Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50
Thunder Tiger 30/50 Raptor 30, Raptor 50 Helicopters
Old 03-05-2012, 06:52 AM   #121
tr911
The bearings came from RC Bearings so I suppose they are shielded.
Titan x50 FBL, R50 Titan SE FBL, R50 V2, R30 V2 , Trex500, T-Rex 450x2, mCPx X2,
tr911 is offline        Reply With Quote
Old 03-05-2012, 06:59 AM   #122
tr911
Hey KC, You coming up for the Helicopter meet Flyin in McCalla this month? I think it is on the weekend of the 16th.
Old 03-05-2012, 07:59 AM   #123
KC36330
No, me event list is mostly jet related.
JetCat USA Rep / KingTech Turbines Rep
KC36330 is offline        Reply With Quote
Old 03-06-2012, 09:42 AM   #124
tr911
Is there a spacer that goes on the OS 50sx for the fan hub? The crank shaft sure does seem long..
Old 03-06-2012, 10:21 AM   #125
KC36330
only a 1mm thick washer between the fan and the front brg.
Old 03-06-2012, 11:19 AM   #126
tr911
Good, I have the washer.
Old 03-06-2012, 03:24 PM   #127
stretch1100
Can anyone suggest setting for a raptor 30 with the copterx 3-axis gyro? Im about ready to do a test flight with the flybarless head.
stretch1100 is offline        Reply With Quote
Old 03-06-2012, 03:35 PM   #128
tr911
Stretch, do you have the programming box or are you using a radio? If radio what modle is it?
Old 03-06-2012, 06:05 PM   #129
stretch1100
I have the box and the USB cable is on order. This is a suggestion someone just gave me on RCG:
I'd set the preset to number 4 and test fly. Both my 450 and 600 required total roll/pitch gain to be reduced from 40 to 25, and later I increased the swash PID I-gain from 80 to 95. I also increased the swash decel a bit for more poppin stops.
Old 03-07-2012, 05:28 PM   #130
tr911
How does that configuration work for you stretch?
Old 03-07-2012, 05:31 PM   #131
cruzroy
i thought you could not free load start a nitro, without prop ???
cruzroy is offline        Reply With Quote
Old 03-07-2012, 05:33 PM   #132
tr911
I LOVE MY AR7200BX... After I changed the Head Lock Gain as KC suggested and fine tuned the swash my Raptor comes off the ground straight up. Everything is right now. No wag, wobble, windage, willies, just straight smooth flight. This saturday is suppose to be clear and 70 degrees out side... It's about time, I'm gonna load up my helicopters and go to the field for a all day event.. WOO HOOO!!! (got to get another gal of fuel)
Old 03-07-2012, 05:39 PM   #133
tr911
I've only read that on forums Cruz, I have not read that anywhere on Thunder Tigers web site or OSs web site. As long as you dont over rev the engine I dont see any harm. I have worked on two cycle engines for a while and tested them with out a load and never had one to break a crank, or a ring or sling a rod If you DO over rev you stand a chance of slinging the rod or breaking it .. that would be a sad day... By the way I'm not saying do it .. use your own descrestion. By the way, again, a nitro engine will run backwards too...
Old 03-07-2012, 05:44 PM   #134
KC36330
all you need is enough weight to flywheel the engine to run it, it doesn't have to be loaded, but DO NOT over speed the RPM, and remove the clutch if you run it with the fan as your flywheel, you'll destroy the clutch and sling both shoes (usually right at yourself) when it spins up otherwise.
Old 03-07-2012, 05:46 PM   #135
tr911
Oh yeah, Thanks KC, if you notice the crank shaft is not bear. It does have the fan and an old clutch that I broke the weights off for my flywheel.
Old 03-09-2012, 09:54 AM   #136
tr911
I got the DS650 mounted on the tail and the DS620 on the throttle. I ordered parts to upgrade to a 50 they should all be here by Monday evening.
What is the difference between FBL and FB blades? Chord? Weight? etc..?
I have a set of Mavrikk 600mm Patriot's on the way.
Old 03-09-2012, 10:23 AM   #137
Bob O
FBL blades are more neutrally balanced for better stability and less work for the servos and FBL system.
Here's a comparison I did of Mavrikk FBL and FB blades. You can see how the FBL blades are neutrally balanced compared to the FB set.
Warp 360 Spartan Vortex VX1
Bob O is online now        Reply With Quote
Old 03-09-2012, 10:39 AM   #138
tr911
Bob, to be honest with you I can't tell the difference from looking at your photo. I wouldn't have know which is which if they weren't marked..lol
Old 03-09-2012, 10:54 AM   #139
Rahulgaba
Tr look at the blades hanging... The FBL ones hang perfectly parallel. And the fb ones are not.. Look at the far end of the two blades. I am not putting on FBL blades yet. Aint got the money. Heehee.
But here's my birds. They all went FBL too!! Yaay!!
Whiplash 90E Scorpion HKIII 4035-560 and MSH Brain
WARP 360 IKON
VIBE 55 IKON Compass TRACX head
JR X9503
Gaba
Rahulgaba is offline        Reply With Quote
Old 03-09-2012, 11:12 AM   #140
tr911
Oh... I get it. The balance is all the way around.. Hmmm I see.... cool..
