Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters > TRM Power
TRM Power TRM Power - Toxic Al Factory Support Forum Worldwide. Any Product.
Old 02-16-2012, 06:47 AM   #1
yowser
Default 270RC Vibration Question
Does the 270RC vibrate less at 10500 than it would at 9500? I am breaking in my unmodified 270RC and is has some vibes messing with the vbar. The first four flights went well but the 5th one tipped over and broke a blade. I know I really should send it to you Al for a balance job, I'm sure it will be there with you soon.....
I have it very rich, to the point it is leaving oil/coleman residue from the muffler. Needles are at 1 3/8 each. Spark plug is dark so not really worried about a lean issue.
MA eXcell 450 Mini VBar Blue Pro
Logo 500 mini V-bar
Compass 6HV BeastX
Heli bug 600, beast x, RJX pipe on Coleman.
yowser is offline        Reply With Quote
Old 02-16-2012, 12:30 PM   #2
Toxic Al
The richness itself can give a vibe issue if it to much,the motor will struggle on the mixture not running clean. I have seen motors run rougher at lower rpms rather then higher but it depends on a numbers of things, mixture being one of them.
The other factors are the crank( true or untrued) ,crank weight ,piston weight which can vary, tuning for a particutlar throttle curve( meaning which needle is it pulling on based on throttle curve and throttle postion).
I would recommend turning the motor up to at least 11,500 to 12K and see if there is improvement or tune it in a till the plug starts to show some dark brown and see if there is improvement at the lower rpms you mentioned.
If not let me know I will do what I can to help. Peace,Al
Toxic Al is offline        Reply With Quote
Old 02-16-2012, 08:14 PM   #3
yowser
You are good people Al. Thank you!
Logo 500 mini V-bar
Compass 6HV BeastX
