Go Back   HeliFreak > R/C Helicopter Support > Beam E4
Beam E4 Beam E4 Support Forum
Old 01-15-2012, 03:16 PM   #1
Spork01
Question main gear mod
I decided to give the beam e4 v2 a go. I have the align 450mx motor with the 15T pinion. What mod is the main gear? I was looking at the spare parts listed at amainhobbies and saw they have 15T pinion available.
Is the main gear spacing the same as align?
Trex 450 Pro V2 FB spartan quark
trex 250 beastx
Fusion 50 beastX
Spork01 is offline        Reply With Quote
Old 01-15-2012, 03:30 PM   #2
Spork01
I'm going to use hitec hs65hb's on cyclic and futaba 9257 for the tail. Do I need to buy any special adapters to mount the tail servo within the frame?
trex 250 beastx
Fusion 50 beastX
Old 01-17-2012, 12:37 PM   #3
Inverse
On the Advance, no.
9254 will slot straight in.
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Prôtos 500 - MSH Brain
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote
Old 01-20-2012, 01:59 PM   #4
slowflow
Same pinion as align 450.
slowflow is offline        Reply With Quote
Old 01-31-2012, 06:21 PM   #5
Fabien
Hi,
be carefull with mixing up other brand's motor pinons, the teeth cut might not be the same as the Beam ones, not because of different modules used, but depending on the number of teeth of the main gear, then there is a tooth profile to modify depending on the motor pinion (Addendum / dedundum). If with a Align pinion you experience excessive wear of the main gear, you will then need a Beam one
Best regards,
Fabien
Fabien is offline        Reply With Quote
