Go Back   HeliFreak > R/C Electronics Support > Thunder Tiger GT5 FBL System
Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics
Old 12-27-2011, 11:46 AM   #1
ashleyk
Question Trim gt-5 in flight
Hi Guy's
Just a quick question, once i have set up the swash plate with a leveling tool does the gt-5 needed to be trimmed in flight or not
ashleyk is offline        Reply With Quote
Old 12-27-2011, 03:05 PM   #2
NitroAl
If everything is right on the bench then you are good to go!
CustomHeliParts/KDE TRex 700N
ThunderTiger X50 FBL
Ely.Q Vision 90
Ely.Q Vision 50
NitroAl is offline        Reply With Quote
Old 12-28-2011, 05:21 AM   #3
ashleyk
Many thanks
kevin
Old 12-29-2011, 06:05 AM   #4
seemore74
But if you do need to trim in flight, how would that be done?
Shape 9.0, Goblin 700 (yellow & orange) , Outrage G5 all FBL** MKS Cyclics & Rudder Servos all round.
Futaba SBus Rx, Futaba 8FG** transmission
seemore74 is online now        Reply With Quote
Old 12-30-2011, 03:15 AM   #5
NitroAl
Put it in rate mode! I Have a JR 11X and have the total gain assigned to the Gyro channel, T.Lock is HH and Norm is rate mode. Other radios will be different and may need to be reversed or set below 50.
Ely.Q Vision 90
Ely.Q Vision 50
Old 12-30-2011, 02:09 PM   #6
Stolla
You cant trim in flight, it will reset on next initialization
Old 12-30-2011, 02:40 PM   #7
NitroAl
You can't trim on your radio but you can do a mechanical trim not that it's worth doing if you have set up your swash level!
Ely.Q Vision 90
Ely.Q Vision 50
Old 12-30-2011, 03:57 PM   #8
ady
NitroAI , you mentioned rate mode , on my gt5 i have my total gain on a black background , this is with norm on my gyro , does this mean she is in rate mode , and when she has a white background in total gain , she is then in HH ? cheers
ady is offline        Reply With Quote
Old 12-30-2011, 04:23 PM   #9
NitroAl
Black background is HH, It may depend on weather the channel is reversed or not!
Ely.Q Vision 90
Ely.Q Vision 50
Old 12-30-2011, 04:31 PM   #10
ady
thank you , i`ll have a fiddle , as with a standard tail gyro , its possible to see the difference between HH and rate , will this be the same on the GT5 , i`ll have a look
