Go Back   HeliFreak > R/C Electronics Support > Thunder Tiger GT5 FBL System
Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics
Old 12-31-2011, 07:06 AM   #1
Morricane
Default GT5 on T-rex 450PRO=Success(video)
I have been having my eyes on this thread for a while now and I have finaly got me a GT5.
And I must thank all of you for al the good info you have posted here
Thanks to you it has been a breeze to make all the right adjustments.
Happy new year
TEAM EastCoastHeli | www.eastcoastheli.se
Morricane is offline        Reply With Quote
Old 12-31-2011, 02:21 PM   #2
NitroAl
Nice setup and nice flying too. Good to hear you are happy with the G-T5 on that little pocket rocket!
CustomHeliParts/KDE TRex 700N
ThunderTiger X50 FBL
Ely.Q Vision 90
Ely.Q Vision 50
NitroAl is offline        Reply With Quote
Old 12-31-2011, 07:09 PM   #3
jockstrap
Yea - nice flying - I wish I could fly like that..
I noticed you used the extended antirotation tray to mount it.. so do you have enough room to "tap" in there - must be tight ?
DX7 Mode-1 | 450 pro 6s | 450 pro | Schweizer 300C Gasser Scale | T-Rex550e | Aeolus 50 | HeliX T-Rex700 fbl Gasser | HWC600 Gasser | Henseleit MPXLe | Henseleit 3DNT | Suzi-Janis 700 | Gaui NX4 | Gaui X5 | Blade 350QX
jockstrap is offline        Reply With Quote
Old 01-01-2012, 06:19 AM   #4
Morricane
Thanks guys
Yes it's a bit tight, so I have to use my little finger to tap
Old 01-10-2012, 09:56 AM   #5
sbc
Could I trouble you for your values in your GT-5? Thanks.
sbc is offline        Reply With Quote
Old 01-10-2012, 02:56 PM   #6
Morricane
I'll be glad to share my settings.
Note: The balls on the swash servos arms are 11mm from the center.
So I guess that the most intresting settings are those in the P/I menue for the
swash.
P=95
I=73
I/D=80
D stick=35
feed=100
I-limit=25
hoover=3
Tail settings
P=67
I=70
D Stick=23
The rest of the settings for the tail didn't I change.
I had to increase the values for the main rotor in the swash menue.
Aileron=120
Elevator=110
Pitch=115
Old 01-10-2012, 11:51 PM   #7
sbc
Thank you! I did not know you could get the P & I for cyclic up so high! I think I hit the limits at about 65 or so. The ball links are 12.5mm on my HS-5065s. My Trex450 is the older non-Pro version.
Old 01-11-2012, 02:29 AM   #8
swalko
How high you may raise P/I values on same helicopter depends most on how much cyclic throw you have (in G-T5 menu), servo speed and total gain value. Sample:
Total gain / cyclic throw in degrees (in menu) / P / I
1.) 100/8/100/100
2.) 100/10/75/75
3.) 125/6/100/100
There are other factors (blades, ... ), but Total gain / cyclic throw in degrees (in menu) / P / I are the most important on same helicopter with same setup.
swalko is offline        Reply With Quote
Old 01-16-2012, 10:36 PM   #9
sbc
Thumbs up
This is very useful info! Thanks! I learn something everyday.
Old 11-16-2012, 08:45 AM   #10
Bladecpnitro
Happy new year
http://www.youtube.com/watch?v=EqEiCsVU5WU
Very nice setup. Did you have to extend any of the cyclic servo leads to reach to the GT-5?
Taranis X9D+ - Trex 550E-TT- 12S Scorpion 4025-650 - MicroBeast - 450 Pro - 4S - Scorpion 2221-10 - GauiX3 is here! If its fixed don't break it!
Bladecpnitro is online now        Reply With Quote
Old 12-09-2012, 12:34 PM   #11
Morricane
Yes I did extend the wires from the swash servos. But it's not necessary if you install the GT5 on the right side of the heli with the wires facing forward.
