Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 10-16-2012, 01:07 AM   #41
Scooterpilot
X50, YS60SR, Hatori Pipe, CGY750, Rail Blades, Futaba 451 and T/R Futaba 251, Switch Glow
Very nice flying machine.
Name:	G4 and X50.jpg
ID:	357930   Click image for larger version
Name:	On the bench1.jpg
Team Thunder Tiger
Futaba 12Z, 14FG & 8FG
Two Raptor G4's, CGY 750,YS120
Two Raptor X50 FBL, YS60SR, CGY 750
Scooterpilot is offline        Reply With Quote
Old 11-01-2012, 01:22 PM   #42
crazyflyer79
sharing of my titan x50 torque tube FBL
recently changed it to flybarless yet to maiden after the change
components used
cyclic - MKS HBL950 x 3
Tail - Futaba BLS 256HV
Throttle - MKS HV787
TT FBL head
Futaba R6208SB
Futaba CGY750 with gov
YS56sr engine
Hatori 566 56NS-3D Pipe
pushglow
Rotor Tech color 3D 620mm carbon main blade
Rotor Tech 92mm carbon tail blade
upgrade upper and lower bearing block to the alu ones
TT metal cooling fan
powered by a direct 2s 2000mah lipo
Name:	Photo 2-11-12 12 47 04 AM.jpg
ID:	362606   Click image for larger version
Name:	Photo 2-11-12 12 51 24 AM.jpg
ID:	362607   Click image for larger version
Name:	Photo 2-11-12 12 47 59 AM.jpg
ID:	362608   Click image for larger version
Name:	Photo 2-11-12 12 50 34 AM.jpg
ID:	362609   Click image for larger version
Name:	Photo 2-11-12 12 56 04 AM.jpg
Name:	Photo 2-11-12 12 51 54 AM.jpg
crazyflyer79 is offline        Reply With Quote
Old 11-04-2012, 12:54 PM   #43
Langelus
Definately finished with X50's now.. second time in two weeks that I snap the tailbom in-flight First time I managed to save it and this time I broke the landinggear in the auto and it did the suicide chickendance because of the idle on bailout.
Langelus is offline        Reply With Quote
Old 11-04-2012, 01:19 PM   #44
Bob O
Member
I can't see the pics.
What do you mean by "snap"?
Bob O is offline        Reply With Quote
Old 11-04-2012, 01:35 PM   #45
Langelus
Tailbom broke clean off after the clamp for the supports
Old 11-06-2012, 06:37 AM   #46
esmoglo
Here is mine so far so good. I must say I was actively trying to hate this bird (Nitro) but it fly's so darn good I actually like it.
Angelo
esmoglo is offline        Reply With Quote
Old 11-20-2012, 11:05 PM   #47
raptorz499
Maybe you are tightening the bolts wayyyy to tight
raptorz499 is offline        Reply With Quote
Old 11-22-2012, 01:35 AM   #48
Langelus
If you're thinking about the bomfailure then no.. not so tight.
Sent from my GT-S5690 using Tapatalk
Old 12-18-2012, 11:33 AM   #49
aerosmith
Default X50F
The maiden was last week & all is well.
I'm pleased...
ID:	375254   Click image for larger version
Drummer
aerosmith is offline        Reply With Quote
Old 03-02-2013, 12:55 PM   #50
aerosmith
Default My 2nd X50F
Love these things.
Drummer
Old 03-09-2013, 01:08 PM   #51
phil m
is that picture with stick at center and servos are at ninety?
phil m is offline        Reply With Quote
Old 03-10-2013, 08:37 PM   #52
aerosmith
Default No
Powered off.
Drummer
Old 03-21-2013, 04:07 AM   #53
KouDy
What are you using as thorn and clunk in header tank aerosmith? It looks like the thorn is metal part. I am looking at some improvements on that part over plastic one (not speaking of the fact that you have to order whole header tank in order to get it).
shelved : Titan e325 SE flybarred | Titan X50 flybarred torque tube
Futaba 10C in mode 3
KouDy is offline        Reply With Quote
Old 03-22-2013, 02:16 PM   #54
aerosmith
Default It is metal
I'm using a grommet & nipple from another heli I had.
Works great. No leaks!
Drummer
Old 08-06-2013, 06:41 AM   #55
Friedrich
Talking Titan X50 TT
My Titan X50 TT FB
My first nitro heli and had done about 12 flights. Still tweaking the engine and setting it up to my needs.
RL 53 engine
RL 3D Hi-Flow muffler
Align ds610 servo's on cyclic and throttle
Align ds650 tail servo
GY520 gyro
Align G600 governor
Align 2-1 voltage regulator
Hitec 7channel receiver and Hitec Aurora 9 Radio
7.4v 2500mA Lipo
Friedrich
Friedrich is offline        Reply With Quote
Old 10-05-2013, 09:55 PM   #56
skytrekin
X50F with the Redline 56 and 56 high flow 3D muffler
CGY-750 and multi-gov
Outrage Torq servos running on 2s lipo
Maiden flight was today, it flew great!
ID:	455880   Click image for larger version
ID:	455881   Click image for larger version
skytrekin is offline        Reply With Quote
Old 10-05-2013, 10:29 PM   #57
Scooterpilot
It's alwasy great when the first flight is smooooooooth...
Congrat's
Team Thunder Tiger
Old 11-11-2013, 01:13 PM   #58
Rob43
Titan X50 Torque Tube edition, YS 60SR, Hatori SAB-1, Vbar, Futaba BLS servos, Pushglo, CCBEC, Torsion Solid FBL 615mm main blades, KBDD 96mm EE tail blades...pre-maiden
= Rb43 =
Rob43 is offline        Reply With Quote
Old 11-11-2013, 04:23 PM   #59
Bob O
Member
Nice Rob!!
Old 11-11-2013, 08:47 PM   #60
Rob43
Thanks!
= Rb43 =
