Go Back   HeliFreak > R/C Electronics Support > Gryphon Electronics
Gryphon Electronics Gryphon Electronics Factory Support Forum
Old 01-31-2012, 11:18 PM   #1
daisydog
Default Gryphon Extreme Regulator
Does any one know if I can use the AUX port on the Gryphon Extreme Regulator to power the Switchglow?
I can't seem to find to much information about that port and what it can be used for.
joe
daisydog is offline        Reply With Quote
Old 06-14-2012, 05:31 PM   #2
Fabien
Hi Joe,
the AUX port is ONLY for the low voltage alarm optional board or integrated low voltage alarm on some switches. You shall not use it to power any device, BUT you can use a Y cable from the regulator servo or receiver outputs ( depends if you use a GVR or GSR model) to power the glow ignitor or any other device, as long as the summ of devices plugged on it do require more current than the unit can give,
BEst regards,
Fabien
Fabien is offline        Reply With Quote
Old 09-30-2012, 12:28 AM   #3
sixback
I power my gryphon little auto booster from the (-)(+) pins of the AUX port while using the signal pin for my low voltage alarm LED.
Don't see any issues with it.
sixback is offline        Reply With Quote
Old 05-15-2013, 11:47 PM   #4
banteng
Hello, I've gvr7020s, can you tell me what is exactly the voltage output on the AUX port (+ , - ).
I'm intended to use it to power the my RX. is it 5,2V output on Aux Port ?
thank you.
Trex700E DFC HV 3GX V3.1 Super Combo
Trex600EFL Pro 3GX V3.1 Super Combo
Trex450SE-V2 FBL Tarot ZYX
JR XG7
banteng is offline        Reply With Quote
