Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Genius CP
Genius CP Walkera Genius CP Helicopter Support
Old 01-04-2012, 10:11 PM   #1
dgibbons
Default Charging Batteries
My brushed genius will be arriving tomorrow. 2801 pro is programmed & batteries are on their way.
What's the best way to charge the stock & hyperion batt's. Wow was out of the charging cable. I have a Bantam BC6DX.
Thanks for the help.
dgibbons is offline        Reply With Quote
Old 01-04-2012, 10:34 PM   #2
sebo
clubheli has a 6S adapter
http://www.clubheli.com/6S-Serial-Ch...XH_p_2819.html
i'd remove the stock connector and use some other type of plug like micro dean. the only thing is when charging in series the cells have to be the same capacity. imo it's better to charge them this way in balance configuration rather than parallel.
sebo is offline        Reply With Quote
Old 01-04-2012, 10:39 PM   #3
Scott Bowersox
for the hyperions, I would get this parallel adapter to charge up to 6 at a time with your bantam. http://www.allerc.com/hyperion-6-por...ly-p-5360.html
The connectors are different than the stock walkera ones. Either make a small adapter cable to use both types or switch out the connectors to the same type of whatever your preference is
Hope that helps
The knack of flying lies in learning to throw yourself at the ground, and miss. Clearly, it is this second part, the missing, that presents the difficulties.
Team Compass Pilot
Scott Bowersox is offline        Reply With Quote
Old 01-04-2012, 10:43 PM   #4
Scott Bowersox
[QUOTE=sebo;3526187]clubheli has a 6S adapter
That's a handy little thing there too!
Team Compass Pilot
Old 01-04-2012, 11:29 PM   #5
dgibbons
Thanks for the replies. So, if I'm running 3 1s batteries 240 mah I would set the charger @ 3s & 720 mah?
I have a charge cable that should be arriving soon. The hyperion & the one from clubheli both look nice. Thanks for the links.
USPS says the genius will be delivered tomorrow & I'm trying to avoid being grounded due to no charged batt's.
Old 01-05-2012, 10:25 AM   #6
crf69
the hyperions can be charged at 5c
3.6 amps for 3 cell's.=5-6 minutes
i do mine at 1c though do be safe on these little guys.
gainzzz-r-us
crf69 is online now        Reply With Quote
Old 01-05-2012, 12:11 PM   #7
shastamike
A little reading about charging and caring for the Hyp 240's.
http://media.hyperion.hk/dn/g3lipo/ scroll down to the charge and care part.
BTW lots of parts to keep you grounded. I get caught all the time waiting for:
servos
tail booms
main motors
Enjoy your G CP and keep your credit card handy! Good flying to you.
Mike
shastamike is offline        Reply With Quote
Old 01-07-2012, 09:19 AM   #8
bytemuncher
I use these pigtails from Hobbyking because they are cheap and easy to change to micro deans http://www.hobbyking.com/hobbyking/s...dProduct=10621.
The hyperion charging chart is very convenient as a reference. http://www.hyperion.hk/dn/g3lipo/lgum6p.htm
ID:	278779   Click image for larger version
ID:	278780   Click image for larger version
bytemuncher is offline        Reply With Quote
Old 01-07-2012, 11:53 AM   #9
bytemuncher
I'm curious how you can get 5-6 minutes charge times? The best I can get is 12 minutes charging a hyperion 240 in fast mode (using accucel 6) at 6c (~1.4amp for one battery).
Old 01-07-2012, 02:16 PM   #10
crf69
gainzzz-r-us
Old 01-07-2012, 10:02 PM   #11
bytemuncher
Hi Crf,
Did you post a link...I can only see a book icon?
