Old 08-19-2014, 06:47 PM   #61
Xrayted
I don't have any of mine personally, but these are pretty much what is does. It will roll the heli either upright or self level inverted if you set it that way. You can set the flight control rates in degrees per second, and that is also how fast the heli will flip itself upright. Flying with SL on all of the time will make the heli fly like a coaxial and it will constantly try and keep itself upright. You can also set it to SL as soon as your release the sticks to neutral.
I can switch between normal flight and SL while in hover and the heli will sit level all on its own. Flipping into SL while moving in FFF will level the heli, but will not stop its forward inertia. You will need the GPS unit if you want the heli to rescue itself and lock into position.
You will need to be more specific as to what you are wanting to know if these videos don't show you what you need.
Tony
Goblin Speed, Ikon2, HW 200HV / Blade 180 CFX / The girl in my DX9 tells them what to do
Xrayted is online now        Reply With Quote
Old 04-03-2015, 11:46 AM   #62
lfedje
The instructions say, mount as close as possible to the COG. I am getting a 720 black edition and am considering mounting it on my Goblin 380. The only place to put it will be aft of the servos on the designated mounting plate. It's not all that important to me that this works, but if it does, it would be a nice feature.
Is the location I described close enough.
Oxy 3 4S Stretch Brain, 2 - Protos 380 Evo's, Jeti DS-16, Heli-X (wireless), Twisted Hobbies MXS-C
Lynx Heli Innovations - Field Rep
lfedje is online now        Reply With Quote
Old 04-03-2015, 12:23 PM   #63
dpelletier
It will be fine there. Like my Goblin 500.
All my Skookums are on all the individual helicopters designated mounting plate. Beam E4, Goblin 500, Synergy E5 and Furion 6.
Futaba 14SG, Synergy E5, Furion 6, Beam E4(v1) FBL, CGY750, Skookum
dpelletier is offline        Reply With Quote
Old 04-03-2015, 12:42 PM   #64
lfedje
Just to be sure, I am talking about the SL feature. This is a big move for me changing my helis from AR7200BX to SK540 for my Oxy3's and SK720 for my Goblin 380's. A bit of a learning curve coming up.
Old 04-03-2015, 02:55 PM   #65
Xrayted
It doesn't matter. Mount it where you can. Mounting it closer to the COG will reduce lateral vibes in some cases, otherwise it serves no purpose. A gyro measures angular movement not COG, so it works the same anywhere as longs as its square with the frame.
Tony
Old 04-03-2015, 05:12 PM   #66
lfedje
Thanks, Guy's
Old 04-04-2015, 09:53 PM   #67
IamProStreet
Works just fine on my 380. Had to use some thick Zeal tape to mount it above the nylon nut. I'm not real crazy about the mounting I used so let us know how you did it to keep the plugs from hitting the servo. Couldn't use thin tape with the aluminum mounting plate because there was too much vibration transmitted that way.
IamProStreet is offline        Reply With Quote
Old 11-12-2016, 04:35 PM   #68
Bill Fleming
Hello Soko:
I'm following your directions regarding a SL switch. I've carefully followed your instruction, but when I conduct the functional test only nothing happens when F-1 is flipped. Hold isn't engaged. All my switches are inhibited. I'm suspecting an inhibited switch might be causing my problem. Would it be possible for you to send me a screen shot of your switch menu on your DX8 which is what I'm also using.
Thanks, Bill
Bill Fleming is online now        Reply With Quote
Old 11-13-2016, 02:26 AM   #69
soko
Hi Bill.
This thread and instructions is verd old as you might have seen...
With the current SK720 black edition and the newest firmware its quite easy to setup bail out, especially with the gps module.
In addition I dont use the described setup in my DX8 anymore, so I cant send you screenshots.
The best thing would be to use the Monitor screen on your DX8 to see if the channel values change with the switch...
if yes: your problem is in the Skookum
if no: yourre havin an issue in the DX8 -> take some screenshots and post them here
Soko
The future of setup... now! Soko Heli Toolbox app for a next generation setup experience.
ONE tool for ALL setups of ALL sizes and ALL brands of helis
www.soko-heli-tools.com
soko is offline        Reply With Quote
