawk
It's actually a quik uk tail. The set screw just backed out. Stayed on the heli just came off the shaft.
AMA# 927891
Old 10-02-2011, 06:30 PM   #4
aramb
Congrats on saving the heli!!!
Trex 800e, Goblin 770, Trex 600n
Futaba 14SG / AMA# 959345 / IRCHA #3954
Team HeliDirect
aramb is offline        Reply With Quote
Old 10-02-2011, 06:56 PM   #5
kouasupra
Great save!
kouasupra is offline        Reply With Quote
Old 10-02-2011, 08:46 PM   #6
dchekas
Use green loctite on the tail shaft, then slide on the tail hub, and green loctite the set screw into the hub.
dchekas is offline        Reply With Quote
Old 10-02-2011, 09:05 PM   #7
f22warzone
agreed green loctight on the shaft to hub assembly but still only blue on the set screw, so that way you can remove it some day with heat.
TRex-800E /Scorp 5035-478 5+5YY 1.8mm/VBar Blue Full 5.2Pro /CC Hv160/WR-Herc Super BEC/RJX 810mm 3D /RotoTech 115 + QuickUk Tail/ Hitec 7940th HV/TP 5000 65c
f22warzone is offline        Reply With Quote
Old 10-02-2011, 10:51 PM   #8
GlobalHawk
Green loctite requires heat to remove?
AMA# 927891
Old 10-02-2011, 10:52 PM   #9
GlobalHawk
Thx everybody, but the fact that the 700e autos so well made my job that much easier.
AMA# 927891
Old 10-02-2011, 10:54 PM   #10
Inverse
Yep, soldering iron for a few seconds and you're sweet.
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote
Old 10-03-2011, 05:11 PM   #11
NRPY
Glad to hear you saved it. I need to finish building mine. Ran out of motivation a few months back.
NRPY is offline        Reply With Quote
Old 10-03-2011, 09:59 PM   #12
dchekas
The MA green Superlock does not require heat, just a good hex driver.
It's definitely stronger then the loctite 243 I normally use, but it's no where near as bad as loctite 262 or 266 was.
I've got 120+ flights and counting on my 700, no tail hub ejections yet. Thanks to Smacktalk RC for the tip!
Old 10-04-2011, 08:21 AM   #13
WBFAir
Yeah, as you have experienced, the tail coming free from the hub is a pretty bad thing.
All in all I know many think about not locking that part in with retaining (green locktite) compound as you think, well I might have to get it off someday.
But one, you really can service most of the tail as the way they make the tail assembly to come apart these day, and two, outside of a crash, you really don't take it apart all that much, and three just as others have said, even with that stuff, you can still get it apart it you have too.
So my thought always is to do all that you can to secure that part to that shaft in every best way possible.
WBFAir is offline        Reply With Quote
Old 10-04-2011, 11:26 AM   #14
GlobalHawk
All in all I know many think about not locking that part in with retaining (green locktite) compound as you thinl, well I might have to get it off someday.
I never had that experience until it happened. Loctiting the grips to the shaft NEVER crossed my mind. Have to give it serious consideration now!
Sent from my Samsung Galaxy S II using TapaTalk
AMA# 927891
Old 10-04-2011, 11:41 AM   #15
WBFAir
Yeah I never had it come free from my 450 and I don't green loctite that one, but I have seen others with 450's who just don't really even locktite even the grub screw and/or pay the whole thing much mind at all and seen them loose that connection many times in a row and still never get it to secure it better.
Anyway, the 700 though is a whole nother animal so you have a lot more forces.
Actually come to think of it, I think I might have just put some of the blue locktite on mine but I also used the QuickUK tail on mine so that has the two grub screws, but I also used a good amount of that too on those screws as well.
Also a nice cleaning of the parts that will be meeting, including the grub screws and their holes with acetone or some other really good oil remover product, is a thing I do for all locktite connections I make. And as well do the same and do a little chasing of the threads of either for old connections if I ever remove them.
Seems like a lot of work I know but in the four years I have been putting these things together, I never once had anything ever come apart.
Old 10-04-2011, 11:47 AM   #16
Dino Spadaccini
Funny to see how fast some one was to jump on if it was an Align part.
Funny how its ok for the grub screw to come loose in the UK part and everyone is staying to lock tite it to the shaft. First and foremost i am glad your heli made it out in piece. blue lock tite on the grub screw and set it with firm pressure then after the first flight check it and you should be fine
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote
Old 10-04-2011, 03:29 PM   #17
MajorPayne
I guess that someone your referring to would be me. And yes, after the failures of the align v1 tail and my recent purchase of an align v2 tail, I was very curious to know if there was a problem with it since I haven't tried it yet. Hope that's ok with you.
T-REX 700E VBAR
Old 10-04-2011, 03:50 PM   #18
Dino Spadaccini
No problem
Old 10-04-2011, 05:16 PM   #19
Mystic3D
Just a tip on the quick UK tail.
When I ran it some play developed between the shaft and hub.
I ended up putting retaining compound on it to take out the play.
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote
