Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > AHF Aeolus
AHF Aeolus AHF Helicopter Support
Old 12-19-2011, 11:15 PM   #1
BC
Default FBL conversion?
Hi, is there a kit or conversion for the aeolus 50? I have the 50 GF kit.
thanks
BC is offline        Reply With Quote
Old 12-20-2011, 12:26 AM   #2
Geffect
Yes, AHF do a FBL conversion kit:
http://www.hobby-wing.com/aeolus-fbl-head.html
Geffect is offline        Reply With Quote
Old 12-20-2011, 02:59 PM   #3
Raptor30_V1
Default A50 GF FBL
Hello,
I have a FBL RJX50 head on one of my Aeolus A50 GF. Using a BeastX works fine so far, even though I still prefer to use my flybarred birds (eq. with CSM Cyclocks).
I recently bought the genuine FBL rotorhead from AHF for my electric E50, parts of the FBL-head made a very good impression, the only mod chosen being the KBDD-dampers. Haven't flown yet the AHF FBL-head, but will do its job ..
Best Regards,
Oliver
P.S: Hobby-wing has them at a very fair price
Raptor30_V1 is offline        Reply With Quote
Old 12-20-2011, 04:57 PM   #4
Geffect
Would an Align FBL head fit the Aeolus? That might be another option too..
Old 12-20-2011, 08:20 PM   #5
Peter
yeah , it would..
but having ALIGN plastered all over a decent heli would be a bit sad , I'd think ...
Peter .... Furion 6 FBL ; E,N and G Whiplash FBL ; 2 Spectra G FBL ; Stratus FBL ;MA Extreme+E Razor+N Razor +Fury 55 FBL;xcell 60+xcell 70: TSA 700N & G; TSA 600N Pro & Platinum ; All BeastX ; guided by XPS .
Peter is offline        Reply With Quote
Old 12-21-2011, 02:52 AM   #6
Geffect
Originally Posted by Peter View Post
yeah , it would..
Absolutely
Old 01-27-2012, 01:53 PM   #7
Raptor30_V1
Default AHF FBL rotorhead
Hello,
Let me just give you an upgrade on the AHF-FBL rotorhead. The quality of the head is good, the only dislike are the linkages from the swashplate to the main blade grips..
- the first ones supplied are commonly used 2mm rods .. (w/ 2.2mm thread)
- the ones added later as an upgrade are way stiffer w/ rod diameter about 2.5mm ..
The only problem w/ this stiffer linkages is, that:
1.) the thread is still 2.2mm to use the standard rod and compared to the unthreaded part of the linkage w/ 3mm this means a questionable zone with high tensions and prone to failures (where the heck do Chinese developers learn about mechanical design ?)
2.) this *enhanced linkages* are to large, not much, but some 2-3mm on each side to get your Zero-degree alignement.
To solve the matter, either:
a.) buy ALIGN's HN7100AT linkages - but rods will be 5mm instead of 4.75mm - need to buy rods w/ 4.75mm whole size (Mikado/ Vario etc.)
b.) following a buddy, the FBL-linkages from the rave ENV90 does the job
If you found a different solution, please feel free to share it.
Best Regards,
Oliver
