Old 12-23-2012, 05:43 AM   #81
surm
I recognized how to set up a Idle 3 on DX8.
surm is offline        Reply With Quote
Old 12-23-2012, 06:44 AM   #82
Skidpad
Using a Mix I presume? (there's a helpful thread in the Spektrum forum on how to add a second IU on the DX7s using this method, so that's why I'm asking).
Fusion 50, Blade 450 3D/FBL; mCPX BL, DX8
Skidpad is offline        Reply With Quote
Old 01-07-2013, 09:17 PM   #83
Memphis3
Cool New to Dx8
Dx8
Surper Tx
I have had the Dx8 for 2 weeks. Got it with 2 bad switches. I had to repalce the
M-2013 E round long bat M-2013 L/L flat bat with EG2385-ND and EG2386-ND from Digi-Key
Now I have 2 chargers 2 TM1000 2 AR8000 2 cases.
Video's are a big help prior to reading manual (clairfication).
Last edited by Memphis3; 01-10-2013 at 04:23 PM.. Reason: Deleted Help request not related to Video
Memphis3 is offline        Reply With Quote
Old 01-14-2013, 05:43 AM   #84
Saxguy1000
Originally Posted by Memphis3 View Post
Dx8
Surper Tx
I personally would have just returned it! I sent mine back to HH to have the trim buttons repaired, but that was after 2 years of abuse.
Saxguy1000 is offline        Reply With Quote
Old 01-19-2013, 07:36 PM   #85
NorCal
Default Disable Throttle Warning
Trying to program H.K. 25 ESC. Instructions specify on 1st step that trans throttle needs to be set to wot (wide open throttle) No can do w/o warning signal. Anyway to temporarily disable throttle warning?
NorCal is offline        Reply With Quote
Old 01-20-2013, 05:25 AM   #86
HELISTUPID
Hi
Turn on your radio before you put the throttle wide open,then you power up the ESC and follow the instructions for your ESC's
Don't forget to bind up your reciever/transmitter every time after doing any changes, just to be safe.
HELISTUPID is offline        Reply With Quote
Old 01-20-2013, 12:07 PM   #87
NorCal
Thanks buuuuuuut, esc instructions want the throttle stick in the full up position BEFORE powering up.
Here's how I did a "go around"
Went into System Settings, Warnings, Throttle & set Throttle "Over 100%". Pretty logical when you stop & think about it buuuuuuuuuut I obviously missed it!
Thanks for your tip. Hopefully this will help someone else out
Old 01-28-2013, 07:25 PM   #88
fallfromheaven
Default info
finless do u work on heli's if someone sent one to u
fallfromheaven is offline        Reply With Quote
Old 02-20-2013, 01:25 PM   #89
HeliKing84
Hi, i just bought this spectrum DX8 TX, which running a old version 2.0.2, and i know there is a new version for this DX8 TX for update.. So what i want to know that which is better, old version or new version? cos i heard that someone mentioned to me the DX8 version got abit of problem.. but i now very what is the problem. So i hope could get someone with knowledge on it and give me advice. Thanks...
HeliKing84 is offline        Reply With Quote
Old 02-20-2013, 08:29 PM   #90
johnahamelv
I am on the latest 2.06 fw, and I have not had any issues.
Whiplash E--ICE2HV160/KDE-495/MKS HV's, Synergy E5/S--ICE2HV120/KDE-530/Futaba HV's
T-Rex 600Pro XT--ICE2HV120/KDE-530, T-Rex 550--ICE100/KDE-1175, B130X, mCPx
VBar Silverline x4, Lots of KDE, DX8, Sims: Aerofly5.7 /RF6.5/Phoenix 4
johnahamelv is offline        Reply With Quote
Old 02-20-2013, 08:41 PM   #91
Skidpad
Default Re: Spektrum DX8 Intructional Videos
There were problems with some of the early DX8's, but those have been resolved, and the new ones are fine; I bought one around New Years.
Firmware...there's a list of the changes within each firmware upgrade on the Spektrum site, and you have to 'join" the community to download the firmware.
Be advised that some people - myself included - could not get the tx to load the new firmware from the SD card supplied with the tx; using another card solved the problem. There are a couple of threads about it in the Spektrum forum.
Enjoy it...good tx for the price.
Old 02-21-2013, 12:42 AM   #92
HeliKing84
Originally Posted by Skidpad View Post
There were problems with from of the early DX8's, but those have been to resolved, and the new ones are fine; I bought one around New Years.
Ok well, I just updated my tx to newer firmware from spectrum, and did join the community. But update I using stock sd-card from the tx supplied. So I not sure weather I am running the new firmware or not. And also not sure got problem or not.. So possible someone post some pictures or video show me??
Ok, for my tx which is a pre own used. Pervious owner bought it last year ard May.
Old 02-21-2013, 06:26 AM   #93
johnahamelv
If there is a concern whether the DX8 is "pre-recall", check it against the Horizon Hobby service bulletin.
Also, you can verify the version of the firmware under System Setup>>System Settings>>Next.
Old 02-21-2013, 12:01 PM   #94
HeliKing84
And i had goggle on youtube some of the DX8 video, I had notice that how come the backlit how come is blue color? is newer DX8 or they did something to the TX?
Old 04-18-2013, 07:44 PM   #95
masonian
Default DX7s and DX8 initial swash settings
When setting up your heli should you change the swash setting to 50 or leave them at 60. I'm new to spektrum radios and don't understand why there initial setting is at 60. My first post by the way.
masonian is offline        Reply With Quote
Old 04-18-2013, 07:56 PM   #96
johnahamelv
+/- 60 is a good place to start. You then adjust as necessary with a pitch gauge. This is mostly for FB helis and some FBL units. Once you start using sophisticated FBL units, you'll setup in 1-servo mode, and most parameters will be adjusted within the FBL unit software.
Old 04-19-2013, 07:17 AM   #97
masonian
Default swash
Really! I did not read anything about using the one servo swash selection. I'm about to setup my new trex 550DFC with a DX7s, My previous heli was a trex 450 sport with a Futaba 7c
Old 04-19-2013, 07:43 PM   #98
johnahamelv
Seems like you may be using the 3GX FBL unit. If I remember correctly, the 3GX relies on the transmitter channels for most of the setup. For other FBL units like the VBar's and Skookum's, you just set to 1-servo, and the FBL unit takes care of the rest, so less reliance on the transmitter.
Old 05-15-2013, 03:56 AM   #99
erk700
Great videos..really helpful..thanks Bob
erk700 is offline        Reply With Quote
Old 05-15-2013, 05:07 PM   #100
NightF0x
Thanks Bob great tutorial !!!
NightF0x is online now        Reply With Quote
