| Gasser Helicopters Gasser Specific Discussion |
#21 |
In fact I would like to have a muffler that's got a header that doesn't get loose enough to leak, and if century would make one like that I'd be delighted, You must have tried the zimmerman muffler in the past, and you know what I mean. There is no song and dance with that one. You don't have to face the motor or face the header, you don't have to tighten while hot, you don't have to glue it down with goop. You just put it on and go fly, and it stays on and your motor side stays clean until you pull it off. I really like that as I hate a mess myself, hence part of the reason why I went to gassers and away from nitros, even with free nitro fuel I'd still want to fly a gasser, because I hate the cleaning you have to do afterwards with nitro birds. And no doubt that the v5 muffler makes very good power, I know the torpedo did and I posted that in my muffler test thread. I would just like it modified just a bit so anyone can bolt it on in any kind of ship and have it seal until taken off.
Its not about me or my flights or helping others, its about asking for a better product, or an update to a product to improve it. If I don't ask, then how will it ever come about? Its feedback that counts. -=>Raja.
1005 Xcell Autorotation Queen, Hanson G26 3D Max, 3333 flights Spectra-g, Hanson 270 3D Max, 2200 flights Whiplash-g 88.9mph Speed Cup Record, Hanson 270 3D Max, 276 flights Jewel on-board Generators, Team Miniature Aircraft, Team Helicommand |
#22 |
I thought I may aswell post up aswell, Torpedo V2 on my G30 mounted with the zenoah gasket no setscrews no loctite, never had a single leak in over a year, never had to re-torque the bolts, and even on my vairo the muffler is the only engine related part not to give trouble in over 2 years.
T-REX 250 FBL, T-REX 500, Bergen 44 Magnum, Vario Benzin Trainer FBL, Radikal G30 FBL, MCPX |
#23 |
Hey, I just went to order a V5, and incidentally I noticed that the Predator line is gone? No biggie, I run a G30, but does that suggest that another 810mm machine is coming to fruition, or a big G30, etc?
By the way, on mufflers: I ran a Zimmerman pipe for years in AP, recently developed longitudinal cracks from the base, that is why I am trying a V5. The V5 sounds like a good piece, but I am concerned with the extra weight, weight can mean more mechanical advantage against the mounting. Having not felt the mass centering of it yet I cannot comment fully, but we shall see, looking forward to it. Also, how long is the V5 from mounting bolts to front end? I have to clear a camera mount with the thing. |
#24 |
Lets put this in perspective. Raja is a rep for MInair/Team Heliwholesaler/Zimmerman/Hanson (or was) and who knows else. Raja will spend an entire day on forums searching out anything good that someone said about about either a century product or product that competes with one of his sponsors and then make a negative comment about that product. I guess it is safe to assume raja thinks that is what his sponsors want him to do. I doubt this since above companies dont approve of competitor bashing, at least I hope not.
As a century rep, you wont find me bashing competitors. One, this isnt something century would want or ask me to do. Century asks me to help as many people as I can (whether century flyer or not), fly their products and ask me to give feedback on all their products. Two, I have a whole lot better things to do with my life then spend a whole day on forums looking to bash competitors. So here we are, there was a good thread going about century's latest offering in gas mufflers and raja couldnt stand it any longer so had to crap on it. So here is my question to you Raja. You obviously really enjoy flying your gassers which is the reason I would hope all of us are into this hobby. Why cant you just enjoy flying and feel free to promote the products you support and THATS IT? I challenge you to go just one week without the bs, just one week!! Maybe, just maybe, you will find that it is just as enjoyable to just talk about positive things and leaving the bs. Just a suggestion Z |
#25 |
fallafalla, like you I run the same way... I use a lock-washer, and a steel flat washer against the muffler with no locktite...
After a couple tightening sessions while hot, the Zenoah gasket reaches its max compression, and seals like it should.. On the Predator, it was another story unless you were using a smooth 231..With the Radikal and the big drive train, its much much better, even with a smooth big block.... Eric, your guess is correct...Some mind blowing machines headed this way |
#26 |
I fly with V5 for 2 months. I just used the stock Zenoah gasket with a little amount of black sealing gel (don't know what it called exactly). Never tighten while its hot. No leak at all.
BTW I used green loctite on the bolts.
Trex 700 Gasser FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX270TT | SG | RJX Gas muffler | JR x9503 Trex 600 Gasser FBL | HeliBug HB6-RC7 20T | Brain | GV-1 | Stock Zenoah G290RC | RJX pipe | JR x9503 |
#27 |
"Eric, your guess is correct...Some mind blowing machines headed this way Nitro, electric and a new Radikal Condor .. Your going to say: Century made this? "
Cool Bill, glad to hear. Just interested in gassers, and well, the current 720mm build carries the 7d so well that I'll stay with short blades for now, but I'll watch and see what they can make. They are in a good position to make an affordable, low powered turbine if they wanted to. I'd consider a Wren W44 machine, running heavy, with a lot of fuel on board; little power source, long smooth runtime, just a thought... Regarding muffler bolts. I always use automotive black RTV as a threadlock; I am no chemist, but I think that all but perhaps some specialized versions of loctite will turn fluid with the heat. I concede, RTV is a weak threadlock, but it is a lock to 700 deg F. That is the key part to it. I also run the RTV on the gaskets, flanges, etc in a very thin layer. And I agree that loose mufflers are often a symptom of untamed vibration. |
#28 |
The one on the table has been on my spectra g with a 29cc engine for over two month with no leaks( i did not buy it new ).The other one is on a helibug 600 with a 29cc engine for two weeks and no leaks( i did buy it new ).I wouldn't say they look like new,a few scratches,dings and dents but they look good, no leaks.I have not done anything special.Use a new gasket,tighten the bolts and go fly.
#29 |
Hey, on the V5 how long is it from the mounting bolts to the front end?
Thanks. |
#30 |
maybe this will help Eric
#31 |
Carey Shurley To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#32 |
Thanks Bill and Carey.
2 quick ABS cuts and it will clear the camera. |
#33 |
Well I have run the new G5 Torpedo muffler. It is as quiet as any Zimmerman, and kind of deep in tone. I do not care about tone, and power, just as long as it is quiet enough! Running the 9mm reducer and at 11,200, seems good
So although noise perceptions may be logarithmic, not linear, we can use laymans' terms to say that a can muffler has a "loudness" of 10, a torpedo V2 is a 6 and this thing or a Zimmerman is a 3. |
#34 |
First picture is of the zimmerman on my Spectra-g. I just used some red rtv on a used gasket and bolted it up after I removed my Hatori that was on there before. Haven't done anything since, just flying it.
Second two pictures are of a Spectra-g with a torpedo running on a toxic 231. I used some red rtv on a new gasket and bolted it up. Retighten the screws while hot but its leaking after several flights. The screws don't come loose enough for the muffler to fall off per say, but they are loose enough for it to spring it leak it seems. Just came home from flying today and looks like it blew out. So how should I fix it? Face it, goop it, retighten it? Gasket, no gasket, would like to get a seal that stays, I have another new gasket here if need be and will try it again, just let me know and thanks. -=>Raja.
#35 |
High temp black RTV.
#36 |
Raja,
I don't have a V5 but I fought sealing my V4 until I started using these gaskets from Dave's Discount Motors : Super Heavy Duty Steel Reinforced graphite Exhaust Gasket: FD227 -$4.50. I installed the pipe with just the gasket, simply loctiteing the bolts with Red loctite. Kept my V4 sealed and I have 84 flights on my Century Torpedo on my 700G and it is completely dry, shiny and clean using just the same gasket. Hope this helps.
doug |
#37 |
Now that's some great information!!
I need to try something different because obviously the procedure that works for me on the zimmerman does not work on the aluminum pipes. -=>Raja. EDIT: Just looked it up, shows a price of $2.25, you got the right part number right? Just want to be sure. Also what else did you buy from Daves before, I remember you mentioning something but I forgot what. If I'm going to order I might was well pickup a couple of things there.
#38 |
After fixing my motor last week my V5 kept getting loose! I would have to auto in every 5 minutes to check the tightness!
So this week I took the pipe off and put some black RTV with a new copper gasket that they sell at Daves Discount Motors! ( It's solid copper) and then I tighten the bolts a little to tight and I stripped the threads on the head.. ![]() Well since it's a Hanson motor so I wanted to fixed the threads instead of buying a new head! I installed new thread inserts in both holes so it should be stronger than before! I'm going out in a few hours to try the new copper gasket with the RTV! I hope it holds........ |
#39 |
I did try a copper gasket in the past as well not much luck with that, even tried it sandwiched between two stock gaskets but give it a try and good luck.
Seems to me the gasket Doug uses is a winner, I have not tried that myself yet. Yes helicoil stuff works really well, I also once stripped threads on one of my G26 motors when I used to own the v3 muffler from retightening it too much. The helicoils will never strip and are much stronger. -=>Raja.
#40 |
