Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > 4G3
4G3 Walkera 4G3 Helicopter Support
Old 01-08-2012, 08:51 PM   #1
RacingRay
Default Brushless tail wont spin on novus cp/4g3
I started with a brand new Heli-Max 2g brushless tail upgrade with the heli-max tail ESC for the Novus CP, got everything wired up correctly (triple checked), powered it up, heard the ESC beeps, but upon giving it throttle the tail rotor just barely blips back and forth, harldly moving a couple millimeters. So I figure the crappy 2g motor is bad and I buy a 2.9g motor from wow and it's doing the same thing! Could the new heli-max ESC be bad? What other ESC available with the one source wire? Any help/ideas would be apprieciated.
RacingRay is offline        Reply With Quote
Old 01-28-2012, 07:17 AM   #2
yhhyun
Default try this
in throttle curve set,
set the throttle value as 0 at the lowest stick position.
Try this!
yhhyun is offline        Reply With Quote
Old 04-28-2012, 07:04 PM   #3
walkera4g3
Try this!
+1
walkera4g3 is offline        Reply With Quote
