Go Back   HeliFreak > R/C Helicopter Support > Hirobo Nitro Helicopters > Hirobo Electric Helicopters
Hirobo Electric Helicopters Hirobo Lepton EX, Quark and other Electric Helicopters
Old 12-02-2011, 08:48 AM   #1
7.62x51
Default EMBLA - building; setups; advices.
Just recieved the kit.
Starting the build.
What's in the box:
Henseleit TDR; Synergy E7; Hirobo EMBLA.
Fabio
7.62x51 is offline        Reply With Quote
Old 12-02-2011, 09:44 AM   #2
7.62x51
This kit is "high quality".
The manual are awesome, it's made of thick paper and the drawings are user-friendly.
Very rigid frames made of very good carbon fibre, good plastic parts and beautiful alloy bearing holders completes the stages 1 and 2 of the constuction.
Now starts phase 3:
Fabio
Old 12-02-2011, 11:55 AM   #3
7.62x51
During the phase 5 i broke a tail linkage; yes i'm a dumb. So for not compromise all my work and wait a week for spares i thought to modify the tail pitch plate assy.
I found a couple of links compatible, only longer, this makes me reverse the tail rotor rotation (TDR style now..).
Waiting for the piece i will try to fly like this.
Fabio
Old 12-02-2011, 12:09 PM   #4
toyturbo
Awesome! Keep the pics coming!
toyturbo is offline        Reply With Quote
Old 12-02-2011, 12:45 PM   #5
poring
Cool! I was waiting for you to post this.
poring is offline        Reply With Quote
Old 12-02-2011, 01:36 PM   #6
7.62x51
Servo mounting was rather laborious, expecially wiring.
However i did it, and seems good...
Fabio
Old 12-02-2011, 03:02 PM   #7
7.62x51
Head ready. High quality here. Work was simple and fast, no trouble.
Fabio
Old 12-02-2011, 03:50 PM   #8
7.62x51
The swashplate is awesome
I used MolyKote EM-30L on gears, this lowered the friction
The head can be phased, i set it neutral.
Fabio
Old 12-02-2011, 05:18 PM   #9
7.62x51
Ball links were on the tight side, so i used a specific tool to make them fit properly.
Ok, it's time to do electric setup. Should not be too long, i preventively zeroed servos assignig them opportune value of su trim.
Then i will sold connectors on Koby and find the best place fot in into the frame.
Fabio
Old 12-03-2011, 03:19 PM   #10
7.62x51
Ok, work is aimed to the end; cannot fly today, maybe tomorrow.
Kontronik Koby is too large to be fitted inside of the frame so, as per manual advice, i put it on the front side.
First flights will done using Edge blades that are 315mm center to tip instead of Hirobo's 325 center to tip. Stock blades are beautiful!
Setup:
Kontronik Koby 40 - governor on
Hirobo motor - kv?
Pinion 15T Revco
MKS DS92
MKS DS 95i
Align GP780
EDGE 325
EDGE Tail blades
Curve 1 flat 40%
Curve 2 flat 50%
Curve 3 flat 60%
Collective pitch +/- 14
I will post my impressions after flight, so stay tuned....
Fabio
Old 12-03-2011, 03:49 PM   #11
poring
Looks good! Thanks for all the pics.
Old 12-03-2011, 07:10 PM   #12
7.62x51
I was not totally satisfied by cable wiring, so i did it better.
Reciever plate can be mounted in different way, so it's possible to find the best position for the reciever.
Fabio
Old 12-06-2011, 11:39 AM   #13
7.62x51
Today i had a couple of flights comparing EMBLA with my TRex pro.
I set Scorpion 2221-8 motor on both, 15T on Hirobo and 14 on Align.
Governor on for 2750-3000-3250 rpm on EMBLA; 2900-3100-3400 on TRex.
14 collective - 10 cyclic EMBLA; 12 - 9 TRex.
So, Hirobo at max rpm is faster, quicker, more stable than Align.
At lower rpm EMBLA is very quiet, fly straight, is smooth.
In every condition EMBLA have more collective autority than TRex.
Helis have almost same weight, Align is lighter for 40 grams of difference.
Fabio
Old 12-06-2011, 05:47 PM   #14
NEAGRON
Fabio,many thank's for that,i want one,your's Marty.
NEAGRON is offline        Reply With Quote
Old 12-06-2011, 06:04 PM   #15
7.62x51
Marty
buy it, you will not be disappointed.
Hirobo did this 450 in "join-venture" with Thunder Tiger, some parts are same of Mini Titan V2 (gears, belt, boom, braces,....), so you can buy spares cheaper than Hirobo's....
Fabio
Old 12-06-2011, 06:30 PM   #16
2kwik2c
Talking
Glad to see an Embla 450 build thread and I'm happy that you like it. I have yet to build mine. Hearing from your experience makes me want to start building it as well. Just so you know the spare parts for the Embla 450 is not expensive just because it's a Hirobo brand. They are around the price as the Thunder Tiger Mini Titan spare parts. Hirobo made sure that the owners of the Embla isn't short handed just because of the cost of repair.
Enjoy!!!
2kwik2c is offline        Reply With Quote
Old 12-06-2011, 06:42 PM   #17
NEAGRON
Originally Posted by 7.62x51 View Post
Marty
Hi 7.62-51-;3450296,
I will have one but it might be after xmas,spent all my pennies,once again thank's and keep us posted with progress and mods,Marty.
Old 12-07-2011, 11:36 PM   #18
Mike2112
Please post more pics and videos. Very nice! I have a Trex 450 Pro too and would like the Embla.
Hirobo Evo .50/Futaba 9C/OS 50 Hyper & Hatori/Radix/GV1/GY401&9254/9252s/Arizona Heli Canopy
Trex 500 FBL/Futaba 8FGS/CGY750/CC ICE 75 & Scorp 1400 16T/Radix/9650s/9256
Trex 450 Pro/Futaba 8FGS/450M 14T/TP Blades/ 3156s/ Futaba GY520&9257
Mike2112 is offline        Reply With Quote
Old 12-08-2011, 01:43 PM   #19
eightythree
Nice side by side comparison to the pro.. Enjoyed this thread and glad you built the traditional flybar model! The blade grip mixing arm setup is what i like to see.
To this date ive flown many 450 sized helis and thought the trex 450 pro was the best flying out of all of them. The Embla is on my list for my next 450
eightythree is offline        Reply With Quote
Old 12-08-2011, 04:07 PM   #20
7.62x51
Today i tryed some sport flight at 2800 rpm (42% throttle); i left my timer as per 3D, 4 minutes, at the end in the pack still were 40% of charge.....
I thought it was more unstable with green paddles and uniball in center of seesaw, but it's not; sometimes i was thinking to fly flybarless..
Fabio
