Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 10-16-2012, 12:07 AM   #41
Scooterpilot
X50, YS60SR, Hatori Pipe, CGY750, Rail Blades, Futaba 451 and T/R Futaba 251, Switch Glow
Very nice flying machine.
Name:	G4 and X50.jpg
ID:	357930   Click image for larger version
Name:	On the bench1.jpg
Team Thunder Tiger
Raptor G4, CGY 750,YS120
Raptor X50 FBL, YS60SR, CGY 750
Raptor 30 FBL, OS37, CGY 750 12Z, 14SG, 8FG
Scooterpilot is offline        Reply With Quote
Old 11-01-2012, 12:22 PM   #42
crazyflyer79
sharing of my titan x50 torque tube FBL
recently changed it to flybarless yet to maiden after the change
components used
cyclic - MKS HBL950 x 3
Tail - Futaba BLS 256HV
Throttle - MKS HV787
TT FBL head
Futaba R6208SB
Futaba CGY750 with gov
YS56sr engine
Hatori 566 56NS-3D Pipe
pushglow
Rotor Tech color 3D 620mm carbon main blade
Rotor Tech 92mm carbon tail blade
upgrade upper and lower bearing block to the alu ones
TT metal cooling fan
powered by a direct 2s 2000mah lipo
Name:	Photo 2-11-12 12 47 04 AM.jpg
ID:	362606   Click image for larger version
Name:	Photo 2-11-12 12 51 24 AM.jpg
ID:	362607   Click image for larger version
Name:	Photo 2-11-12 12 47 59 AM.jpg
ID:	362608   Click image for larger version
Name:	Photo 2-11-12 12 50 34 AM.jpg
ID:	362609   Click image for larger version
Name:	Photo 2-11-12 12 56 04 AM.jpg
Name:	Photo 2-11-12 12 51 54 AM.jpg
crazyflyer79 is online now        Reply With Quote
Old 11-04-2012, 11:54 AM   #43
Langelus
Definately finished with X50's now.. second time in two weeks that I snap the tailbom in-flight First time I managed to save it and this time I broke the landinggear in the auto and it did the suicide chickendance because of the idle on bailout.
Langelus is online now        Reply With Quote
Old 11-04-2012, 12:19 PM   #44
Bob O
I can't see the pics.
What do you mean by "snap"?
Warp 360 Spartan Vortex VX1
Bob O is online now        Reply With Quote
Old 11-04-2012, 12:35 PM   #45
Langelus
Tailbom broke clean off after the clamp for the supports
Old 11-06-2012, 05:37 AM   #46
esmoglo
Here is mine so far so good. I must say I was actively trying to hate this bird (Nitro) but it fly's so darn good I actually like it.
Angelo
esmoglo is online now        Reply With Quote
Old 11-20-2012, 10:05 PM   #47
raptorz499
Maybe you are tightening the bolts wayyyy to tight
raptorz499 is online now        Reply With Quote
Old 11-22-2012, 12:35 AM   #48
Langelus
If you're thinking about the bomfailure then no.. not so tight.
Sent from my GT-S5690 using Tapatalk
Old 12-18-2012, 10:33 AM   #49
aerosmith
Default X50F
The maiden was last week & all is well.
I'm pleased...
ID:	375254   Click image for larger version
Drummer
aerosmith is offline        Reply With Quote
Old 03-02-2013, 11:55 AM   #50
aerosmith
Default My 2nd X50F
Love these things.
Drummer
Old 03-09-2013, 12:08 PM   #51
phil m
is that picture with stick at center and servos are at ninety?
phil m is offline        Reply With Quote
Old 03-10-2013, 07:37 PM   #52
aerosmith
Default No
Powered off.
Drummer
Old 03-21-2013, 03:07 AM   #53
KouDy
What are you using as thorn and clunk in header tank aerosmith? It looks like the thorn is metal part. I am looking at some improvements on that part over plastic one (not speaking of the fact that you have to order whole header tank in order to get it).
Titan e325 SE flybarred | Titan X50 flybarred torque tube
Futaba 10C in mode 3
KouDy is offline        Reply With Quote
Old 03-22-2013, 01:16 PM   #54
aerosmith
Default It is metal
I'm using a grommet & nipple from another heli I had.
Works great. No leaks!
Drummer
