Old 12-17-2011, 10:27 AM   #1
kostasch
Default DX8 problem??????
hello ! i have a problem and i want some users of spektrum dx8!
Please tell me which is the normal time for (system is inactive)
In the manual write 10 minutes ! But when i leave for 5minutes and 5 second about it start the alarm and the vibe and appear in the screen system is inactive!
please help me
kostasch is offline        Reply With Quote
Old 12-17-2011, 12:18 PM   #2
Slyster
That doesn't sound like much of an issue. I'd update it to the latest airware software and I bet it reverts to what the rest of ours are set to.
"It's not just a hobby... it's a lifestyle" - Pete ϟ
Slyster is online now        Reply With Quote
Old 12-17-2011, 12:41 PM   #3
kostasch
thank you very much for your answer ! i have already the last software 2.04! when i had the 2.01 it started in about 11 minutes ! now with 2.04 it happen in about 5minutes and 5 seconds!!!! if its possible please try it in yours dx8 and tell me because i am afraid! ok i know this is not a big problem but i must know for sure what happen
Old 12-17-2011, 11:04 PM   #4
tcappert
Mine is about 5 minutes/10 seconds...ver 2.04
Trex700N/Trex600N/Trex600ESP,Trex550E Trex450L X2/mCPX BL
JR X9503/DX9/Phoenix
tcappert is offline        Reply With Quote
Old 12-18-2011, 02:22 AM   #5
aerocal
Haha. Apparantly it has changed to 5 mins. Have to think about this one for a few.Maybe an accident maybe intentional.It would make it so I dont get so far away from my radio before it goes on.
Too many helis & Too many planks
Lots of DX radios & A couple Futaba 72mhz radios
AMA member & Full scale plank driver
HELIFREAK !!!
aerocal is offline        Reply With Quote
Old 12-18-2011, 05:00 PM   #6
garyji
I'm pretty sure mine doesn't go 10 minutes.
G.
T-450 Sport FBL, T-550 V1 FBL, Red Goblin 700. Goblin 500. 350 QX. Bunch of little Blades, and Planks. DX8, Retired Full scale Jet Plank Driver, U.S. Navy Ret.
garyji is offline        Reply With Quote
Old 12-18-2011, 05:32 PM   #7
halcyon32
Mine is a little over 5 minutes also. ver 2.4
Align T-REX 450 Sport
(Castle Creations Phoenix 45), (Spektrum DX8 AR8000 TM1000), (Revolectrix Co-Pilot II Lite)
http://www.helifleet.com/Halcyon32
Contributor, Team LavaQuad
halcyon32 is offline        Reply With Quote
Old 12-18-2011, 06:04 PM   #8
kostasch
Thank you very much for the post.So now i am sure that this is normal and it changed with the last version 2.04. Anyway i sent already. A mail to HH and i am waiting for the replay the next days. Thank you all of you for the help.
Old 12-19-2011, 01:30 AM   #9
1004ron
Does anyone see a problem with it being at 5 mins ?
I don't see a problem with it at 5 mins, and typically this only activates when busy with a heli setup, or the odd occasion that I leave it on after a flight.
SAB Goblin 700 - CCHV120 - BEC Pro - AR7200BX - TM1000 / 450 Pro - GT5 - Tarot head / T-Rex 550 V2.1 - CC100 - BEC Pro - AR7200BX - TM1000 /
1004ron is offline        Reply With Quote
Old 12-19-2011, 09:59 PM   #10
Soarmax
I see no problem with it being 5 minutes. Just seems funny that they would make no mention of changing the time in the DX8 SpektrumAirWareChange Log for 2.04.
Wouldn't it be nice if they made it operator adjustable, say from 1 to 20 minutes. At least you would know what to expect.
My quess is that someone at HH goofed up.
Helicopters don't fly -- they beat the air into submission.
If something hasn't broken on your helicopter -- it's about to.
T-Rex SA - Full Metal - 430L/35G/12T - 65MG/401/3154 - DX7/6100
T-Rex V2 - 430XL/35X/12T - 65MG/401/3400G - DX7/6100 -- T-Rex 500CF - 5245/GY520/9257 - DX7/6200
Soarmax is offline        Reply With Quote
Old 12-20-2011, 03:31 AM   #11
johnopsec
This is likely the result of some regression testing in the new build. This timer is probably a "compile time" option when the code is compiled. Whoever was doing regression testing of the code probably dropped the time down to save some time during the testing. (Do you really wanna sit around for 10 minutes just waiting to see if the TX complains like it should when you could just compile it with a 5min timer instead?) Once this testing was done, someone simply recompile using the "normal" timers and we are probably running the exact build that was "tested".
John
Compass Knight 600E, Blade 450, Blade 400, Blade SR, Blade mCPx, Blade 120, Blade mSR, Blade mCX, Blade CX2
johnopsec is offline        Reply With Quote
Old 12-20-2011, 02:49 PM   #12
aerocal
Originally Posted by Soarmax View Post
I see no problem with it being 5 minutes. Just seems funny that they would make no mention of changing the time in the DX8 Spektrum AirWare Change Log for 2.04.
Or they just got weary of trying to make everyone happy at the same time.
Makes no matter to me.Its better at 5 mins anyway.
HELIFREAK !!!
Old 12-20-2011, 03:01 PM   #13
aerocal
Ill just have to remember to bump a stick a couple times when I have the blimp hiding in a corner while the National Anthem and presentation of colors is going on.That would be embarrassing.Thousands of ppl staring at me with contempt for my inactivity alarm blaring out in a dead silent auditorium.Even worse if it ended up on the 11o'clock news.
HELIFREAK !!!
Old 12-21-2011, 11:27 AM   #14
Colorado_Scott
Default Another issue..
On my DX8 I find that if I go into Switch Select (hold down the scroll key while turning on the transmitter) and set the L-Trim for Throttle and the R-Trim for Pitch, after shutting off the radio, the setting do not stay - ONE setting might stay, but one does not. These setting would allow me to adjust hover pitch and hover throttle while actually hovering.
Can someone else check their out and see if this is a issue with others also.
**** I just spoke with Spectrum - they confirmed this is an issue - they were not aware of. Expect a firmware update at some point..
scott
Scott
Colorado_Scott is offline        Reply With Quote
Old 12-21-2011, 09:53 PM   #15
aerocal
scott
This is a subject for an entirely new thread.It generally gets confusing when you start a new topic in the middle of an existing thread.Anyway...
Checking real quick right now I cant reproduce your issue.I have a 450 that is setup that way and those settings have stayed intact as well through a couple updates.
Im a bit confused by your last statement.You talked to Spektrum(with a k) or you spoke with Horizon service? They confirmed this was an issue or they confirmed that they were not aware of this issue? Or both?
HELIFREAK !!!
Old 12-22-2011, 09:04 AM   #16
Colorado_Scott
Default I'd check your settings again..
You state.. "Checking real quick right now I cant reproduce your issue."
That's great - perhaps you don't have the issue - but Horizon confirmed this on their DX8 transmitters. They were not aware of this, but tried it when I was on the phone with them. They saw the same issue. I'd check your's again.. set L/R Trims to Pitch and Throttle - not sure it matters which one. Turn your Tx off, then back on and check settings again. If you are running 2.04 - one or the other, perhaps both, will not be there.
Not sure why your Tx would be different than mine of Horizons - fact is, they turned in a 'trouble ticket' on this and it will be solved in future firmware updates.
Or, Sorry, Horizon Service.. they were contacting the Spektrum group.
Both.. but clearly not an issue with your Tx.. which I find strange..
Scott
Old 12-22-2011, 02:17 PM   #17
aerocal
Scott
Thanks for clarifying.Its not so strange that sometimes these things dont show up with all units.If you did clearly identify it with HH Im sure they will have a remedy quickly.
HELIFREAK !!!
Old 12-23-2011, 10:55 AM   #18
Colorado_Scott
Yes, they got a DX8, set it up like to told them, turned it off, then back on, and the settings for LTrim and RTrim were not there.. they tested and saw the problem. I'm sure also they will fix this easily - but they may wait to fix a few 'bugs' before they release another update. Fine with me, I'm not in any hurry - the Radio is working fine, but I'd use this function if I could.
sc
Scott
Old 12-23-2011, 07:05 PM   #19
aerocal
Scott
Thanks for the info.Like I said I used the thr/pit trims in a model and after you said something I tried several configurations to try to reproduce.Im just curious why I didnt stumble upon it before.
Could you PM me the model file? Change the name to .txt if it wont let you attach and Ill change it back when I get it.Thanks.
HELIFREAK !!!
