Old 02-19-2012, 08:10 PM   #21
photocycler
Day 2: Boom supports epoxied and mounted, motor installed and a first run at belt tightening
I will probably braid wrap the remaining cyclic servos and hopefully receive the FBL head to wrap up the mechanical part of the build tomorrow
Notes:
I have only had a couple somewhat long goes at the build, but I can't have more then 4 hours into it if that.
PRÔTOS 500 CF - BeastX
MCPX
photocycler is offline        Reply With Quote
Old 02-19-2012, 10:06 PM   #22
Thalios
Starting to look real good!!
Lynx Heli Team Pilot
Prôtos CF, 130X and many others.
CarbonCore H6 650mm Wookong-M
All on DX18!
Thalios is offline        Reply With Quote
Old 02-21-2012, 09:59 PM   #23
photocycler
FBL conversion was delivered, I am now trying to find the best place for instructions on the FBL install? Finless never did a build video for the Mini so I have not seen any videos or direction for the install
I am referencing the mini manual, I see they show a thin spacer to be inserted into the hub before the dampener, I don't have these thin washers in my fbl upgrade kit, are they necessary?
Name:	Screen shot 2012-02-21 at 8.38.53 PM.png
MCPX
Old 02-22-2012, 05:38 AM   #24
pani
Hi photocycler
No washers on the inside for the 500.
pani is offline        Reply With Quote
Old 02-22-2012, 10:59 AM   #25
mattmezz
Here you go.
http://msheli.com/Manual/Vbar_conversion_r01.pdf
mattmezz is offline        Reply With Quote
Old 02-23-2012, 10:38 PM   #26
photocycler
So im stuck at a really stupid part, seems the mini manual has the mixing arms backwards so after assembling mixing arms I am now trying to remove the pin and having difficulty
anyone have a suggestion for removing the pin from the mixing arms..
MCPX
Old 02-23-2012, 11:14 PM   #27
alexf1852
I did that to one arm. I also put a pic in a thread about the new FBL kit how the arms should go Hoping others would see it and not make the same mistake I did.
To get the pin out, try using a ball link plier and a small thin nail that is used to put up small picture frame. Try to squeeze the nail and push out the pin.
Edit: Here's the link to the post with the pic:
http://www.helifreak.com/showpost.ph...88&postcount=3
MSH Protos * 2, SAB 630
alexf1852 is offline        Reply With Quote
Old 02-23-2012, 11:42 PM   #28
photocycler
Thx for that, that is where i was looking when i saw I had it backwards...I will give the ball pliers a try
MCPX
Old 02-24-2012, 10:52 PM   #29
photocycler
ok hoping to buy my tail servo and FBL unit this weekend
So the finless video showed him running the tail servo on the opposite side, is that my best bet?
MCPX
Old 02-25-2012, 12:14 AM   #30
d1esel
Mounting the tail servo on the left offers some protection against flybar, and possibly main blade impact during a crash. Place your elevator servo on the opposite side of the tail servo to help balance the heli.
Fusion 50 Skookum - Prôtos 500 VBAR - Trex 450 Pro VBAR - DX7 - PL8
d1esel is offline        Reply With Quote
Old 02-25-2012, 11:16 AM   #31
photocycler
I will be flybarless but still sounds like a good idea unless there are any negative effects of running it that way?
Also where can I find info on grounding the boom, I assume that is necessary?
MCPX
Old 02-25-2012, 04:50 PM   #32
Thalios
If you have the latest version, no need to ground the boom. (It has some lines in the plastic).
I have not grounded mine, and it works fine.
All on DX18!
Old 02-25-2012, 04:56 PM   #33
photocycler
Thx
Just got the AR7200BX home, going to work on the servo centering and get the main servo frame in today.
Anyone point me to some DX7s settings?
MCPX
Old 02-27-2012, 02:32 PM   #34
photocycler
Ok pair of Gens Ace 2500 packs ordered and savox tail servo..should be dialing in the beast this week for a weekend maiden
MCPX
Old 02-27-2012, 06:56 PM   #35
flyfishsick
pics!!! pics!!! where are the pics!!!!
flyfishsick is offline        Reply With Quote
Old 02-29-2012, 12:20 AM   #36
photocycler
Pics will be coming shortly
So battery's will be here tomorrow and I plan to work on beastX setup this weekend.
Do I need a digital pitch gauge to setup pitch?
Would I be better off with EC3 or EC5 for my 2500 packs?
MCPX
Old 02-29-2012, 12:30 AM   #37
alexf1852
Yes, you will need some type of pitch gauge. EC5s are too big for this size bird and not necessary. I prefer XT60 over the EC3. But EC3 are fine too.
Old 02-29-2012, 11:14 AM   #38
Thalios
I use EC5.
EC3 are, I think, rated for max 60A.
All on DX18!
Old 02-29-2012, 11:48 AM   #39
Dead Meat
EC5 here as well, like them a lot.
Dead Meat is offline        Reply With Quote
Old 02-29-2012, 12:15 PM   #40
alexf1852
That rating is 60 amps continuous. The Protos does not pull that much continuously. The average may be 30 to 45 amps over a hard 3d flight. Unless of course you're running a custom wound high powered motor with 470 blades.
Sent from my ADR6300 using Tapatalk
