| Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
#61 | |||
For example, I have had my TRex 450 for many years now set up to be very stable while I was really looking to hone my basics. I kept the Flybar weighs on, I used only wooden blades and used a good amount of D/R in the Tx. I kept my HS fairly low and all stuff like that and all in all, I could almost hover it hands off. And that was with a FB helo. But this year as I was fairly secure in my flying, toward the end of the summer I was trying more 3D stuff and I know it had a lot to do with me, but my 450 the way it was, just was not the same as I saw other people's helos flying. So I got rid of all the D/R and even increase my swash mix up a good amount. I put on top of the line CF blades and took off the FB weights and am running the HS up to the highest amount and its like a completely different helo now in that for sure, it will flip in a second (heck have even done it where I didn't even know I wasn't in idle up) but also for sure I cannot hover it hands off any more and I practically have to go through one or two packs of trimming depending on the field conditions that day to get it tuned to what's going on there just so I can get to be as stable as I can for that day. And this variation is all on the exact same model of helo. So my point is, it's usually a trade off, you want performance, you get less stability, you want stability, you get less performance. So depending on what you are going to want would probably be a good thing to think about in getting this helo. |
#62 |
@finless
Thank you for sending out an update. Just to know that you have been busy is understandable. I mean, I know your doing this on your own time! Also, I hope your Dad has a quick recovery.
there are 10 kinds of people in the world. Those that understand binary numbers, and those that don't. |
#63 |
"I don't know as mine is still in the mail, but with the 6 & 8, in the programing, can't you remap any switched action to any switch in there?
You can map some but not all and not the TH. Can you direct me where i might be able to get this M120 850 battery? thanks |
#64 | |
So just for clarification, on the 8, these switches are natively reversed and you can't remap them both to the normally seen, "idle up on the left / TH on the right" way? As far as the packs, just one thing to note, I have only read this so please check this out a bit before you buy, but WowHobbies looks like they have them in stock: http://www.wowhobbies.com/hm-4g3-z-0...2-1-1-1-1.aspx as well as several other packs for the M120 if you check out its parts page that might fit. For the most part if the M120 stock one fits, I would suspect that any other non-Walkera packs would work if made for the M120 as well. |
#65 |
Hey Finless! Thank you for everything you do for us. I hope your Dad is feeling better, and have a Merry Christmas!
#66 |
Team Taco VP
Odd the Devo 6 allowed you to remap the 2 switches no problem. You sure you cant on the 8? I was under the impression the software on the 6, 8, and 12 are the same just added features above the 6. See my vid on where I swapped the switches in the menus and let me know if that is not an option on the 8.
On my devo7 it is not an option and I will be moving them by taking it apart and soldering. Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#67 |
you can only remap a couple of the switches on the Devo 8, just as if it were a Devo 6..
Flight mode can only be switched to mix switch Throttle hold can be switched to FMOD, MIX SW, ELEV D/R, AILE D/R, RUDD D/R, or Gear SW. ELEV, GEAR, AILE, and RUDDER (1 way switches) cannot be remapped to anything. |
#68 | |
Haven't crashed it yet to see if it helps out on the main shaft. But I think I should have the same chance as a V120D02 S version, since it has a metal shaft that looks identical. CF blade weighed 4.6 grams, and the plastic came in at 4.4 grams. Man... I ordered some more stuff from that online shop on Dec 2nd. They send me an email on the 12th stating they don't have the 4F200 blades now. And I was thinking... now? On the 12th, when I place my order on the 2nd? Still hasn't shipped yet. Not so sure if I want to order anything from that sight, since they allow the order when they actually don't have it. But... that was my update.
Erazor 450 (2801 rx) 2750kv | EXI 450 Pro (2702V rx) FBL Tri-Blade head 3500kv AKE | V450 Walkera (2702V rx) 3950kv Turbo ACE 804 | 4F200 & 4F200LM | V200DQ02 & V200D02 | V120D02 & V120D05 | 250 CopterX | 250 EXI FBL | Genius - WK2801 |
#69 |
Whelp... scratch that. My V120D05 had a crash.. and the main shaft was bent, using the plastic D02 main blades. Unless it's the plastic head that may help, I think the only real way to avoid a bent main shaft is to have a non metal main shaft... like the Genius heli.
#70 |
Wow, your the first person I have herd that bent a main shaft.
I'm not sure who the guy is but I have seen one poster over at the RCG thread who was talking about making up some of what he describes as unbendable metal shafts. From reading his stuff and others, I gather he has been making these for some of the other Walkera helos that were more prone to having shafts bend and they worked pretty much as he described. Again off hand I don't know who he is but I just remember him asking if anyone wanted the same for the 02S's and he would make them, but I never saw much talk about it after that as no one seems to be bending them. |
#71 | |
I should mention, that I did bend those shafts before, and bent them back so I don't have massive vibration out of them. And I don't see what the difference would be, as far as the main shaft being better on the D02 S version. The only other difference, the S version uses a plastic head, while both my D02 and D05 are metal.
#72 |
Yeah I'm not really sure myself either as one, I don't have any past Walkeras to look at, and Bah Humbugg but my 02S seems to be parked in the NYC customs depot and looking like I won't get it till after the holidays.
But from what I've read and I don't know for sure, but is the 02S's main shaft a little bigger? At any rate, as I mentioned, I have been following the thread on RCG for this helo and guys have been plowing this thing full force into trees, and complete crashes into the ground into cement, and I haven't read any reports that I can recall of main shafts being bent. But if its one thing I can say from downing my 450 is that every crash it diff and there is always something new that breaks or gets bent on every crash. |
#73 |
Well then... I might buy a S version main shaft to compare to the older one.
Not much of a price difference from Wowhobbies website. The S version is $4.25 (includes collar) while the reg D02 is $3.95 (does not have collar), D05 shaft is $5.25 (includes collar). And the so called "Stay-True upgrade Main Shaft" is a whopping $23.95. So... I'm just putting 1+1 together. ![]()
#74 | |
Well hope the S version is of some better use for you. Again, don't know this stuff by having it in my hands, but I do recall in looking at the diff's of the main gear, that in looking at the pics, it looked like the ID of the shaft hole in the gear was noticeably bigger then then whole in the gear of the regular 02 or the M120's gear. Actually one of the things I do already have is a spare 02S main gear and I just checked that and it seems to be about a 2.45mm ID, if that is of any help to you. |
#75 | |
I'd actually would have to have the main shaft to really compare.
#76 |
Yeah I'm not really sure in this but I think I remember seeing that the 02S's shaft is 2.5m while the 02's was 2.
Hard to believe that .5m would make that much dif so perhaps the metal is dif too, but again, not seeing reports so far that it's bending much. But then again, I haven't gotten my hands on mine yet so that very well could something that completely changes. |
#77 | |
The stay true at Wow are made by Procrasher on RCG. They are well worth the price because they are almost unbendable. I haven't bent mine, and it's been through a lot of crashes. This is with my D02. He will be making shafts for the D02S which he says are not going to bend. These are Photos of my Xtreme V120D02/S. It's a blast regards, JLB01 |
#78 | |
#79 |
Well, nice beginning to this series. I hope your dad is doing better and you had a nice holiday this year.
I have one of these Walkera machines also - the v120D05 - pretty much the same as the 02 but with a belt drive tail instead of torque tube. Being that it was my third heli after farting around with the Blades (mSR then SR), this thing ran like a finely oiled sewing machine in comparison. Very nice right out of the box. Well, being a total newb at this and still getting the hang of hovering, I smacked it into the pavement - not too bad but I had some repairs to do. I broke one of the plastic swash driver arms and bent the main shaft and messed up some teeth on the main gear. Talk about a PITA to fix - the head and main gear are held in with friction pins instead of screws so that took some thinking to figure our how to get it apart and back together without damage. Anyway, once i had it back together every time I would spin it up and go to lift off it would roll over to one side or the other and would not fly. I got frustrated and shelved it for the last 6 months or so. After finding your vids out here on this and the Genius, they helped me figure out that I needed to bring down my control ranges so that it wouldn't be so twitchy and voila! It's flying again. Unfortunately I bought this before they offered that slick new radio you have been playing with. Mine came with the WK-2603 that Walkera seems to want to use with most of their kits. Talk about an alien way of thinking - the only setup vids that I've found that go into any detail are in Japanese! (Maybe it's Chinese - I dunno - but I can't understand it either way). So, my question is, would there be any chance that you could get hold of one of these older radios and go through the setup on this thing? I think I'm beginning to figure it out but I end up with more questions than answers and there's no one around that can answer them. |
#80 |
man this place Rocks.....
