Go Back   HeliFreak > R/C Electronics Support > YGE
YGE YGE ESC Support and Discussion
Old 02-09-2012, 11:28 AM   #1
ziper_it
Default YGE V4 has vbar support?
As this is not clear from other threads, could anyone confirm if the YGE 100LV V4 has vbar support (rpm output) or if this depends from manufacturing batch?
I'm specifically referring to the one in stock at Freakware (https://www.freakware.de/shop/artike...6&wkorb_item=0).
Regards,
Francesco
ziper_it is online now        Reply With Quote
Old 02-09-2012, 12:06 PM   #2
snemi00
You will have to ask Freakware about it. The vbar support comes standard on the HV models but it is an option on the LV models.
Team RotorQuest / SAB Heli Canada
SAB Goblin 700 YGE160HV, Goblin 770 YGE160HV Scorpion 4530 14s, Goblin 500 YGE120, Logo 700 XXtreme, Protos Mini stretch 6s
snemi00 is online now        Reply With Quote
Old 02-09-2012, 03:21 PM   #3
Ecaf
The 100LV at elektrorc.com does:
http://elektrorc.com/product_info.ph...oducts_id=1314
but as snemi00 said, there is no confirmation on the one a Freakware as being V-Bar compatible. I would check with them.
elektrorc.com
mini-PRÔTOS - MSH Brain
SAB Goblin
μBeast
Ecaf is offline        Reply With Quote
Old 02-09-2012, 04:40 PM   #4
ziper_it
Thanks.
I contacted them and waiting for response. BTW I found another shop in Ireland that has stock.
Old 02-10-2012, 08:11 AM   #5
ziper_it
Dso i called Freakware to get a faster reply. Do you want to know the answer?
"This is not my part, you have to call YGE"
