Go Back   HeliFreak > R/C Electronics Support > CJY Total-G FBL System
CJY Total-G FBL System Curtis Youngblood Total-G FBL Flybarless System Software and Hardware Support
Old 02-18-2012, 01:46 PM   #1
pugdavey
Default Got a wobble!!!
Just got my velocity 50 converted to fbl.
Had it setup with the totalg flybared to get the tail and gov working well first. It was flying lovely with this setup (just the gov playing some times !!)
Went out today up into a hover and all's ok Fc gain at 50. Then into st1 and its got a alleviator wobble that would shake it to deaf, Flick the Fc gain off and it stops ??
All other settings are stock.
7HV,EL Brute, HW120 hv, bls 451,251, SK540
Warp, mks92a, ds525,hw40pl, sk540
Lynx team pilot
pugdavey is online now        Reply With Quote
Old 02-18-2012, 07:30 PM   #2
vboy55
Sounds like the gain is too high what kind of blades are you using?
vboy55 is online now        Reply With Quote
Old 02-19-2012, 04:45 AM   #3
pugdavey
Got spin 620 but there FB. I did notice my pinion was not very central after I put the new clutch bell on !! Might be vibes ? Head speed is 1800 st1 1950 st2 2050
Sent from my iPhonings
Lynx team pilot
Old 02-19-2012, 12:56 PM   #4
vboy55
Where is it mounted and what's the tail doing? What kinda of tape?
Also if the spindle dampeners are new put a little lube on them so the spindle can float the little bit it needs
Tommy
Old 02-19-2012, 03:11 PM   #5
pugdavey
Its up front and mounted on the supplied tape.
Tail is rock solid
The head has new dampeners and all greased up. I did fly it fine at 1850rpm with Fc 50&60
increase the rpm and it wobbles like a low head speed ?
Lynx team pilot
Old 02-19-2012, 04:29 PM   #6
vboy55
Usually if it vibes the tail is the first to notice try another set of blades any set see of the same thing happens
If you have the tools needed check the cg of each blade maybe off a little or one could weigh a bit more
I run my gain at 48 on my N5c so you can try dropping the gain a bit just to see of it helps
Tommy
Old 02-19-2012, 07:43 PM   #7
Sky Dancer
Sometimes new dampers will cause a wobble at lower head speeds until they loosen up some. I've even sanded the dampers a little to help stop the wobbles at low head speed.
Don C
Sky Dancer is offline        Reply With Quote
