Go Back   HeliFreak > R/C Helicopter Support > E-Sky Helicopters > HBFP V1/V2
HBFP V1/V2 E-Sky Honey Bee V1 & V2 Fixed Pitch
Old 12-30-2011, 04:00 PM   #41
Terrna
Originally Posted by oliverdots View Post
At a guess, and I am guessing, can't you simply undo the collet and move it inwards to push the tail gear into the motor pinion?
The collet isnt the problem here. (My thoughts)
I can push the entire shaft in, and the gear and the pinion will connect, but the problem is the other side, I can just glue the round plasticy thing (shown on two pictures), and that will probablly hold it in place, but is that safe?
Will I have problem with the thing if one day I decide to replace the tail blade?
Do I get a new shaft thingy, when I purchase new tail blade?
If so, I guess I can just glue the plastic ring thingy to the shaft, and it will work.
At least that is what I think.
Terrna is offline        Reply With Quote
Old 12-30-2011, 04:01 PM   #42
Bugster
It could well be the bearing which is there to locate the rear reduction gear shaft.
Here's a link to the housing
http://www.heliguy.com/Electric-RC-H...rotor-housing/
The rear reduction gear bearing housing should be 20mm long. If yours is shorter by 2 or 3mm then it has lost the bearing and housing at that end. There is also a small push on rubber collar that presses on to that end of the shaft to stop the shaft floating out as in your pic. I guess both of these items could be repaired with cyano and a bit of care.
Cheers, Bugster
Bugster is offline        Reply With Quote
Old 12-30-2011, 04:21 PM   #43
Terrna
I think the problem is the rubber collar, it fell kinda fell off, and now its loose after I pushed it back in.
What is "cyano"?
Also, IF I buy a new "Tail rotor housing", will the little rubber collar come with the package?
I am woundering this for the future
Old 12-30-2011, 04:29 PM   #44
Bugster
What is "cyano"?
Sorry, it's superglue.
Take a look at this spare part - think it answers your question
http://www.heliguy.com/Electric-RC-H...28EK1-0217%29/
Cheers, Bugster
Old 12-30-2011, 04:34 PM   #45
Terrna
Ooo! I'll glue it later on
And yupp, answered my question perfectly !
Thank you !
Your awesome
Alan
Old 12-30-2011, 06:54 PM   #46
Steemo
Ah thanks! Didn't know that.
I knew about the [IMG] thingy, but in their original size their are something around 4928x3264, which would be too big. Though I'm not too sure if they would have turned automatically to thumbnails.
But thanks for the link, now I know where I can upload in this site ^_^
If you know any tips about my recent problem, please dont hesitate to tell me, much appreciated
There is an [IMG640] tag that automatically re-sizes images to 640x480
T-Rex 700E Pro DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro |T-Rex 500 DFC Pro mini V-Bar
T-Rex 450L Dominator | JR DSX9 9503 Mode 2
Steemo is offline        Reply With Quote
Tags
broken, hbfp v2
