| Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics |
I have been having my eyes on this thread for a while now and I have finaly got me a GT5.
And I must thank all of you for al the good info you have posted here ![]() Thanks to you it has been a breeze to make all the right adjustments. Happy new year
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. TEAM EastCoastHeli | To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Nice setup and nice flying too. Good to hear you are happy with the G-T5 on that little pocket rocket!
CustomHeliParts/KDE TRex 700N ThunderTiger X50 FBL Ely.Q Vision 90 Ely.Q Vision 50 |
Yea - nice flying - I wish I could fly like that..
I noticed you used the extended antirotation tray to mount it.. so do you have enough room to "tap" in there - must be tight ?
DX7 Mode-1 | T-Rex 250 | EP200SE V2 | Tricopter | Quadcopter 450 pro 6s fbl 3X1000 | 450 pro fbl beastx | Schweizer 300C Gasser Scale |T-Rex550e 600 vbar | Aeolus 50 HeliX T-Rex700 fbl Gasser | HWC600 321puh Gasser fbl| Henseleit TDR |
Thanks guys
Yes it's a bit tight, so I have to use my little finger to tap
Could I trouble you for your values in your GT-5? Thanks.
#6 |
I'll be glad to share my settings.
Note: The balls on the swash servos arms are 11mm from the center. So I guess that the most intresting settings are those in the P/I menue for the swash. P=95 I=73 I/D=80 D stick=35 feed=100 I-limit=25 hoover=3 Tail settings P=67 I=70 D Stick=23 The rest of the settings for the tail didn't I change. I had to increase the values for the main rotor in the swash menue. Aileron=120 Elevator=110 Pitch=115 |
#7 |
Thank you! I did not know you could get the P & I for cyclic up so high! I think I hit the limits at about 65 or so. The ball links are 12.5mm on my HS-5065s. My Trex450 is the older non-Pro version.
#8 | |
Total gain / cyclic throw in degrees (in menu) / P / I 1.) 100/8/100/100 2.) 100/10/75/75 3.) 125/6/100/100 ... There are other factors (blades, ... ), but Total gain / cyclic throw in degrees (in menu) / P / I are the most important on same helicopter with same setup. |
#9 |
This is very useful info! Thanks! I learn something everyday.
#10 | |
Very nice setup. Did you have to extend any of the cyclic servo leads to reach to the GT-5?
DX 7, EXI 450 FBL GT-5, HK 250 FB Quark, Nano Brushless 16500KV 125mm boom To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. (!) |
#11 |
Yes I did extend the wires from the swash servos. But it's not necessary if you install the GT5 on the right side of the heli with the wires facing forward.
