Go Back   HeliFreak > R/C Helicopter Support > E-Sky Helicopters > HBFP V1/V2
HBFP V1/V2 E-Sky Honey Bee V1 & V2 Fixed Pitch
Old 12-11-2011, 09:34 AM   #1
Steemo
Default Guide to installing wire mesh shielding
On my 450s and 500 I have used the following method for tidying up servo wires, and have since done the same for some of the wires of my Bee. I stripped a servo gear today(yes OLP it was the orange HK ) so I had to install the shielding on the replacement. Though some of you might like to see how it's done so I took some pics.
First you take off the black plug by pushing the wires in as far as they will go into the plug then one by one gently lift the little piece of black plastic holding each wire in place with a pin or tip of an xacto knife then pull that wire out.
Put a small amount of heat shrink over the 3 wire ends as this helps a lot with getting the wire through the mesh.
Figure out the length of your servo wire you need then you can either:
Cut out the wire in the middle, join and insulate each wire
or
Triple over the wire and secure it with some heat shrink (I have done this method this time)
Cut your mesh tube to length and don't forget to singe the ends with a lighter so they don't fray when you open it up.
Slide the mesh over the servo wire, this can be a bit frustrating if you don't do it right so remember it is easiest to push from behind as this opens the mesh up. if you pull from the front it closes the mesh on the wire and it will not move.
Before putting the plug back on the wires you need to slide on the heat shrink to secure each end of the mesh. I like to use heat shrink that is just too small to fit over the mesh and stretch it gently with needle nose pliers then slide it on quickly as the heat shrink likes to return to its original shape after stretching even without heat.
Once you have 2 pieces of heat shrink over the mesh you can re-attach the black plug to the wires, make sure you get this the same way in as they were before, you can use another servo plug as an example of where the black red and white wires go(can sometimes be purple red and yellow as with my servo here).
Now arrange the heat shrink right up at each end and fix them in place.
This was really hard for me to get done when I first tried but with some practice and after I learned some of the tips and tricks I've outlined here its now a quick easy job.It will protect vulnerable wires from sharp edges, tidy up your wiring and give your heli that professional install look.
Name:	2011-12-11 20.10.07.jpg
ID:	272723   Click image for larger version
Name:	2011-12-11 20.18.48.jpg
ID:	272724   Click image for larger version
Name:	2011-12-11 20.20.40.jpg
ID:	272725   Click image for larger version
Name:	2011-12-11 20.21.47.jpg
ID:	272726   Click image for larger version
Name:	2011-12-11 20.22.27.jpg
Name:	2011-12-11 20.24.51.jpg
ID:	272728   Click image for larger version
Name:	2011-12-11 20.27.39.jpg
ID:	272729   Click image for larger version
Name:	2011-12-11 20.47.44.jpg
ID:	272730   Click image for larger version
Name:	2011-12-11 20.49.19.jpg
ID:	272731   Click image for larger version
Name:	2011-12-12 00.18.57.jpg
T-Rex 700E Pro DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro |T-Rex 500 DFC Pro mini V-Bar
T-Rex 450L Dominator | JR DSX9 9503 Mode 2
Steemo is offline        Reply With Quote
Old 12-11-2011, 10:10 AM   #2
Oldladypilot
Perfect!!
Thanks for posting this Steemo!
Very useful info.
Bugster;
1 vote to sticky this please!!
Spektrum Dx6i , HK 500 GT, Esky Honey Bee FPV2, Blade MCX, MCX2, HK P-51 Mustang, F4U Corsair, Hobbyzone Champ
Oldladypilot is offline        Reply With Quote
Old 12-11-2011, 11:32 AM   #3
Viet-Lama
Very sweet job. I like your little "folding trick"! Much better then all that cutting/splicing to shorten the wires.
I already have braided wire and will soon tidy up one of my 450s. Going to use that crafty fold method
Every time I crash I wonder, why didnt I get into RC tanks.
Viet-Lama is offline        Reply With Quote
Old 12-11-2011, 12:45 PM   #4
Bugster
Originally Posted by Oldladypilot View Post
Bugster;
Any more in favour?
Cheers, Bugster
Bugster is offline        Reply With Quote
Old 12-11-2011, 01:44 PM   #5
boykintom
Yes--there are several very good tips here.
boykintom is offline        Reply With Quote
Old 12-12-2011, 12:54 AM   #6
Viet-Lama
Please remove my outdated LANDING SKIDS COMPAIRED tutorial and replace with this one
Old 12-12-2011, 01:53 AM   #7
Steemo
Thanks for the sticky votes guys, I know this isn't a common customization for the bee because of it's small size but it could be helpful for many of the budding CP builders/fliers we are seeing so much of around here.
Old 12-12-2011, 05:52 PM   #8
Bugster
Stickied. Thanks Steemo
It's under Modifications to improve your HBFP
And VL I couldn't bear to delete your "skids compared" sticky because it will help pilots of vintage V1s in the future
Cheers, Bugster
Old 12-13-2011, 12:53 AM   #9
Viet-Lama
Old 12-29-2011, 09:05 AM   #10
boykintom
I would like to use this method, but I'm having trouble finding the plastic braid. Suggestions for stores that carry this?
Old 12-29-2011, 09:11 AM   #11
oliverdots
Great idea I will be using. Thanks for that Steemo.
Definately worth the 'sticky' status
Cheers, OD.
If you make a mistake and learn from it, that's progress
2 x Nano heli's - now passed on to Megan, HoneyBee V1.....Awaiting test flight, T-Rex 250 V1, Hitec 5084MG tail servo, DX6i, Walkera 4#3A (it's in fairly good hands Bugster).
oliverdots is offline        Reply With Quote
Old 12-29-2011, 10:46 AM   #12
Oldladypilot
You can get it at;http://www.cabletiesandmore.com/amer...cPath=69_73_74
Or;http://www.hobbyking.com/hobbyking/s...idProduct=9551
Watch carefully what size you order, and order plenty.....you'll mess some up until you get the hang of using it!
Old 12-29-2011, 11:05 AM   #13
Egroeg
Using a soldering iron on servo wires can for some strange reason render the servo dead.
If one needs to reinstall the female pins on wires use a crimping tool.
This guy has a good selection of cable protection mesh.
http://helidirect.com/advanced_searc...line&x=22&y=21
No Pitch...No Fun!!!
Egroeg is offline        Reply With Quote
Old 12-29-2011, 09:03 PM   #14
Steemo
Thanks OD, it means a lot to me when it's coming from someone who's post helped me out lots when I first started.
This is where I get mine, cheap as chips but it's worthwhile placing a big order with lots of other bits and pieces you need to reduce the overall shipping cost per item. EMS rocks btw 3-4 days to your door
Yes! 4mm is the best size to get if you are only going to feed one or 2 servo wires. 6mm is only needed when you are feeding 3 or more.
Originally Posted by Egroeg View Post
Using a soldering iron on servo wires can for some strange reason render the servo dead. If one needs to reinstall the female pins on wires use a crimping tool.
I'll keep that in mind, I might practise shortening some wires by soldering on some cheap $2 servos and see how that goes. But i do agree, re crimping is the cleanest way
Oooooo Pretty colours
