| Belt CP E-Sky Belt CP |
#21 |
Stripped SK720 from Belt CP 700N and mounted it on Belt CP 6HV:
Setup the makeshift connections on the bench and run the initial wizard that mainly has to do woth SK720 orientation, Spektrum satellites binding, Tx input scaling, servo selection and so on: Selected the Futaba S9256 as a tail servo and did the operational test, the small Spektrum voltage regulator is a 2A thingy and drops the voltage down for 3 things: tail servo, ESC reference signal and telemetry module. Will have to double check TM1000 specs, maybe it can run off 8.4V directly :Andy, you were spot on !!! The tail servo as well and kicking ![]() ![]() . It was just frame rate and pulse width that made it appear dead before
Jerry Trex 700N Pro fbl, 600N Pro x 2, 450SE v1, 250 v2 fbl, Compass 6HV fbl, Blade 450x, 400, 300x, 130x, mCPx, 120SR, mQx, mSR, Rotor Concepts HPQ1, Walkera CB180Q, CB100, Novus FP, CP, Esky Hunter, Big Lama. |
#22 |
have you had your Belt CP 6HV in the air yet
Trex 500 : Atom FBL head AR7200BX | Atom 6HV : vbar 5,3 pro | Goblin 700 : vbar 5,3 pro | Goblin 500 : vbar 5,3 pro |
#23 |
Nope I haven't. Gerd had put some 30-40 flights on it before I bought it off him, then he partially disassembled it to make it fit into the original box for shipment and I never reassembled it until now when I finally have all the parts to go FBL. Mind you, that includes FBL parts for other helis as well, couldn't stomach the idea of leaving Belt 700N crippled for example, so it's got a nice MB+CP2 combo now awaiting installation.
BTW, Belt 6HV parts are much more difficult to get than Belt CP's so I'll have to be really careful flying it. Also, it makes me thinking that my next Belt should be Align variety ![]()
#24 | |
TDR - Logo 600SE + 500SE + 400 - Furion 450 6S mini-V - 300X - 2 x mCPX - Schluter Bell Huey Cobra '74 - Aura 4 hotliner FAI world record longest electric RC heli flight: 1h 46m 22s |
#25 |
I'll try to beat you to maiden, Raf
In the meantime, I have corrected the thread name, an obvious error that was causing a stress to some mods. Mods, apologies for the original confusion, must be the age related thing Tom's talking about all the time that's finally getting to yours truly:
#26 |
Sure,,, that's right,,, drag me into it.
Avant Aurora 90n,Trex 600E Pro, HC500, HDX450sev4, Trex 250se, mCP-X & mSR, Mosquito, X/A Hexa/WKM/FPV, 450 Flame Wheel,Gaui 330X |
#27 |
Sorry Pops
#28 |
Another C- on your report card, son? Gonna have to do better or your grounded!
#29 |
Belt CP V6, lol, I know some people at Compass headquarters who won't be very happy now...
#30 |
The Capi - HF Support
What lipos you planning to use on the 6hv ?
SAB Heli Canada / RotorQuest/Compass Team KBDD Spreading capibara awareness since 2006 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#31 |
if you haven't made your batt choice the I would recomend Turnigy 3000 A 40C , link , nano-tech are good but to my expirience i feel like they don't last long even when they are never gone under 20%
#32 |
Already got 2 sets of 2 * Hyperion VX G3 6S 2600mAh 35C and one set of 2 * V-Plus XP 6S 2600mAh 30C, expecting to see 7-8 min of flight time with my mild sports flying, planning to drop head RPM to about 1800-1900RPM, not sure how well the HW 70A-HV will work at these speeds, though.
#33 | |
#34 |
I am running 3300 packs with the stock pinion and get around 5-6min.
#35 |
What HS are you running it at, Dominic?
#36 |
No clue, using the stock pinion at 100% flat.
#37 |
http://www.helifreak.com/showthread.php?t=232574
Here's your answer guys. Some measurements with my stock 6HV. Sportflying for 8 and a half minutes at most, if you don't push it hard of course.
#38 |
Once upon a time we calculated with Raf that the flight time was inversely proportional to the HS, he did also a bunch of of tests on a 450, practically a straight line dependency. He's also got his Logo 600 to fly for some absurdly long times of >40 min by adding extra packs and lowering HS to the brink of instability.
On 6HV's 10T pinion, 104T main gear and stock 540 kv motor 100% throttle translates in about 2100 RPM considering about 90% motor efficiency. If you're getting 6 min out of 3300 packs I'll need to drop the HS to about 1700 RPM just to get the same 6 min. Of course putting around the sky (my skill level) vs stick banging (NOT my skill level) may give me another minute or even two... ![]()
#39 |
This darn 6HV is being a nightmare to fit the electronics on
, you'd think there is enough space on a 600, right? Think again, the frame is actually narrower than on my original TR450SE, no kidding. Almost got it sorted out, but still not finished, maybe it wasn't meant for the list of electronics that I'm fitting on it:
!!! So I need to feed it from 5.2V side of the regulator ![]()
#40 |
It's a very narrow frame indeed, which makes it excellent in terms of agility, all the mass is concentrated, but you're right about the downside: no room to fit much stuff, best to keep it as simple as ever possible. You could forget about the telemetry for example ?
