Old 07-03-2012, 09:01 AM   #21
Chris Sexton
Very helpful thread indeed. I am now 6 flights (3 tuning and 3 hard FFF/Big Air) into my SK540. Flies great
Team Synergy/Team Scorpion
Chris Sexton is offline        Reply With Quote
Old 07-24-2012, 10:18 PM   #22
B@@MER
Maybe a dumb question but Ive Been away from Helis for awhile and just getting back in
I just picked up a 540 and was wondering if a fut9251 is a suitable servo on the tail. I have one from a 601 which had low time on it.
Thanks in advance
Kevin
If Ya Aint Burnin Ya Aint Learnin
Kev-o
B@@MER is offline        Reply With Quote
Old 07-25-2012, 12:25 AM   #23
desertstalker
Should work fine, just make sure you get the settings correct (AFAIK it is 960us, 560Hz servo but check that).
-DX8
Old 07-25-2012, 04:30 PM   #24
pctomlin
I just finished the maiden (two flights) on a 450 SEV2 heli with the 540, super happy with the performance right out of the gate. Besides being a fantastic FBL unit, between the videos and the guys here on the Skookum forum you can't go wrong. Special thanks to Georgi for his help. Gotta go, got some more flying to do.
Paul
Outrage 550 - Castle 3434-1100, Ice 100, Bec Pro, 94758z, Total G w/JR 8900G
Outrage 550 - 4020-1390, Ice 100, Bec Pro, JR 8717s, Total G w/JR 8900G
Rave Ballistic FSO - HKIII 4035-560, Ice HV160, Bec Pro, JR 8717s, Total G w/BL-9188
pctomlin is offline        Reply With Quote
Old 08-08-2012, 11:51 AM   #25
zosek
I'm a little confused here. If i have standard reciever (futaba) i can't use governor?
Matija
zosek is offline        Reply With Quote
Old 08-08-2012, 12:06 PM   #26
heathy
Yes that's right. If your using a normal rx then you have to forgot the gov! S-bus is the way forward here.
Sent from my iPhone 4s using tapatalk
X2 SK720 MINIJAZZ 20 / WARP 360 SK540 KOBY55 / E5 SK540 YGE120LV / LOGO 550SX SK540 HELIJIVE 120 / 7HV SK540 YGE160k / 7HV SK720 YGE 120k / TDR SK540 POWERJIVE 120 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote
Old 08-10-2012, 10:02 AM   #27
dantemcc
are there any setup vids for the sk540? Or are they both the same setup?
Why does everyone keep calling me Dan? My name is Dante
dantemcc is online now        Reply With Quote
Old 08-10-2012, 10:21 AM   #28
georgi UK
=] generic apart from the self level tutorial....
georgi UK
georgi UK is offline        Reply With Quote
Old 08-31-2012, 06:38 PM   #29
dantemcc
Why dont they tell you what to do in the case of something does work or the setup fails at a single step? I'm stuck on step 22 and have no clue how to get it right. I've tried everything under the sun and it still doesnt work. A video of what to do at a certain step if something fails, would be nice. But I guess I should hold my breath.
Old 09-03-2012, 12:19 PM   #30
kumar2494
Im using an sk540 with a dx8 on my velocity 50 n2 with a gryphon remote glow ingiter plugged into the IO-B port. However, I cant switch it off, and Im not sure how to mix it with the throttle hold on my radio either. Does anyone know how to make this work?
SAB Goblin 500
MA Whiplash Electric - 14S
kumar2494 is offline        Reply With Quote
Old 10-27-2012, 06:44 AM   #31
anthony1
i had the same problem until last night, evertything was at 100 % but still wouldn't get past this step , what i found was that the collective input from my transmitter was way too high , i reduced it in atv(pitch) in my transmitter until it started to go down in the software then put it back up to 100% in atv(transmitter) and a couple of extra clicks and it passed, so then i was able to finish the setup
Furion 450 skookum 540
Furion 6 ,skookum 540, futaba bls servos, 10s ,awesome,
anthony1 is online now        Reply With Quote
Old 10-29-2012, 12:12 AM   #32
x5heli
Hi all pilots,
Here's website for skookum setup or tunning. All right here so dig it.
http://www.skookumrobotics.com/wiki/...itle=Main_Page
for advanced go here man.
http://www.skookumrobotics.com/wiki/...dvanced_Tuning
x5heli is online now        Reply With Quote
Old 11-22-2012, 06:55 PM   #33
karma4u
Hello
This is my second SK540, am about to set it up on my 550 sized heli. I was watching the setup videos again since I haven't set up the SK for a while, and something struck me.
I do not remember ... "resetting the gyro' in my previous setup. If you watch the "Blade Pitch & Phasing Adjustments" video(3rd video down on the first page), it mentions at 3:00 minute mark to reset the gyro.
I do not understand it. I do not think I had done it before. Hoping someone would confirm that it is a needed step. There is a possibility that the reset is built into the Wizard, then I must have done it. But, if I need to do the reset by pulling up the menu, I am sure I have not done it in the past.
Look forward to your feedback
cheers
karma4u is offline        Reply With Quote
Old 11-23-2012, 12:15 PM   #34
georgi UK
=] the reset is simply disconnecting from windows and reconnecting again, this happens during the wizard stages. nothing to worry about.
georgi UK
