Go Back   HeliFreak > R/C Helicopter Support > 500 Class Electric Helicopters > 500 Pro Class Electric Helicopters
500 Pro Class Electric Helicopters 500 Pro Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 10-02-2011, 07:57 PM   #1
Helisun
Default T-Rex 500EFL Pro Battery Compatibility List
Many websites list specs for T-Rex 500EFL Pro as such:
Radio transmitter and electronic equipment required for assembly:
Transmitter(7-channel or more, helicopter system)
Receiver(7-channel or more)
6S Li-Po 4500 ~ 5200mAh X2
Dial Pitch Gauge
Those are some big batteries! and you need 2, really??
I see a couple of threads regarding batteries for the 500EFL Pro. So to clean things up, can we start a thread just on the batteries compatible for 500EFL Pro? There is a battery list for the 600EFL Pro on that forum, which is really helpful.
I'm looking at these 3, please let me know if these are ok. Thanks.
GENS ACE 2600mah 6S1P 22.2V 25C Lipo battery pack
http://www.hobbypartz.com/98p-25c-2600-6s1p.html
Voltz 2600mAh 6S 22.2V 35C Lipo Pack
http://www.readyheli.com/VT260035C6S...k_p_37130.html
Align 6S1P 22.2V 2600mAh/25C/A Battery
http://helidirect.com/align-6s1p-222...500-p-7060.hdx
Probably won't go with Align battery, they cost 2X as much.
Helisun is offline        Reply With Quote
Old 10-02-2011, 11:22 PM   #2
smaze17
I highly recommend the Gens Ace packs. I use them in every single aircraft I own. This includes ducted fan jets. They perform very well plus they are a great value!
S
Trex 700e DFC / iKON / CC ICE2 120HV / Align 700MX
Trex 450L Dominator / iKON / RCE-BL45X / 460MX
smaze17 is offline        Reply With Quote
Old 10-02-2011, 11:45 PM   #3
electrodude71
at least 35c or above
hello my name is frank, and I'm an r/c addict
electrodude71 is offline        Reply With Quote
Old 10-03-2011, 07:39 AM   #4
rotaryguy
The Gens Ace packs are great. Better than the very expensive 35c Hyperion packs I used to waste my money on IMO.
C rating has become a marketing tool in some cases and seems blown up to sell and others will use true numbers.
Do some research and you will find the Gens name popping up all over. And yes the 25c variety.
rotaryguy is offline        Reply With Quote
Old 10-03-2011, 07:43 AM   #5
Shawn Behrens
The gens ace 3s 2200 25c is the same as the 55c only the 55c has a larger guage wire.
shawn
Shawn Behrens is offline        Reply With Quote
Old 10-03-2011, 09:13 PM   #6
Helisun
Found this PULSE 6S 22.2V 2600mAh 45C - XTREME POWER SERIES
http://helidirect.com/pulse-6s-222v-...00-p-24100.hdx
Price is reasonable, and it's got 45C.
Thunder Power G4 Pro Power 2650mAh 6-Cell/6S 22.2V also got 45C, but they are as expensive as Align batteries.
http://helidirect.com/thunder-power-...00-p-16405.hdx
Now I just gotta wait until the next holiday discount code.
Old 10-03-2011, 09:29 PM   #7
rotaryguy
Get the $45 Gens Ace 2600's - you will be very surpised. I too was hesitant until I ran the 25C Gens packs in my 700e - VERY impressive. In this case you get way more than you pay for.
Old 10-04-2011, 03:13 PM   #8
smaze17
Yes. agree with rotaryguy. The Gens Ace packs are very impressive in every way. Do NOT let the fact that they are 25C scare you away. These have become my favorite packs for everything I fly
S
Old 10-04-2011, 04:46 PM   #9
davehour
S
I'm using one of the 2600's 25C in my 500 and it has a lot of pop.
David
T-Rex 700E Pro DFC, Spirit FBL Unit, Futaba R6303SB/8FGHS
Blade mCPx 140mm boom, DX7
RealFlight 7
davehour is offline        Reply With Quote
Old 10-04-2011, 10:58 PM   #10
invertsick
im using pulse 3000 35C in mine and i really like them,
I'm even thinking to get 3300 packs if i know they will fit under the canopy.
invertsick is offline        Reply With Quote
Old 10-08-2011, 01:11 PM   #11
syn90
So for those of you that are using the 2600 packs, can you get at least 5 minutes with the stock drivetrain and headspeed governed at around 3000-3100 RPM? If so, how many milliamps are you putting back into the pack after? If you aren't getting 5 min, how long are you getting and how much are you putting back into the pack?
Thanks in advance!!
syn90 is offline        Reply With Quote
Old 10-08-2011, 02:26 PM   #12
BigIreland
Thanks in advance!!
Syn, I highly doubt it. I run Voltz 2600mah 45c's on my older V-Barred 500ESP and it's a monster at 2600-2700rpm headspeed. I get a little over 4 minutes doing medium-hard 3D. I don't think 3000rpm is necessary. Still you really might want to go that high. Try 2500rpm first and work your way up in 100rpm increments. I think you'll find happiness well short of 3krpm. Hope this helps.
BigIreland is offline        Reply With Quote
Tags
battery, efl pro, t-rex 500
