Go Back   HeliFreak > R/C Helicopter Support > Beam E4
Beam E4 Beam E4 Support Forum
Old 02-11-2012, 06:47 AM   #1
mikey5003
Default Venom Lipo 7500mah
Can anyone help me out,by telling me if this battery is ok to use in a Beam E4?
http://www.ebay.com/itm/360423125185...ht_4482wt_1059
Thanks,
Mike
mikey5003 is offline        Reply With Quote
Old 02-11-2012, 05:18 PM   #2
Bluerocktj
It's too BIG. Look for a 2200mah lipo. Something like this:
http://www.hobbypartz.com/98p-25c-2200-3s1p.html
or this:
http://www.allerc.com/hyperion-g3-vx...ck-p-4539.html
Beam - "Best Expert Acquired Man" - "Beautifully Engineered Action Machine"
Bluerocktj is offline        Reply With Quote
Old 02-11-2012, 07:21 PM   #3
mikey5003
Yeah that's what i was figuring too, just wanted someone else to back it up. Thanks for the info and for your time.
Mike
Old 02-11-2012, 08:36 PM   #4
mikey5003
They are out of stock on the 2200's so these will be good no?
http://www.hobbypartz.com/98p-25c-3300-3s1p.html
Old 02-12-2012, 09:21 AM   #5
mikey5003
anyone?
Old 02-12-2012, 10:55 AM   #6
dpelletier
I have these which I really like:
Sky Lipo 2200mah
I also have those Gens Ace (currently out of stock) and can't really see any difference.
Gens Ace 2200mah
If you go bigger than these, they wont fit under the canopy, not to mention added weight.
Dany
Synergy E5 in the works
Furion 6 Flybarless, Skookum 720
Beam E4(v1) FBL, Skookum 540
dpelletier is online now        Reply With Quote
Old 02-12-2012, 11:29 AM   #7
mikey5003
Thanks for the info
Mike
Old 02-12-2012, 02:10 PM   #8
olemil
I have a couple of the Venom batteries and Zippys, they both fit nicely under the canopy and work great. The Venoms are my favorites (great amount of punch!!) but are almost 3x the cost of the Zippys. Another plus on the Zippy's is they come with the XT-60 connectors which is the type I use. I use a heavier battery to balance out my COG since my ESC is mounted in the rear under the frame.
Beam E4-(Scorpion HK-2221-6,11T pinion, Phoenix 60, HS65MG cyclics, GY520),120SR, Trex 250SE (stock) MH bottom plate,GY-520,Futaba R6106, MCPx,DX7se,Futaba 8FG Super, DJI Flamewheel F450 w/Naza/GPS, HPI Vorza on Futaba 4PL.
olemil is offline        Reply With Quote
