Old 06-05-2013, 08:54 AM   #781
matthewcornell
Default What did you do with your PRÔTOS today?
Originally Posted by tat2spyder View Post
got to try out my new canopy today. Much easier to see in the air, and a little but better fit too. Fusuno took there sweet time mailing it to me, but i think it was worth the wait. Now i gotta re-paint my skids and fins to match a bit better.
I have the same one and like the visibility. Haven't had the nerve to try the classic one, which is so cool.
matthewcornell is offline        Reply With Quote
Old 06-05-2013, 08:55 AM   #782
matthewcornell
Originally Posted by desertstalker View Post
The pinion will wear out, check it every 50-100 flights and replace as needed.
What do you look for? Wobble or play when spinning by hand?
Old 06-05-2013, 08:57 AM   #783
matthewcornell
Originally Posted by banditpowdercoat View Post
Gotta love it when your reflexes suprise you
Well put. I had this happen on my 450 within I swear two inches of the ground. Didn't even think, just saved it.
Old 06-05-2013, 08:58 AM   #784
matthewcornell
Originally Posted by spacecowboyz View Post
Pack three went out and flew could not get in the groove of it couldn't Controll my shaking and had to use captain rescue on heli command quit a few times.
How do you like using it?
Old 06-05-2013, 01:08 PM   #785
Dr. M
Pinion checks: take it off and inspect the rollers; inspect the motor shaft adapter too. Put it back on and verify it spins freely in one direction and locks in the other.
I don't think these wear off as fast as suggested. Mine (15t) has almost 200 flights and shows no signs of getting tired. Early on in the Protos days, the small pinions (12-13T) used to break and or seize, but that problem has long since been addressed.
Fly first ask questions later.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
MSH PRÔTOS 500 FBL "Sky Whip" | ZYX v4.0
Audacity P6 FBL "Phoenix" | MSH Brain | 12s e-conversion
Dr. M is offline        Reply With Quote
Old 06-08-2013, 06:20 PM   #786
spacecowboyz
Flew six packs thru it nice and mellow flips and rolls getting used to going from 10 deg of cyclic to 13 some none in monovers and the best thing of all brought it home in one piece. Tightend the tail belt
spacecowboyz is offline        Reply With Quote
Old 06-10-2013, 08:48 AM   #787
banditpowdercoat
2 packs last night and knees were shakin like I was a noob again No Idea why. Wasnt pushing myself to hard, Some high speed Stall and Piro turns over the valley.
Still can't get Tic Toc controls down. I can do it in SIM really well. She stays put. But seems more like short fast rainbows with my Protos, and allways drifting with the tail rotor push.
Dan Pesonen
FBL, Don't think about it, DO IT.
mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS
"Tri-Flow"
I put that S*** on everything!"
banditpowdercoat is offline        Reply With Quote
Old 06-10-2013, 08:53 AM   #788
matthewcornell
Same boat here. I've been working on my 450 a lot, starting out with it to warm up, and the Protos seems a lot of heli. Maybe I need to do more close-in work, rather than the high-speed sport flying I also enjoy. Still not used to a big bird, I guess. Let's stick together!
Old 06-10-2013, 11:35 AM   #789
Jumna
Rebuilt three servos. On to the head and servo frames. Totally lost orientation practicing piroflips a bit too distant. I'm going to switch to a hollow shaft while I'm at it and see if that gives it some more responsiveness.
MSH Prôtos, Trex 450 Pro EXI, mcpx, sr
some planks
dx8, phoenix
Jumna is offline        Reply With Quote
Old 06-13-2013, 12:06 PM   #790
mkovalcson
I recieved my MKS metal gearsets for my Futaba 9660 servos which I hope to install shortly.
I remember trying to get a set of these and only finding 9660A+ gears a while back which of course didn't fit.
http://www.mksservosusa.com/product....&cat=12&page=1
Henseleit TDR, Synergy E5, MSH PROTOS 500, 300X
Jeti DS-16, FMA PL8, Skookum, Kontroniks, JLog2's
mkovalcson is online now        Reply With Quote
Old 06-13-2013, 02:20 PM   #791
alexf1852
I thought these were not being made anymore. Let us know how they fit. My 9650 servos have them but they've developed a little bit of play after hundreds of flights.
MSH Protos * 2, SAB 630
alexf1852 is offline        Reply With Quote
Old 06-14-2013, 07:20 AM   #792
mkovalcson
I thought so too!
There was a thread on the main page a while ago about servos and someone gave me this link.
It may be next week before I get a chance to install them.
Old 06-16-2013, 02:59 AM   #793
spacecowboyz
Changed to a 12 t pinion and set the hs to 23 24 25
Old 06-17-2013, 08:30 PM   #794
Jumna
Rebuilt (servo blocks, lower block, main gear, servo gears!) and added a nice orange Lynx vertical fin. All that mess but didn't crack the curtis main blades or grips...!
some planks
dx8, phoenix
Old 06-18-2013, 01:12 AM   #795
pani
Down to a 13 from a 14 pinion. Gov store now at 1700 2000 and 2400.
pani is offline        Reply With Quote
Old Yesterday, 09:59 PM   #796
banditpowdercoat
Another 4 great flights. Still cant keep my sideways from traveling in flips, rainbows tic tocs etc. But started on funnels. Just kinda pitched the heli sideways and did a 1/2 circle tail in. Bout 10ft radius. Went back and forth, faster and such. Now to keep on that in the sim, see where it takes me. Was real comfortable witht he 1/2 circle, bout a 30* bank nose up
Oh and balanced my tails and mains. Usually Edge have been pretty spot on. I have been using a see saw style balancer. But this time, I did the balance on a razor to find CG. Then make the CG the same and balanced them on the head. Took A LOT of tape. 1 full wrap electrical tape to get CG the same, then 1 wrap and 1/2" more at CG on other blade to get them balanced. Way out. But holly crap, so much smoother. Upped tail gain 3% I think I can go more too
Dan Pesonen
"Tri-Flow"
Old Today, 01:24 AM   #797
ddhuans
Nothing to do with my P500 today, just leave it on the wall )
Align T-Rex 500EFL Pro: Scorpion motor, Align servos, Castle Creations ESC, BeastX µB
MSH Prôtos 500: Scorpion motor, Hitec&Futaba servos, YGE ESC, BeastX
µB
Mikado Logo 500SE: Scorpion motor, Savox servos, YGE ESC,
BeastX µB
ddhuans is offline        Reply With Quote
