Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Old 01-23-2012, 09:43 PM   #1
coopercobra03
Default Does This Look Normal?
This is from using a 1/2 gallon of fuel using Klotz Super Techniplate with Castor oil!
Piston looks horrible! Could this be from the castor oil? I'm using a 32:1 mix...
ID:	283354   Click image for larger version
coopercobra03 is offline        Reply With Quote
Old 01-24-2012, 12:27 AM   #2
rbort
Default Castor is dirty
Never use it in any motor. I used Blenzall oil with castor when I first started in 1997 with gassers and it was terrible, didn't even finish the gallon decided to move on to Yamalube and it was a much better oil at the time. Nowadays the oil of choice is Penzall Marine fully synthetic recommended by Chris Bergen.
-=>Raja.
1005 Xcell Autorotation Queen, Hanson G26 3D Max, 3334 flights
Spectra-g, Hanson 270 3D Max, 2202 flights
Whiplash-g 88.9mph Speed Cup Record, Hanson 270 3D Max, 280 flights
Jewel on-board Generators, Team Miniature Aircraft, Team Helicommand
rbort is offline        Reply With Quote
Old 01-24-2012, 07:12 AM   #3
carey shurley
Nowadays the oil of choice is Pennzoil Marine fully synthetic
I suspect AMSoil Sabre 100 is still the most popular oil being used, its much easier to find and less expensive.
STOP using the castor
Carey Shurley
carey shurley is online now        Reply With Quote
Old 01-24-2012, 10:22 AM   #4
rbort
Default Yes Carey
Amsoil works quite well I used over 3 gallons of it however I decided to try Penzoil Marine and after so,me time Hanson actually said that my motors come back cleaner to him when Penzoil than they did with Amsoil.
As a disclaimer I didn't have any operating issues with the motors either way, but I can see myself that the piston top is much cleaner when I peek through with a flashlight.
You could try it sometime to see if you like it better, or just use what you know works for you. Trouble is with Penzoil you need to get it in gallon containers, but that's not an issue for me I buy it 3 gallons at a time and shipped to my door its cheaper than Amsoil at dealer cost. The stuff doesn't go bad but if you're not going to use that much oil you could split it with Al and Ricky for example.
All the best, and we got FL weather here today, 54F snow is almost gone!
-=>Raja.
Old 01-24-2012, 10:53 AM   #5
carey shurley
I'll wait to hear more about the final verdict on muffler clogging with that stuff.
Carey Shurley
Old 01-24-2012, 12:06 PM   #6
Toxic Al
The castor is very dirty(high ash content) can cause rings to stick in the land which can make it hard to start. I would recommend a full synthetic without castor, amzoil, pensoil or equivelant. Peace, Al
Toxic Al is offline        Reply With Quote
Old 01-24-2012, 06:19 PM   #7
coopercobra03
Thanks Raja, Carey, Al,
I just ordered Pennzoil 100% synthetic from West Marine today! It's funny I live in Pennsylvania and I can't find Pennzoil anywhere!
Well I guess this is why my engine won't start anymore, I definitely think my ring is stuck in the groove!
If I take the piston out and soak it some solvent (ATF or something) it should break free huh?
Or order a new piston and ring?
Old 01-24-2012, 11:50 PM   #8
rbort
Default Hold on
Get some Yamalube Ring Free and add it to your gas in the shock treatment ratio given on the bottle.
Try hard and get the motor started and then run it for at least an hour or 4 tanks through. Then run it some more the next few days until you burn the entire gas container through and you will see mprovement.as I did one time with this stuff while working on someone else's machine.
-=>Raja.
Old 01-25-2012, 02:24 PM   #9
600nitroexpress
Yeah I use the klotz R-50 syth, I dont think it has caster oil in it though,have not had any trouble with it at all very clean and hardly no smoke at 32:1 per gal. I think i will try the penz full syth when i run out of oil. Klotz is Kind of exspensive I think I paid over 50 a gal.I am running colman fuel so it smells just like kero.
600nitroexpress is offline        Reply With Quote
Old 01-25-2012, 09:30 PM   #10
coopercobra03
Well I cooked the piston in ATF outside on the grill for about an hour or so at 250F and the ring came loose.
Buffed up the piston a little to rid of the carbon! Tomorrow I'll start with the reassembly!
I hope I get my oil before the weekend so I go flying!
Old 01-28-2012, 11:41 AM   #11
coopercobra03
I got my Pennzoil and put everything back together last night! She started right up today with no problems!
It even seems she runs smoother with the Pennzoil also!
I want to thank everybody for there help!
Time to go to the field...............................
