| 450 PRO Class Electric Helicopters 450 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
A friend Ronald of mine was suffering from a severe tail wag of his new (1 month old and never crashed) T-rex 450 pro V2!
We first suspected the gain (BeastX), but that was not the problem. Tail servo was ok, tail control link and slider were ok. (without binding) Push rod and ball links where ok, and where sliding without binding! Until I noticed something, I saw a little gap between the metal tail holder and the tail blade grip! The gap appeared larger than normal so I took off the blade grip and guess what The blade grip bearings were completely broken to pieces! I have the bearings replaced and the tail wag was gone.
We Men Need a Second Hobby, Besides Women To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Futaba T8FG T-Rex 550 & 450 DFC BeastX V3 Logo 600se VBar 5.3 pro Kontronik www.modelhelicopter-review.nl Last edited by trexpro; 12-03-2011 at 05:38 PM.. |
Align is really having a problem with the bearing in the tail for some reason
I had the very same problem. Nasty wag until I replaced the tail bearing and wag disappeared.
Trex 450 Pro V2 FB spartan quark trex 250 beastx Fusion 50 beastX |
#3 | |
We Men Need a Second Hobby, Besides Women To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Futaba T8FG T-Rex 550 & 450 DFC BeastX V3 Logo 600se VBar 5.3 pro Kontronik www.modelhelicopter-review.nl |
Thanks danny for all your help
Ronald. The Netherlands.
Trex 550E Flybarless with Beastx 3.0 Trex 450 Pro V2 flybarless with Beastx 3.0 Futaba T8FG 12 channel 2.4 ghz fast. modelhelicopter-review.nl |
You will not believe it but my 450 pro V2 tail bearings buckled also today, I was doing a backflip and out of nowhere my tail responded no longer. I was barely able to save my heli. On the ground I noticed the same gap between the metal tail holder and the tail blade grip! The blade grip bearings were also completely broken to pieces.
The only difference is that my 450 pro V2 has 155 flights on it! I dont trust the Align bearings no more! ![]()
#6 |
Wich bearings can you get to replace the align ones?
#7 |
I'm thinking about boca bearings stainless steel
![]() measurements we need are: 3x6x2.5mm and 2x5x2.5mm. Regards danny
#8 |
Must agree Boca bearings are some good ones to use.
#9 |
Happened on my 450 pro V1 as well.
Heat up the grips to get the old bearings out (loosens up the thread lock). Replace with some good replacement bearings from a hobby store (online or local).
Align 450 Pro, Microbeast, RJX head Align 500, Microbeast, Align head, Scorpion, CC ICE 75 Blade mCP X |
#10 |
I recently had the same tail bearing issue with my new 450 pro v2..
The bearing disintergrated as per the first post.. The problem was that the outer race of the bearing remained glued to the tail grip... and was glued tight!!! I tried everything to get it out ... I even heated the tail grip... which turned a black tail grip into a "Bronze" coloured tail grip.. aaaarrrrgggghhhhh... Eventualy, I had to mill out the outer race with a 5mm mill bit.. Now my pro has a half black / half bronze coloured tail... so be careful if you decide to heat the grip.. PS: My pro had only 15-20 flights on it as at the time of the bearing failure -
DX7 Mode-1 | T-Rex 250 | EP200SE V2 | Tricopter | Quadcopter 450 pro 6s fbl 3X1000 | 450 pro fbl beastx | Schweizer 300C Gasser Scale |T-Rex550e 600 vbar | Aeolus 50 HeliX T-Rex700 fbl Gasser | HWC600 321puh Gasser fbl| Henseleit TDR |
#11 |
been through 2 tails so far on my v2 pro
RCHeliCanada.com -Team pilot SKOOKUM rep -ROBOTICS- |
#12 |
it seems I am not alone with this problem !!
It is a serious design issue of the blade grips on the 450 pro version or it's a low quality bearing problem? All the stress and force is on the outer bearing (2x5x2.5), the only way to solve this problem for good is to use thrust bearings! the second best solution is to use high quality bearings, but those bearings are expensive and should also be checked regularly. Anyway the use of a radial bearing with such axial loads is not good! maybe someone knows if a replacement tail (or blade gips) with thrust bearings exists that fits the 450 pro, or are there thrust bearings that fit in the original Align 450 pro blade grips? Regards danny
#13 |
I had some nice bearings from my touring car that are same size. I also ordered some from r-bearings.com. they sale an entire retrofit kit for 450. Cheap and way better bearings.
Sent from my Atrix 4G using Tapatalk
Steve ALEES Rush 750 - Vbar Silverline -YGE160HV, Scorpion 4525-520 OUTRAGE Fusion 50 - Vbar Silverline, Jive 80HV, Quantum 4125-560 |
#14 | |
Did you also have a tail bearing issue before you buy the entire retrofit kit ?
#15 |
Here is yet another Thread on the same subject http://www.helifreak.com/showthread.php?t=309898
#16 | |
#17 |
I am having the same issue on my 450Pros and really don't like how much slop there is in the tail control. Are there any companies that make a good replacement tail assembly for the 450Pro?
RC Heli Pilot = Control Freak |
#18 | |
radial ball bearing supported tail grips and precise machining tolerances for the brass bushing sleeveen. Align has the metal bell crank upgrade and there are also complete new tail pitch sliders to get rid of the slop, but there are no upgrades for the blade grips.
#19 | |
this part took 90% slop out of my tail. http://hobby-wing.com/gsc078.html
#20 | |
