Go Back   HeliFreak > R/C Electronics Support > Thunder Tiger GT5 FBL System
Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics
Old 01-14-2012, 02:42 PM   #1
ady
Default tantem t-rex with gt5
Hello there , I've thrown together a tandem made from a couple of Rex 550 's , many parts are tarot tho , I'm using a helitonix mixer and another gt5 . I have had a quick garden hop in the dark but was not really the best way to try . Had to turn all the controls done by a large amount , had massive alieron pendulum effect which wasn't nice . My last tandem had the use of two futaba 401 gyro's which made it flyable on rate mode only , i'll take it to our field tomorrow for tests and pics and a lot of adjustments , will try that total gain on both white and black backgrounds
ady is offline        Reply With Quote
Old 01-15-2012, 07:10 AM   #2
ady
Old 01-15-2012, 07:14 AM   #3
ady
well she`s hovered the elevator is a nightmare , but i`m sure i will get there , am having to fly with 0 on I on both swash and tail , gains on full all round , but its just as if the elevator gyro function isn`t working , wonder if i need some I ?
Old 01-15-2012, 07:17 AM   #4
swalko
Video is private.
swalko is offline        Reply With Quote
Old 01-15-2012, 07:18 AM   #5
ady
Old 01-15-2012, 08:03 AM   #6
swalko
Yes, you need I. I hold heli on its position, with I = 0 you get rate mode as you asked, i do not recommended you to try rate mode on cyclic . Please set your video as public, i am interrested.
Old 01-15-2012, 08:29 AM   #7
ady
hi , the video is now public , why it went private ? anyhow , i`m gonna try turning I up on the swash in small adjustments , my former tandems never liked HH on the swash plates tho , it makes for something different to the norm , just gotta dial her in
Old 01-15-2012, 08:42 AM   #8
ady
what i`m trying to work out that once switched on you can see no gyro compensation on the elevator , on my pro , you can see the gyro working , on the tandem i can`t ? the unit works thru the helitronix mixer , elevator is thru DCP mix , so to move forward , the rear swash lifts and the front drops , the tail/yaw is very easy to see
Old 01-17-2012, 12:27 PM   #9
ady
good evening everyone , i have factory reset the unit , set the usual in the gt unit and have turned off the I setting in the tail to make that rate mode, i have left the unit in NITRO , do you you thing this helps with vibration , the reason is , at the weekend , i could not get it off the deck without the swashes cranking over , i`ve done a bench run , with a different foam , this time the swashes do not move , i`ve also removed the skid tubes . so on the filter front , is 0 or is it 5 for best vibration filtering please
Old 01-17-2012, 12:28 PM   #10
ady
Old 01-17-2012, 01:44 PM   #11
swalko
Based on the info from manual v2 strongest vibration filter is 0.
Old 01-17-2012, 02:41 PM   #12
ady
Cheers , just needed to read it again , the hover or Hoover setting as they put it , 5 is max ?
Old 01-17-2012, 02:43 PM   #13
mrultralite
I'm a newbie ignoramous but the head speed seems really high [feel free to ignore]
mrultralite is offline        Reply With Quote
Old 01-17-2012, 03:25 PM   #14
ady
Hi , the bench headspeed with no load sounds worse than it is but if you mean the hover video , the headspeed I'm working on , the 520 blades needed some speed to get lift , on earlier versions , I used larger blades but that loaded the little umbrella gear to much and stripped , i'll never ignore any comment cos you might spot something I may miss
Old 01-17-2012, 03:43 PM   #15
swalko
Yes 5 is maximum stability.
Old 01-17-2012, 04:19 PM   #16
Jomaba4308
How do you get the timing right between the heads so the blades don't hit each other?
Sent from my C771 using Tapatalk
MSH Protos 500 GT-5 FBL, Trex 450 Pro 3G FBL,
TT Mini Titan v1, Blade MCP-X. - Spektrum DX8
Jomaba4308 is offline        Reply With Quote
Old 01-18-2012, 02:01 AM   #17
ady
hi , they are set 90 degrees apart , and unless the gears strip , they`ll not hit
Old 01-20-2012, 03:20 PM   #18
ady
hi , i`m just not able to get the gt5 to work on my tandem , so have removed it and fitted csm 720 gyros , so i`ll close this thread now , thanks for all your help , and i`ll still be posting my 600rpo findings as i go along . just need another heli to fit the other gt5 to now
