Old 03-18-2012, 01:39 PM   #81
photocycler
Originally Posted by photocycler View Post
Ok I am sticking with the Red light for MAX Cyclic Limit on the beast and moving on
finally onto the last piece, ESC setup...Are there any stock settings I should change? I dont have a program card but would like to run the governor at 70% throttle with the stock 15t pinion
Ok Finally, got to maiden her and do a test hover...
Originally I had the tail in rate mode with the BeastX which was causing a violent kick on the ground before launch. I have now switched to HH mode with a gain of 60 still has a little tail wag
Is a gain of 60 a good starting point for gain?
photocycler is offline        Reply With Quote
Old 03-18-2012, 05:34 PM   #82
photocycler
Ok I have 4 packs of hovering through her and starting to get the tail where I want it..
- Running Gens Ace 2500 packs which are light, had to push the battery all the way forward and then it hovered very smooth and stable
For the tail..
- I kept pot 3 on the beast X at the default setting, have gain set at 65%.
Tail holds ok on pitch pumps, I am hoping for better, very responsive and not getting any bounce but it does seem to make a loud flutter on hard left rudder
I may need to keep playing with tail settings
Old 12-22-2012, 11:42 AM   #83
matthewcornell
Thanks for the thread! Starting my build today
matthewcornell is offline        Reply With Quote
