Go Back   HeliFreak > R/C Helicopter Support > JR Helicopters
JR Helicopters JR Vibe and Vigor Helicopters Discussion
Old 02-05-2013, 12:27 PM   #1
Firefighternickn
Default Vibe 50 nex mystery part question
I bought a used vibe 50nex. I took the mainshaft and the head off, and a washer fell onto the bottom bearing block. Anyone knows where this copper washer goes? I'm thinking it might sit between the gear and the bottom bearing block
God made firefighters so cops could have heroes too.
Firefighters: Chicks dig us and cops want to be like us, because we find them hot and leave them wet.
Firefighternickn is offline        Reply With Quote
Old 02-06-2013, 11:15 AM   #2
Dave Snider
It's a spacer that installs on top of the one way bearing and below the mainshaft bearing block. Is it flat or does ot have a lip? If it has a lip the lip installs down.
Dave Snider is offline        Reply With Quote
Old 02-06-2013, 12:26 PM   #3
Firefighternickn
No it wasn't the mainshaft collar. The mainshaft collar was separate. That's the one with a bolt and a set screw. The part I'm referring to is just a flat small washer yellow copper in color
Old 02-07-2013, 12:22 AM   #4
Dave Snider
I know it's not the collar, it installs on top of your one way bearing. It horizontally lines up your main gear to the pinion.
Old 02-07-2013, 02:15 AM   #5
Firefighternickn
Could you please tell me if I have it in the right place then? I don't know if you can see it. It's the brass looking washer
Old 02-07-2013, 10:30 AM   #6
Dave Snider
that looks right. sorry I was telling you wrong,In your cased and some others the spacer installs to the bottom of the one way. Most helis have that spacer in some form or another. Just make sure you have no up/down play, the main gear and pinion mesh in the same place,and the spacer installed between owb and main shaft bearing. heres a link to the manual.
http://www.jrradios.com/ProdInfo/Fil..._Manual_LR.pdf
Old 02-07-2013, 12:09 PM   #7
Firefighternickn
Dave, Thank you for all your help. I can't for the life of me find the page with that washer on it. I have the original manual in print also, but I can't locate that part anywhere to see where it goes together.
