Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters > TRM Power
TRM Power TRM Power - Toxic Al Factory Support Forum Worldwide. Any Product.
Old 01-06-2012, 12:47 PM   #1
Doug Darby
Default Just finishing the breakin of my TRM VX231PUH Stage 1-RS
I have 10 flights of 10 minutes each on my new motor keeping the RPM's down between 10,600 and 10,900. As stated in the breakin I have let the engine case cool to ambient after each flight prior to firing the motor for the next flight.
Looking in my gallon of breakin fuel I probably have 3 tanks of fuel left for that gallon. When can I increase the RPM to the 12,750 to 13,700 operating range stated in my instructions?
I assume I can do so as soon as I have run the gallon through it and get it set to run on my Fully Synthetic blend.
doug
Doug Darby is offline        Reply With Quote
Old 01-07-2012, 07:40 PM   #2
Toxic Al
Hi Doug, you can start to increase you rpms after the first tank or so of the synthetic mix, but i would not bring them up to full rpm right away. bring it up about 500 rpm each tank until you get to the desired rpm. keep checking to plug to make sure it is not to lean. by the end of the second gallon you should be at consist high rpms. call me if you have any ? have fun peace, Al
Toxic Al is offline        Reply With Quote
Old 01-07-2012, 09:18 PM   #3
Doug Darby
Thanks Al!!!
Will do!
doug
Old 01-07-2012, 09:20 PM   #4
Toxic Al
anytime,call me again with any questions or problems. Peace, Al
Old 03-17-2012, 08:54 PM   #5
PeterW
I'm on the other end, are very nervous about it ...........
I am about to start my 23cc TRM and read everything I come across
Can I run the engine with governern active or not?
PeterW is offline        Reply With Quote
Old 03-17-2012, 09:42 PM   #6
Doug Darby
The key is to keep the RPM's down during breakin and to slowly increase the load on the engine.
I used the gov to make sure I knew where the RPM was and my breakin went exceptionally.
Also remember to allow the engine to cool in between flights.
doug
Old 04-21-2012, 02:40 PM   #7
PeterW
Today I start the engine for the first time, stable and smooth idle.
Did not fly when there was a strong wind but a few minutes at idle to see if everything works.
May I ask what RPM you ran on the först tank (1600)?
Old 04-21-2012, 03:26 PM   #8
Toxic Al
1600 is fine, keep the rpms lower then peak for a while, you can change to 1700 or so after few tanks but don't stay there toglle back and forth between them every 5 minutes or around there so the motor will gently heat cycle it self. Peace, Al
Old 08-08-2012, 05:34 PM   #9
PeterW
Has a TRM23RS who made 15 flights, I am so happy and it goes really well
Old 08-09-2012, 07:53 AM   #10
Doug Darby
I have 3 TRM motors and I am extremely happy with all of them.
doug
Old 08-20-2012, 05:11 PM   #11
Toxic Al
Great news Peter, keep it up. Any ? don't hesitate to call. Peace, AL
Old 11-11-2012, 06:07 PM   #12
PeterW
Just finishing the breakin of my 23cc and I am sooooo
Everything has worked well all the time, thanks Al
