| Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
#21 |
Very helpful thread indeed. I am now 6 flights (3 tuning and 3 hard FFF/Big Air) into my SK540. Flies great
Team Synergy/Team Scorpion |
#22 |
Maybe a dumb question but Ive Been away from Helis for awhile and just getting back in
I just picked up a 540 and was wondering if a fut9251 is a suitable servo on the tail. I have one from a 601 which had low time on it. Thanks in advance Kevin
If Ya Aint Burnin Ya Aint Learnin Kev-o |
#23 |
Should work fine, just make sure you get the settings correct (AFAIK it is 960us, 560Hz servo but check that).
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh |
#24 |
I just finished the maiden (two flights) on a 450 SEV2 heli with the 540, super happy with the performance right out of the gate. Besides being a fantastic FBL unit, between the videos and the guys here on the Skookum forum you can't go wrong. Special thanks to Georgi for his help. Gotta go, got some more flying to do.
Paul Outrage 550 - Castle 3434-1100, Ice 100, Bec Pro, 94758z, Total G w/JR 8900G Outrage 550 - 4020-1390, Ice 100, Bec Pro, JR 8717s, Total G w/JR 8900G Rave Ballistic FSO - HKIII 4035-560, Ice HV160, Bec Pro, JR 8717s, Total G w/BL-9188 |
#25 |
I'm a little confused here. If i have standard reciever (futaba) i can't use governor?
Matija |
#26 |
Yes that's right. If your using a normal rx then you have to forgot the gov! S-bus is the way forward here.
Sent from my iPhone 4s using tapatalk
X2 SK720 MINIJAZZ 20 / WARP 360 SK540 KOBY55 / LOGO 550SX SK540 HELIJIVE 120 / 7HV SK540 YGE160k / 7HV SK720 YGE 120k / TDR SK540 POWERJIVE 120 / X7 SK540 HELIJIVE 120/ Futaba18mz / Skookum support rep |
#27 |
are there any setup vids for the sk540? Or are they both the same setup?
Rumors are started by haters, spread by fools and accepted by idiots. |
#28 |
=] generic apart from the self level tutorial....
georgi UK |
#29 |
Why dont they tell you what to do in the case of something does work or the setup fails at a single step? I'm stuck on step 22 and have no clue how to get it right. I've tried everything under the sun and it still doesnt work. A video of what to do at a certain step if something fails, would be nice. But I guess I should hold my breath.
#30 |
Im using an sk540 with a dx8 on my velocity 50 n2 with a gryphon remote glow ingiter plugged into the IO-B port. However, I cant switch it off, and Im not sure how to mix it with the throttle hold on my radio either. Does anyone know how to make this work?
SAB Goblin 500
Avant Aurora Electric To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#31 | |
Furion 450 skookum 540 Furion 6 ,skookum 540, futaba bls servos, 10s ,awesome, |
#32 |
Hi all pilots,
Here's website for skookum setup or tunning. All right here so dig it. http://www.skookumrobotics.com/wiki/...itle=Main_Page for advanced go here man. http://www.skookumrobotics.com/wiki/...dvanced_Tuning |
#33 |
Hello
This is my second SK540, am about to set it up on my 550 sized heli. I was watching the setup videos again since I haven't set up the SK for a while, and something struck me. I do not remember ... "resetting the gyro' in my previous setup. If you watch the "Blade Pitch & Phasing Adjustments" video(3rd video down on the first page), it mentions at 3:00 minute mark to reset the gyro. I do not understand it. I do not think I had done it before. Hoping someone would confirm that it is a needed step. There is a possibility that the reset is built into the Wizard, then I must have done it. But, if I need to do the reset by pulling up the menu, I am sure I have not done it in the past. Look forward to your feedback cheers |
#34 |
=] the reset is simply disconnecting from windows and reconnecting again, this happens during the wizard stages. nothing to worry about.
georgi UK |
