Old 11-19-2011, 02:07 PM   #1
boltor
Lightbulb Skookum SK540, SK720 videos / walk throughs, start here!
Assume everyone has seen these now? Outstanding work Skookum!
Initial
Swash / Cyclic
Swash Levelling High, Zero, Low, Collective.
Advanced Tuning for 3D Pilots:
Once you have flown a few flights and are familiar with using the setup
software, you can do some more advanced tuning to further improve your
helicopter’s performance during piros and fast collective changes.
1) If you haven’t already done so, change your setup software interface to
Advanced or 3D Tuning. Do this by selecting one of these two options
from the Preferences menu.
2) The helicopter’s centre of gravity should be directly under the main
shaft. Check by putting the blades at right angles to the fuselage and pick
the helicopter up with your fingers under the blade-grips. The helicopter
should hang with the main shaft straight up and down.
3) Ensure that the swash motion is even throughout its range.
• Put the SK720 into setup mode and set collective pitch to zero. The
swash should be level. Adjust the individual servo centers or the
linkages as required.
• Set the collective pitch to maximum positive. The swash should still
be level. If not, adjust the servo travels for one or two of the swash
servos on the Swash Servos tab in the SK720’s setup software.
• Do the same for max negative pitch, using servo travels for the other
direction.
Blade Pitch & Phasing Adjustments
Tail
Note, its common in setup mode for the tail servo to "kick" periodically, this is all perfectly normal and of no concern.
Throttle
Governor
GOV READ! http://www.helifreak.com/showthread.php?t=428191
Power Bus
Futaba 8FG
Spektrum DX-7
Spektrum DX-8
Traditional Receiver Setup
Self-Level Tutorial
Pre-Flight & Maiden
UPLOADING files to HF read =
http://www.helifreak.com/showthread.php?t=450075
Compass 6HV FBL | Stock Motor | HW 70A HV Pro ESC w/ Turnigy v1.7 firmware | SK-720 FBL & PowerBus | R6203SB Rx, sbus
MSH Protos 500 | Scorpion 3026-880 | CC 75A Ice Lite ESC | SK-720 | R6203SB Rx, sbus
Other: Futaba 8FG | iCharger 208B
boltor is offline        Reply With Quote
Old 11-19-2011, 02:55 PM   #2
georgi UK
=] thanks Bolter, nice one!
georgi UK
georgi UK is offline        Reply With Quote
Old 11-20-2011, 12:15 PM   #3
heathy
Great work Now its idiot proof.
X2 SK720 MINIJAZZ 20 / WARP 360 SK540 KOBY55 / E5 SK540 YGE120LV / LOGO 550SX SK540 HELIJIVE 120 / 7HV SK540 YGE160k / 7HV SK720 YGE 120k / TDR SK540 POWERJIVE 120 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote
Old 11-21-2011, 08:49 AM   #4
JKS3613
Good stuff to be certain, (Thank you SK) but the one specific to SL is the one I really need right now. Hopefully, it will be posted soon as well. Again, great job guys, and thanks!!
JKS3613 is offline        Reply With Quote
Old 11-22-2011, 03:58 PM   #5
georgi UK
=] 4 more added!
georgi UK
Old 11-22-2011, 04:24 PM   #6
fusionsx00
This is awesome, i bet this will free them up from alot of setup questions
Dx8 mCPX bl v1 hp05s130X
GauiX2FESds11,ds95i beastx
Gaui X5FES,AR7200BX,Xera4020Torq9088,9188
fusionsx00 is online now        Reply With Quote
Old 11-23-2011, 03:05 PM   #7
georgi UK
=] DX7 added!
georgi UK
Old 11-25-2011, 11:00 AM   #8
georgi UK
=] blade pitch, phasing & self-level tutorial added!
georgi UK
Old 11-27-2011, 02:38 PM   #9
Pampaflieger
Location: Dresden, Germany Saratoga Springs N.Y. coming soon
Thumbs up very helpfull
Thanks a lot! Will setup my SK720 with Gov too.
Pampaflieger is offline        Reply With Quote
Old 12-01-2011, 12:55 PM   #10
Doc-b
Default FLYBAR
Can the Skookum SK720 be used with a flybar. I am looking for a good stabilization system for my 600N Flybar, with the intent to go Flybarless later
Doc-b is online now        Reply With Quote
Old 12-01-2011, 01:11 PM   #11
georgi UK
______________________________________________-
=] hi, this won't work! can't mix the two, but why not go straight to a FBL head conversion?
georgi UK
Old 12-01-2011, 02:23 PM   #12
Doc-b
Yes I may do that. Thanks. I was trying to buy 1 at a time due to Christmas holidays. I will just have to wait.
Old 12-01-2011, 03:08 PM   #13
georgi UK
=] ok, SK do a refurb unit with a full warranty at 320$ can find you a cheap 3G head if you wish!
http://www.ebay.co.uk/itm/ALIGN-700-...84267670035562
georgi UK
Old 12-01-2011, 06:08 PM   #14
Doc-b
Well After drinkin a few beers. i ordered the Skookum 720 with the FBL head. The heck with it. I want it, I ordered it. Thanks for the help
Old 12-02-2011, 04:15 PM   #15
georgi UK
=] Hmm beer and credit card = heli, welcome!!
georgi UK
Old 12-05-2011, 01:46 PM   #16
CHIEF-X
Default does this wiring scheme look correct to u guys?
hey please check this wiring scheme and see whatcha think! if im doin n e thing wrong please let me know before i set up
Name:	12s wireing sk720.jpg
FUSION 50 12S SK540 TORQ WITH QUANTUM/HOBBYWING POWER SYSTEMALIGN TREX 450 PRO V2 BEASTX 6S MKS SERVO'S GAUI X5 FES BEASTX DX8
WINDANCER
COMANCHE TRIBAL MEMBER 4TH GENERATION
CHIEF-X is offline        Reply With Quote
Old 12-17-2011, 06:43 AM   #17
doug100856
Those videos made my mind up which FBL system I'm buying.
There is SO much electronic stuff released for sale with completely pathetic directions, full of assumptions, darn near 'code' speak.
Those videos are first rate, they sold me. Doug
X50 Titan/DX8 nitro daily driver
HeliArtist AH-1W
Mikado Logo 550SX en route
JR Vibe 500E electric daily driver
doug100856 is offline        Reply With Quote
Old 12-17-2011, 11:26 AM   #18
georgi UK
georgi UK
Old 05-29-2012, 05:48 PM   #19
ArguZ
Is there an advanced setup video out that goes through stuff like Hiller and Bell and Govenor Gain and how it all affects the wagging and bobbing ?
Thing is, I was very happy with my setup until I let a 3D pro fly the heli and he thought it flies like a 7 kilo Scaler
Which was fun at first means I am unable to save it or even the SL would not save it fast enough.
So maybe someone (hey Georgi ) could give us more technical and first hand experience how to setup a proper flickable Heli with the SK....
I guess people would love to see things explained more thoroughly..
ArguZ is offline        Reply With Quote
Old 06-30-2012, 06:38 PM   #20
5488fletcher
Raise your control rate deg under your cylic banks if you havent yet .
5488fletcher is offline        Reply With Quote
